rustfree1967bug Samba Member
Joined: November 16, 2006 Posts: 3436 Location: minnesota
Posted: Mon Jul 24, 2017 12:02 pm Post subject: Issue with emergency flasher |
This is on my '74 standard i just got. The emergency flashers only work with the key on, after doing some reading here i found i need to have the red wire hooked to fuse #8 which is hot all the time. When i hook that wire up my radio comes on as do both the generator and oil light on the speedo. Just wondering what is going on with that. It is an aftermarket rsdio and the memory wire is hooked to fuse #8 as well but i don't think that would do it. _________________ '70 ghia
'69 ghia
'65 singlecab
'66 sunroof beetle
'74 bus
'67 so-42
IDA's...well... they talk dirty -MURZI |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15982 Location: North Florida, USA
Posted: Mon Jul 24, 2017 2:17 pm Post subject: Re: Issue with emergency flasher |
This simplified pic of the E-Flasher and turn signal systems should help you:
Notice above the E-Flasher switch on the right you have two different sources for 12v+. The #15 (green wire) is the ignition switched source that powers the turn signals. The #30 (red wire) source is the power for the E-Flashers. Since #30 power comes from a fuse that has constant 12v+ it works whether the ignition switch is ON or OFF.
From your initial description it sounds like you have the #30 terminal of the E-Flasher switch connected to the #15 fuse. This would only allow the E-Flashers to work WHILE the ignition switch is ON. Confirm which wire is connected to which fuse and which terminal on the E-Flasher switch. All the terminal #s and wire colors are listed in the diagram. _________________ AshMan40
Posted: Mon Jul 24, 2017 7:37 pm Post subject: Re: Issue with emergency flasher |
I haven't pulled the switch out to see what is what but there is a red wire connected to it and even with it connected to nothing on the fuse box the hazards will work with the key on. There is a small green and a small black wire hooked together that are on fuse #12. I tried connecting what i assume is the #30 wire to fuse #8 like it should be but that is when radio and speedo warning lights come on. Turning the hazard switch on those things then shut off. _________________ '70 ghia
'69 ghia
'65 singlecab
'66 sunroof beetle
'74 bus
'67 so-42
Posted: Tue Jul 25, 2017 5:10 am Post subject: Re: Issue with emergency flasher |
Sounds like your E-Flasher switch is wired incorrectly. You will need to get a look at which wire goes to which terminal. See if you can't get a camera in there to take a pic of the wires and the terminal #s. _________________ AshMan40
Posted: Tue Jul 25, 2017 7:55 pm Post subject: Re: Issue with emergency flasher |
rustfree1967bug wrote: |
I haven't pulled the switch out to see what is what but there is a red wire connected to it and even with it connected to nothing on the fuse box the hazards will work with the key on. |
When the E-Flasher switch is ON, the flasher relay is powered from the #30 terminal on the E-Flasher switch. If you have this wire disconnected and the flasher relay is STILL powered something is clearly wired wrong. Use the above diagram as a guild and confirmed your wiring.
There is a small green and a small black wire hooked together that are on fuse #12. I tried connecting what i assume is the #30 wire to fuse #8 like it should be but that is when radio and speedo warning lights come on. Turning the hazard switch on those things then shut off. |
The radio and speedo warning lamps are powered from fuse #12 of the fuse box. They should be powered as soon as the ignition switch is turned ON. If they are only powered when the E-Flasher switch is ON then you clearly have something wired wrong. Possibly the output from the E-Flasher switch (+) is connected back to the fuse box instead of running to the flasher relay? _________________ AshMan40
