'77 Bus Fuel sender - to cut or not to cut
Balmoral1958
Balmoral1958 is offline
PostPosted: Mon Jul 17, 2017 7:38 am    Post subject: '77 Bus Fuel sender - to cut or not to cut Reply with quote
Need to replace my sender - to do it "properly" need to remove my carbs etc.....
or do i just cut an access hole?
Thoughts appreciated
busdaddy
busdaddy is offline
PostPosted: Mon Jul 17, 2017 7:46 am    Post subject: Re: '77 Bus Fuel sender - to cut or not to cut Reply with quote
Only you can answer that question, but once you cut a hole it's hard to undo that.
Shop carefully for a new sender or rebuild yours, most new ones require the hole since you'll be changing it often.
Balmoral1958
PostPosted: Mon Jul 17, 2017 7:53 am    Post subject: Re: '77 Bus Fuel sender - to cut or not to cut Reply with quote
thanks -
If I could make a good looking "hatch" that would help - I have a "European" made sender which may be of marginally better quality...
chachi
chachi is offline
PostPosted: Mon Jul 17, 2017 8:11 am    Post subject: Re: '77 Bus Fuel sender - to cut or not to cut Reply with quote
i say just fix it right and let the next guy fix it in 20 years.
'74 transporter panel
'91 vanagon carat NAHT
inst: @dr.coffey
Abscate Premium Member
Abscate is offline
PostPosted: Mon Jul 17, 2017 9:14 am    Post subject: Re: '77 Bus Fuel sender - to cut or not to cut Reply with quote
Easy one. A note pad and situational awareness can replace a fuel gauge until such time as the engine needs to come out for a maintenance item - at which time out comes the fuel tank for refreshments of hoses and sender.
.ssS!
Balmoral1958
Okay - I believe I can remove the firewall with the engine in... just...
[email protected]
Samba Peckerhead
PostPosted: Mon Jul 17, 2017 9:36 am    Post subject: Re: '77 Bus Fuel sender - to cut or not to cut Reply with quote
Why do people ask this? Like some dude on a forum really matters...
With all the junk parts out there....do it. I did and have for several others. Do it nice and neat. Shit....it was a fix that vw did as well....
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
aeromech
aeromech is offline
PostPosted: Mon Jul 17, 2017 9:46 am    Post subject: Re: '77 Bus Fuel sender - to cut or not to cut Reply with quote
I just cut mine. My reasoning was that VW would have made a access port but they were all into saving money. So I cut the hole and made a cover out of donar metal cut from the baggage floor of a similar year bus. In the end I did a good job and it's all covered up anyway.
Whatever you do, try to replace the sender with an original one, not one made in China.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Balmoral1958
PostPosted: Mon Jul 17, 2017 9:49 am    Post subject: Re: '77 Bus Fuel sender - to cut or not to cut Reply with quote
Thanks - the forum serves a great purpose of giving a diversity of feedback - as we have seen. I'll see if I can find a piece of matching metal...
Any pictures of their hatch would be great...
aeromech
aeromech is offline
PostPosted: Mon Jul 17, 2017 10:17 am    Post subject: Re: '77 Bus Fuel sender - to cut or not to cut Reply with quote
This is one I did in a 1972 bus
And I used a marine access cover
I can't seem to find pics of a cover I did using donar metal
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
mainstreetprod
mainstreetprod is offline
PostPosted: Mon Jul 17, 2017 10:34 am    Post subject: Re: '77 Bus Fuel sender - to cut or not to cut Reply with quote
Easiest , cheapest and safest way is a 4 1/4" hole saw from Harbor Freight on a variable speed drill, with a little cutting oil. No sparks at all= no blowing up the block, as you might do with a grinder and cutting wheel if your sender gasket leaks any fumes at all. And you get a nice neat hole that can be covered with the marine cover posted prior. This may be considered a hack, but with the quality of today's senders it is a necessary hack.
Balmoral1958
PostPosted: Mon Jul 17, 2017 10:44 am    Post subject: Re: '77 Bus Fuel sender - to cut or not to cut Reply with quote
Thanks! Appreciate the responses.
Tcash
Tcash is offline
PostPosted: Mon Jul 17, 2017 10:48 am    Post subject: Re: '77 Bus Fuel sender - to cut or not to cut Reply with quote
Please use
Fuel sender access hole, to do or not to do?
Thank you
Tcash
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Bay Window Bus All times are Mountain Standard Time/Pacific Daylight Savings Time
