DeathBySnuSnu Samba Member
Posted: Fri Jul 21, 2017 8:19 pm Post subject: Re: Just weird - WooooHooooo scooter |
I left out all the motorcycle parts pics.....
The trans don't have so many custom parts in it. Off the shelf stuff. Everything other than the chrome tubes and the 3.44 gear I already had in my junk pile.
Late swing with the wide syncros.
Normal 1 and 2
1.26 third
.82 fourth.
Welded hubs
3.44 ring and pinion, splined but type.
Hd side covers
Narrowed axles.
Cut down chrome axle tubes
Disc brakes
Oil mods to run upside down.
The only other oddity it the drive extension.
If ya wanna see that I have the pics. |
Posted: Fri Jul 21, 2017 8:23 pm Post subject: Re: Just weird - WooooHooooo scooter |
Hey jet boat...
No. Not a shop at home. This is at my work. I am part owner of a machine shop/manufacture.
4 of us
An electrician
A machinist
A mechanic
And me the engineer. |
58 Plastic Tub Samba Member
Joined: September 03, 2007 Posts: 418 Location: Nowhere, USA
Posted: Sun Jul 23, 2017 2:49 pm Post subject: Re: Just weird - WooooHooooo scooter |
DeathBySnuSnu wrote: |
Hey jet boat...
4 of us
An electrician
A machinist
A mechanic
I cannot tell you how jealous that makes me. Not the partnership (which almost never ends well), but the full bore machine shop at your disposal.
BTW: Wicked cool stuff. _________________ Stan Galat
"Everybody is entitled to their own opinions, but not their own facts." |
vwjetboat Samba Member
Posted: Sun Jul 23, 2017 2:55 pm Post subject: Re: Just weird - WooooHooooo scooter |
Hey jet boat...
4 of us
An electrician
A machinist
A mechanic
very nice.. enjoying life .. |
Posted: Mon Jul 24, 2017 5:04 pm Post subject: Re: Just weird - WooooHooooo scooter |
Drive extension.
Clatter Samba Member
Joined: September 24, 2003 Posts: 7537 Location: Santa Cruz
Posted: Mon Jul 24, 2017 10:31 pm Post subject: Re: Just weird - WooooHooooo scooter |
Love this build...
Good on you for rebuilding all the pics.
Being an IT guy by trade, the hardest part can be picking the winners!
Go ahead and get some huge chrome deep deep Cragar S/S mags for the back of the thing..!
Sure they won't work as well as the negative offset ones you have,
But,
With a springer font end,
You kind of have a certain commitment now.
Some big big rubber will help gear it up, too.
I get the feeling it will pull it..
Love all of the original thinking.
Great build. _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Tue Jul 25, 2017 5:03 pm Post subject: Re: Just weird - WooooHooooo scooter |
Mehhh...
I re-geared the trans to fit already.
Big tires are just such a power suck....
Certainly look cool though...
I am ok with the amount of tire on it.
I never did wear out the old ones, over 10yrs old. They finally got so dryed out they would not hook anymore.....just scratch.
Posted: Sat Aug 05, 2017 2:50 pm Post subject: Re: Just weird - WooooHooooo scooter |
After some discussion and research I went ahead with a split header and anti reversion cans.
I just don't have a place for a 4 into 1 merge. Maybe a tri Y, but it would be long and not very even.
So here I am paired with 1 and 3 around the flywheel end. Then 2 and 4 around the pulley end.
1-5/8 out of the head and into the can as the ID matches the port.
Then out of the can at 1-3/4 to the steep tri Y style 2 to 1 collector.
Then a 2 inch short out of collector into a 2-1/2 elbow with a 2 inch outlet cone as a anti reversion can on the outlet.
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Sat Aug 05, 2017 2:59 pm Post subject: Re: Just weird - WooooHooooo scooter |
Now you can hide a turbo in there! |
Posted: Sat Aug 05, 2017 3:05 pm Post subject: Re: Just weird - WooooHooooo scooter |
I did seriously consider a small turbo on top of each head.
But I have enough heat management issues to deal with normally aspirated. |
Posted: Mon Aug 21, 2017 6:49 pm Post subject: Re: Just weird - WooooHooooo scooter |
The old 2110
260 at .050 cam.
4 straights.
I wonder what the 2387 fuelie is gonna sound like.... |
Posted: Sat Aug 26, 2017 11:22 am Post subject: Re: Just weird - WooooHooooo scooter |
Working on gas tank bottom pick up and return.
mark tucker Samba Member
Posted: Sat Aug 26, 2017 11:39 am Post subject: Re: Just weird - WooooHooooo scooter |
if you put the pickup at the lowest point it should suck up all the crap&water so it dosen't clog the tank&rust it out just messen with ya. keep up the good work. you going to make it 2 stage/levels for a reserve? it can have it's addvantages but the reserve needs to be used often so it dosent funk up....keep it up, your gonna have fun when it's done. |
Posted: Sat Aug 26, 2017 12:31 pm Post subject: Re: Just weird - WooooHooooo scooter |
This should leave a little bit in the tank.
The other tank I made before really was in the very lowest point.
No reserve.
I am gonna have a sight tube on the side of the tank. |
Posted: Sun Aug 27, 2017 11:00 am Post subject: Re: Just weird - WooooHooooo scooter |
sight tube...O I sea. I just saw the turbo comment and the heat management responce....hell use a turbo for cooling!!!! and one for power!!! arnt we back seat engineers nice to have on hand to solve all these issues...... :2gunfire: crap are those real bullets!!!your good keep going, just don't shoot me. |
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
Posted: Sun Aug 27, 2017 2:41 pm Post subject: Re: Just weird - WooooHooooo scooter |
mark tucker wrote: |
use a turbo for cooling!!!! and one for power!!! |
I like that! _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379 |
Posted: Sat Sep 09, 2017 12:39 pm Post subject: Re: Just weird - WooooHooooo scooter |
Not much going on.
Still having health issues.
A small bit of work on it this morn.
Made up the tunnel snd did somr welding. Gas tank bottom nearly done.
Posted: Sat Sep 30, 2017 12:02 pm Post subject: Re: Just weird - WooooHooooo scooter |
And again.
Trying to get back to work on the project.
Welded some more on that gas tank.
Finished up some wiring.
Finished the oil primer.
Posted: Sun Oct 08, 2017 6:50 pm Post subject: Re: Just weird - WooooHooooo scooter |
The gas tank sealer came in on Saturday.
But like usual I was at work all weekend.
Maybe later.
Posted: Mon Oct 09, 2017 10:43 am Post subject: Re: Just weird - WooooHooooo scooter |
wtf??? you tank is already rusted!!!! getter done!!! hope the storms are bypassing you. dam thing sent a tornado over us.....and lotsa rain, ,my orange trees are exploding oranges , I pick them go out 1 min lator and get some more exploding ones so i can juice them befor any bugs get them....humming birds like them to so I give them one on the table to suck on. |
