Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2240 Location: Medford, OR
Posted: Mon Jul 24, 2017 7:41 am Post subject: Sourcing 914 Transmission |
Looking to replace transmission -76 914 2.0 (though a 2.2 is going in)
Where to begin finding a solid replacement?
Rev. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
nogoodwithusernames Samba Member
Joined: November 10, 2014 Posts: 599 Location: CA, USA
Posted: Sun Jul 30, 2017 7:03 am Post subject: Re: Sourcing 914 Transmission |
Found Gene in Utah with rebuilt. Has others available as well, if anyone is in need of such a transmission,
https://www.thesamba.com/vw/classifieds/detail.php?id=2054638
Also had set of new 3bolt heads. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
Joined: December 28, 2016 Posts: 279 Location: atlanta ga
Posted: Wed Oct 25, 2017 7:51 am Post subject: Re: Sourcing 914 Transmission |
914 transmissions are a dime a dozen, but most by now suffer at least first gear problems if not second as well. We have seen few ring gear and pinion problems. The problem is that the parts are expensive, not so much the rebuild labor as long as one has the proper factory tools to reset things like ring gear and pinion depth and to press off the dog teeth. SO one winds up spending 2000 on a rebuild, when one can purchase a used questionable transmission for 250. Just does not make much sense "huh" |
Posted: Sat Nov 25, 2017 9:30 am Post subject: Re: Sourcing 914 Transmission |
Found one from Genno in Utah for reasonable, plus a couple of 2.0 heads.
He even dropped them off in his way through to Portland.
After the car is put back together, I’ll train my sights in that direction. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
