73 westy Distributer question
rogerd20
rogerd20 is offline
PostPosted: Sun Jul 16, 2017 5:53 pm    Post subject: 73 westy Distributer question Reply with quote
Hey guys, hopting to get some help on my distributer wiring. I just bought this 73 westy that hasn't been ran in many years. The motor cranks with a battery on it and I'm wanting to see if it runs. All the wires are pulled off the ignition coil, and I'm wondering if the black wire that comes of the distributer goes to ground like usual or hot. The other wire seems to wrap under and go to the little cylinder mounted on the side. Thanks before hand for any help.
busdaddy
busdaddy is offline
PostPosted: Sun Jul 16, 2017 6:31 pm    Post subject: Re: 73 westy Distributer question Reply with quote
Exclamation VW grounds are brown, never ground a black wire, especially in the engine compartment, expensive smoke will result. Exclamation
That looks like the wire from the points, it's usually green but you likely have some brand of aftermarket points. It goes to the #1 or - terminal on the coil, the other black wire coming from up by the booster fan on the roof of the compartment goes on #15 (+), there shouldn't be any other wires on that #1 terminal.
rogerd20
rogerd20 is offline
PostPosted: Sun Jul 16, 2017 6:41 pm    Post subject: Re: 73 westy Distributer question Reply with quote
Thanks busdaddy, the picture isn't real clear, there is only 1 wire that can be terminated on the ignition coil, the other wire runs to the small cylinder shaped object on the distributer.
busdaddy
busdaddy is offline
PostPosted: Sun Jul 16, 2017 6:44 pm    Post subject: Re: 73 westy Distributer question Reply with quote
The small cylinder is called a condensor, it's a capacitor to preserve the points contact surfaces, most come with wires to the points and coil installed already like that one appears to have.
rogerd20
rogerd20 is offline
PostPosted: Sun Jul 16, 2017 7:06 pm    Post subject: Re: 73 westy Distributer question Reply with quote
Busdaddy, withthat being said does this wire need to land on the - or + of the ignition coil. Sorry just trying to clarify. Here are some other photos I have.
busdaddy
busdaddy is offline
PostPosted: Sun Jul 16, 2017 7:23 pm    Post subject: Re: 73 westy Distributer question Reply with quote
In this case being a single wire coming from the distributor then it goes on the #1 terminal regardless of it's color, all other wires go on #15, even the black ones.
rogerd20
rogerd20 is offline
PostPosted: Sun Jul 16, 2017 7:32 pm    Post subject: Re: 73 westy Distributer question Reply with quote
Thanks for the help, the wiring in the engine bay is a mess so I'm just trying to figure out enough of them to run it off the battery to see if the motor will turn over.
Tcash
Tcash is offline
PostPosted: Sun Jul 16, 2017 10:35 pm    Post subject: Re: 73 westy Distributer question Reply with quote
If it has not ran in years, change the engine oil & filter, fuel filter and the gas. If you start it with water contaminated or sludge up oil. You will ruin the bearing and seize the motor. Gas that has turned to varnish will clog up the fuel pump and carburetor.
Tcash
Tcash is offline
Welcome to TheSamba, Bay Window Bus Forum!
Tcash wrote:
Every Type IV engine owner should know this!!!
If you over tighten the Oil Strainer bolt, you will brake the engine case!
There is a Oil strainer in there.
TORQUE THE STRAINER BOLT TO NO MORE THAN 9 FT. LBS.
Tcash wrote:
Here is a little information. Good Luck
Pictures would be cool.
How to post photos/How to post a photo in the Forums
Pronunciation (Samba) English
I am thinking of buying a VW van
Cleaning+Rodents+Hantavirus
Up in smoke... Bus fires... don't let it happen to you!
M-Plate Location
M-Plate Decoder Volkswagen Type 2 Bus
Bus VIN / Chassis Numbers
Type 2/Bus Owner's Manuals
Bus repair manuals
Bus parts manuals
Early Baywindow Bus Parts Book
Late Baywindow Bus Parts Fiche
Type 2 Wiring Diagrams
Model and Year Variations
Type 4: Secrets Revealed
Distributor Parts & Specifications
PARTS INTERCHANGE MANUAL
Youtube Videos
There is a ton of information located at the top of the Forum section.
Wasted youth
Wasted youth is offline
PostPosted: Mon Jul 17, 2017 7:07 am    Post subject: Re: 73 westy Distributer question Reply with quote
Some aftermarket coils are not marked with the numbers on the terminals, just a plus or minus symbol.
1968 Double Cab truck, 1973 Auto trans bus, 1978 Auto trans Sunroof bus with A/C and a 1987 Auto trans Westfalia.
kenryan
kenryan is offline
PostPosted: Mon Jul 24, 2017 5:04 pm    Post subject: Re: 73 westy Distributer question Reply with quote
Rogerd20
I hope you don't mind a minor (temporary) highjack of your topic by a related question.
I have a 75 Riviera with 2L Type 4 engine with dual Weber IDF 40s.
I'm looking for a good replacement for the stock ignition.
would like to go with CDI but am stymied trying to find a good distributor WITHOUT vacuum advance. (centrifugal only)
Would appreciate redirection to any appropriate thread covering this issue.
Finding many distributors for Types 1, 2 and 3 but not Type 4.
Have been searching a lot and finally found this RECENT post so though I'd dive in.
Thanks ANYBODY for ANY advice and especially you, Rogerd20 for letting me step on your thread.
Ken Ryan
1975 Riviera
http://www.thesamba.com/vw/forum/viewtopic.php?p=8375801#8375801
1973 Bellanca Super Viking
