mainstreetprod Samba Member
Joined: March 09, 2017 Posts: 313 Location: Tennessee
Posted: Thu Jul 27, 2017 7:40 am Post subject: How difficult to pull the engine in a '78? |
More than likely I will sell this bus as I bought it to shoot a couple of scenes in an indy film. That's now done and it's only value to me is as a promotional vehicle, but that's not possible as it overheats after driving a few miles over 30mph.
Obviously the resale value takes a big hit when it can't be driven more than a few miles, so I'm considering dropping the engine and addressing the cooling issue by stripping the tin, examining and cleaning the oil cooler and cylinders, and doing a "reseal" by replacing oil cooler o rings, pushrod seals and valve cover gaskets. I think the heads are fine since the engine runs fairly strong, but might pull them and check things out while I'm at it. I would also source and replace the missing lower tin pieces the previous "mechanic" didn't bother to reinstall.
I haven't pulled a VW engine since 1974 or so when I was 17 (that was a '68 bug). If I remember correctly It involved only getting the rear of the bus up a foot or so, removing the 4 nuts, disconnecting fuel lines, accelerator cable and a few wires and then dropping the engine to the rear and down with a floor jack. Am I missing something? |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Thu Jul 27, 2017 7:45 am Post subject: Re: How difficult to pull the engine in a '78? |
That covers the basics. But most in here will suggest pulling the tranny out with the engine. I followed their recommendations earlier this year, and it was a success for being my first time. Good luck!
Edit: And as long as you have to remove 2 CVs, you might as well clean and repack all 4. Very messy job, but important. _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM
Sally the Bus Samba Member
Randy in Maine Samba Member
Posted: Thu Jul 27, 2017 7:54 am Post subject: Re: How difficult to pull the engine in a '78? |
Quote: |
I would also source and replace the missing lower tin pieces the previous "mechanic" didn't bother to reinstall. |
The likely source of your problem. |
consvws Samba Member
Joined: April 07, 2009 Posts: 950 Location: Roseburg, OR
Posted: Thu Jul 27, 2017 7:58 am Post subject: Re: How difficult to pull the engine in a '78? |
CompleteHavoc Samba Member
Joined: October 16, 2014 Posts: 31 Location: Crown point, in
Posted: Thu Jul 27, 2017 8:46 am Post subject: Re: How difficult to pull the engine in a '78? |
Follow the Ratwell instructions... everything is listed in order... Did this 2 years ago with out any prior knowledge of VW's.
The wife freaked out, I have a history of losing interest when things go sideways... Ratwell made it so simple. Pulled the motor, cleaned out all the rats nests, powder coated shroud, tins, etc. installed in reverse.
Thing runs like a top - though I'm not sure about it being timed correctly... but that's my next thread... |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Thu Jul 27, 2017 9:10 am Post subject: Re: How difficult to pull the engine in a '78? |
Before getting into this you may want trouble shoot why it,s overheating and how much time and money your willing to spend to make it right.A bus with a running engine,albeit one that over heats would be worth more then a bus with a engine in a box. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
Gregg in the 603 Samba Member
Joined: April 13, 2013 Posts: 404 Location: New Hampshire, USA
Posted: Thu Jul 27, 2017 10:00 am Post subject: Re: How difficult to pull the engine in a '78? |
Also, how do you know it's overheating? Do you have a gauge on it? _________________ 1979 Mexico Beige Westy auto
Dirty Dover, NH |
Posted: Thu Jul 27, 2017 12:17 pm Post subject: Re: How difficult to pull the engine in a '78? |
Gregg in the 603 wrote: |
Also, how do you know it's overheating? Do you have a gauge on it? |
It gets hot enough to start burning accumulated oil off engine and heat exchangers, causing a lot of smoke. Also, last time it happened, had loud valve clatter, which goes away when cooler. Dipstick wasn't all that hot, but I read that the "dipstick test" doesn't apply to type 4's. |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3853 Location: San Jose, CA
Posted: Thu Jul 27, 2017 12:31 pm Post subject: Re: How difficult to pull the engine in a '78? |
I've pulled and installed countless engines, but so when it was time to do my first Type-IV, I followed the ratwell sequence, merely because I was dealing with F.I. And I left the trans in.
So in retrospect, the only thing I don't get is why ratwell instructs to remove the starter. Disconnect the wires to get the alternator wire (and MAYBE the F.I. relay wire) off, sure...but in the end, I'm just about 99.5% sure the starter could've stayed put. |
my59 Samba Member
Joined: August 13, 2003 Posts: 3793 Location: connecting the dots
Posted: Thu Jul 27, 2017 5:18 pm Post subject: Re: How difficult to pull the engine in a '78? |
I drop it with the transmission so I can get at the shifter bushings. Using a MC lift and a wheeled floor jack, comes out no problem. Back of the bus needs to be a little over 2 feet off the floor.
The reinstall single handed means getting it all lined up, as it is tough to muscle it into place if it is not lined up right. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Abscate Samba Member
Posted: Thu Jul 27, 2017 5:52 pm Post subject: Re: How difficult to pull the engine in a '78? |
You won't add any resale value to your Bus with a rookie refit.
Of course, if you want to get some experience, go for it. _________________ .ssS! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51152 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Jul 27, 2017 7:02 pm Post subject: Re: How difficult to pull the engine in a '78? |
Oil burning off on a bus that's sat a long time isn't uncommon, especially if you've given it a tune up and awakened a dead cylinder or two that's accumulated extra scum while it slept.
You can pull enough tin to access the oil cooler and fins while the engine is still in the bus. If it's not pissing out a quart every time you drive it or has clutch issues consider jacking it up to a height where you can sit on a chair and lean into the compartment comfortably and doing the job in place. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
