STUNNED MULLET Samba Member
Joined: August 13, 2013 Posts: 154 Location: Fresno, CA
Posted: Fri Jul 21, 2017 12:53 pm Post subject: sheet metal question... |
HI all, I want to start working on this rust repair on my 78. I found a donor vehicle (same year), and was thinking on just cutting the panels from it as it is a dry bus. he wants 600 for all the sheetmetal I need. both sides down the middle of the bus, both rear quarter panels for the wheel wells, and both rear pieces that are on the back of the front wheel wells, and the whole slider door. I have seen some repair panels from EIS parts, that would probably do the trick, but I want to see if the original sheet metal would be a stronger/better option vs the internet stuff? kinda weird question... but I trust your guys opinions on this site... thanks in advance |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Fri Jul 21, 2017 1:33 pm Post subject: Re: sheet metal question... |
Original metal is better. Is the donor shell better than your bus? Perhaps you could just swap your stuff into his shell. You probably already thought of that. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
ateneo Samba Member
Joined: June 12, 2008 Posts: 403 Location: Orange County, California
STUNNED MULLET wrote: |
both sides down the middle of the bus, both rear quarter panels for the wheel wells, and both rear pieces that are on the back of the front wheel wells, and the whole slider door. |
By using original panels you don’t have to worry about modifying the panels to make them fit. Just make sure that the donor panels were cut clean and right. _________________ 1966 Riviera camper Bus
1967 EZ camper bus
1971 Westfalia bus
1971 Deluxe bus
1969 Bus
1962 Bug
1963 Bug
"Rust free" means Rust is FREE. The rest is junk. |
Westfalia73 Samba Member
Joined: June 07, 2016 Posts: 121 Location: New Zealand
Posted: Fri Jul 21, 2017 1:47 pm Post subject: Re: sheet metal question... |
Original panels will be so much better than the aftermarket, some of the aftermarket panels are shit imo. _________________ 1973 tintop westfalia weekender.
1973 beetle.
1981 Brazilian baywindow kombi. |
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Fri Jul 21, 2017 1:49 pm Post subject: Re: sheet metal question... |
I only use original metal when possible, if not I go to the best quality parts I can find, and those aren't usually sold through the normal places that sell junk. _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
Posted: Fri Jul 21, 2017 2:00 pm Post subject: Re: sheet metal question... |
ok... I figured that was going to be the unanimous opinion... thanks guys. I need a lot from this donor, so hopefully he will make me a good deal. tanks a million... |
Keith Samba Member
Posted: Fri Jul 21, 2017 2:09 pm Post subject: Re: sheet metal question... |
Who is your donor? I need more pieces cut for my '78 _________________ Formerly known in the forums as "OVALTEEN"
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
HelmutofBuffalo Samba Member
Joined: August 22, 2005 Posts: 554 Location: West Coast of New York
Posted: Fri Jul 21, 2017 5:55 pm Post subject: Re: sheet metal question... |
Something about the old German steel makes it "work" easier when hammering out dents, welding etc. the steel used in most parts today seems IMO "brittle or stiff" . Even when fixing rust damage I always preferred sheet metal from a donor vehicle to new metal. I believe it has something to do with the smelting process. _________________ 1979 Type I Convertible |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Sat Jul 22, 2017 5:57 am Post subject: Re: sheet metal question... |
Matt, it really sucks they cannot release the entire bus, so you are really at their mercy. Try to convince them not to use the Oxy-Ace torch... even though they say they'll cut six inches above what you need.
Get a carborundum blade for a Skil saw, set the depth of the blade to 1/4 inch, then snap out chalk string lines on the body and make nice smooth cuts. Use a Sawzall to reach into the pockets and cut the weird angles. |
Manfred58sc Samba Member
Posted: Sat Jul 22, 2017 8:47 am Post subject: Re: sheet metal question... |
OG by a mile, and follow the above recommendations for proper cutting. _________________ Fat chick owner/operator |
nemobuscaptain Samba Member
Posted: Sat Jul 22, 2017 11:37 am Post subject: Re: sheet metal question... |
Hi all, after pleading with the owner, they decided to sell the whole bus. I went down this morning and bought it... yikes... its SUPER SUPER dry... the cargo floor looks ridicoulsy clean. The only rot is the rear corners and the battery tray. No motor or trans, and no middle or rear seats. Missing bumpers, and steering wheel.
Tcash Samba Member
Tcash Samba Member
Posted: Sat Jul 22, 2017 12:39 pm Post subject: Re: sheet metal question... |
What is the M-Plate numbers?
M-Plate Location |
Posted: Sat Jul 22, 2017 12:41 pm Post subject: Re: sheet metal question... |
So glad you could work that out. Just the jewelry alone (hasps, latches, cranks, glass, knobs, etc.) is worth the fight for it.
Not sure if you can get this moved through DMV to get it registered again, but if so IMO this would have WAY more value in the end if it was restored to a daily driver.
But I think we talked about that... |
Posted: Sat Jul 22, 2017 1:12 pm Post subject: Re: sheet metal question... |
I am definitely going to try to get it back registered before the cut.. but wasted youth... weren't we talking about the pain and misery of the swap?!!! |
rusty busty Samba Member
Joined: May 27, 2015 Posts: 310 Location: Vancouver BC
Posted: Sat Jul 22, 2017 1:32 pm Post subject: Re: sheet metal question... |
Nice! Champagne edition. My vote is don't cut it up if at all possible.
A dry Champaign edition should be saved! _________________ 1978 CEII Get-away hightop |
Posted: Sat Jul 22, 2017 3:05 pm Post subject: Re: sheet metal question... |
I like to refer to it as sham pag knee.... LOL!! |
Posted: Sat Jul 22, 2017 4:01 pm Post subject: Re: sheet metal question... |
Yes! That is truly a fair amount of work. However... comparing the sheetmetal work needed on the Tahoe bus with the mechanical work of moving the Tahoe's power train over to the Champagne's, I would definitely go with building up the Champagne. Plus, you get a sunroof CE-2! Total score!
Put it to the community. Post several pics of the Tahoe rust and Poll the audience.
BUT... that plan only works with getting the CE-2 out of whatever Title situation it's in and on to some path of actualization. |
