I think my Alternator wants to drive me crazy..
a-marshal
a-marshal is offline
PostPosted: Mon Jul 17, 2017 3:15 pm    Post subject: I think my Alternator wants to drive me crazy.. Reply with quote
A couple weeks ago as we tried to leave the cottage the generator light on our Westy refused to light. I cleaned the contacts on the starter motor and on the battery terminals and tried again.. it worked fine.. drove home. The next morning it would not light..checked a bunch over the week and it would light maybe 10% of the time (usually first thing in the morning). Next step was to replace the voltage regulator, so bought and installed one something like 10 days ago.. all seems well and light comes on every time I check, until today No light...
For whatever it may be worth the Battery is a 3 year old Optima Red Top and starts like a dream. When the light comes on it charges fine, without the light obviously nothing...
Before I go and invest in a new alternator is there something else I should look at?
If I have to replace the alternator is there any good guide to doing it with the engine still in the vehicle? I've got nowhere to drop the engine.
-Ob. vehicle info....
1973 Westy w/ '74 1.8 liter / dual kadrons / 009 distributor / pertronix
Wasted youth
Wasted youth is offline
PostPosted: Mon Jul 17, 2017 5:42 pm    Post subject: Re: I think my Alternator wants to drive me crazy.. Reply with quote
Check your transmission ground strap and negative battery connection on body.
1968 Double Cab truck, 1973 Auto trans bus, 1978 Auto trans Sunroof bus with A/C and a 1987 Auto trans Westfalia.
a-marshal
PostPosted: Mon Jul 17, 2017 6:14 pm    Post subject: Re: I think my Alternator wants to drive me crazy.. Reply with quote
They appear to be good, tomorrow morning I'll try a jumper cable from the negative terminal to the engine case just to make sure.
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Mon Jul 17, 2017 9:18 pm    Post subject: Re: I think my Alternator wants to drive me crazy.. Reply with quote
Broken filiment in the bulb making intermittent contact?
telford dorr
telford dorr is offline
PostPosted: Tue Jul 18, 2017 12:15 am    Post subject: Re: I think my Alternator wants to drive me crazy.. Reply with quote
Disconnect the blue wire at the regulator and ground it. Turn the key on. The GEN light should be lit. If it isn't check the GEN bulb and holder, and the 12 volt feeder to the GEN light mounting plate.
'71 panel, now with FI
To steal ideas from one person is plagiarism; to steal from many is research - Steven Wright
All models are wrong; some are useful - George Box
More VW electrical at http://flowcon.us/td/ (available 9am to 9pm PST)
a-marshal
PostPosted: Tue Jul 18, 2017 6:22 am    Post subject: Re: I think my Alternator wants to drive me crazy.. Reply with quote
Well this morning it lights every time*.. so if I am understanding things correctly the next time it refuses to light I'll perform Telford's test bellow..
if the light stays out then the problem is likely in the bulb, socket or connection in the dash, if however the light goes on at that point I would have to look at the problem being inside the alternator..
*(I]m not going to suggest that the timing to these failures seems to be when it is the most inconvenient but it seems like if I have a bunch of time to work on things the light works perfectly...)
telford dorr
PostPosted: Tue Jul 18, 2017 10:28 am    Post subject: Re: I think my Alternator wants to drive me crazy.. Reply with quote
But isn't that the way things always are??? Rolling Eyes
