E1 Samba Member
Joined: January 21, 2013 Posts: 6569 Location: Westfalia, Earth
Posted: Tue Jul 25, 2017 3:25 pm Post subject: Stock or Aftermarket Distributors & Coils -- Experiences? |
Our distributor broke a critical, tiny (green) wire near the rotor last week, totally disabling our 1984, 1.9L for a day near Aspen. We managed to re-solder it with the help of a passing heavy equipment mechanic, but it still barely ran and the very thought of moteling in Aspen while awaiting a distributor, Yikes!
In the end we found a wonderful mechanic at Aspen Total Automotive. The key on the distributor was also broken (odd!), and he worked a fix within an hour off the tow truck -- for $67.50 Labor. HIGHLY-RECOMMENDED.
So I ask:
1). Has anyone used or know anyone using a different distributor than stock?
2). Is Bosch still the safest bet?
3). Vendors for an entire distributor?
(I'd prefer all-new if possible -- unless you all think rebuilt has *extensive* longevity)
4). I've never heard of this, but the Flamethrower distributor looks good "on paper":
https://www.carid.com/pertronix/flame-thrower-vw-s...gJ2SPD_BwE
Also, anyone have experience or input regarding a higher-output coil?
THANKS in Advance! _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
B.O.B.Wanders Samba Member
Joined: July 22, 2014 Posts: 351 Location: Atlanta, GA USA
Posted: Tue Jul 25, 2017 6:49 pm Post subject: Re: Stock or Aftermarket Distributors & Coils -- Experiences? |
I've used Pertronix electronic ignition modules in a Lucas distributor on an MGB and they are pretty good, but consider what it replaced. I wasn't aware of the"stock-like" Pertronix distributors. Looks awesome. That's about the same price for a new Hall sender unit from BD. I too recently had a break in one of those Hall sensor wires at a splice up under the wire cover and it took a while to find it. Tiny wire but it stops you dead in your tracks. _________________ 83.5 WBX 2WD Assuan Brown Westy, B.O.B.
"It feels good to be lost in the right direction” - unknown |
Gauche1968 Samba Member
Posted: Tue Jul 25, 2017 8:52 pm Post subject: Re: Stock or Aftermarket Distributors & Coils -- Experiences? |
There are aftermarket distributors for a 1.9L Vanagon?
You can't get a new distributor. Well, Ken at Vanagain said he had three NOS left a few months ago, but who knows if he still has them. Otherwise, you have to have your distributor rebuilt. Ken can do it and Bus Depot also offers a service, as do the various part houses: NAPA, Rock Auto, etc. for less money, but who knows what the quality of those are. _________________ 1984 Vanagon GL
1984 Vanagon Westy |
E1 Samba Member
Posted: Wed Jul 26, 2017 8:15 am Post subject: Re: Stock or Aftermarket Distributors & Coils -- Experiences? |
B.O.B.Wanders wrote: |
I've used Pertronix electronic ignition modules in a Lucas distributor on an MGB and they are pretty good, but consider what it replaced. I wasn't aware of the"stock-like" Pertronix distributors. Looks awesome. That's about the same price for a new Hall sender unit from BD. I too recently had a break in one of those Hall sensor wires at a splice up under the wire cover and it took a while to find it. Tiny wire but it stops you dead in your tracks. |
Thanks!
I'm a bit familiar with the vagaries of Leyland electronics, having had warm beer with the sports car racing crowd.
Glad you think the company is okay, and I do have a question... is the Hall sender a separate item, or does it appear to be included with this or a NOS unit?
Thanks Again! _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
E1 Samba Member
Posted: Wed Jul 26, 2017 8:21 am Post subject: Re: Stock or Aftermarket Distributors & Coils -- Experiences? |
Gauche1968 wrote: |
You can't get a new distributor. Well, Ken at Vanagain said he had three NOS left a few months ago, but who knows if he still has them. Otherwise, you have to have your distributor rebuilt. Ken can do it and Bus Depot also offers a service, as do the various part houses: NAPA, Rock Auto, etc. for less money, but who knows what the quality of those are. |
I was also shocked when Google pulled this distributor up.
A NAPA we went to carried one from Echlin, a rebuilt I suspect (didn't ask in deference to buying from a bus supplier). You mentioned my Plan B in Ken...
Thank You! _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
E1 Samba Member
Posted: Fri Jul 28, 2017 5:37 pm Post subject: Re: Stock or Aftermarket Distributors & Coils -- Experiences? |
Shameless bump hoping for more input.
I'm leaning towards buying the all-new Flametronix distributor, and having my factory unit rebuilt as a back up.
Does it appear to come with a Hall sender?
I am also still curious if there's benefits to a higher-output coil. Semi-related or maybe not, once my alternator output went from 13.6 to 14.5 volts, the van ran much better and mpg gained at least 10%.
Is more spark is helpful? Or potentially too hot for the chambers. (?)
Thanks! _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Posted: Fri Jul 28, 2017 8:45 pm Post subject: Re: Stock or Aftermarket Distributors & Coils -- Experiences? |
The Hall effects sensor activates the ignition module and is an integral part of the distributor "system" so I'm am certain it would be included. _________________ 83.5 WBX 2WD Assuan Brown Westy, B.O.B.
the joker Samba Member
Posted: Sat Jul 29, 2017 5:51 am Post subject: Re: Stock or Aftermarket Distributors & Coils -- Experiences? |
please keep us posted I'm looking to upgrade , 2.1 L wasserbox, joker running with a single factory solex carb think it would be a good combo , use to run that with a blue '' hot'' coil , on a 69 ghai , always ran great. |
E1 Samba Member
Posted: Sat Jul 29, 2017 9:43 pm Post subject: Re: Stock or Aftermarket Distributors & Coils -- Experiences? |
Has anyone had their factory distributor rebuilt?
I could price around and still may, but if anyone knows the cost and success of this, and from whom, I'm all ears.
Thanks Again. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
