Carburetor for 1776cc with 110 cam dual port Centermounted
cocopuffsman
cocopuffsman is offline
PostPosted: Wed Jul 26, 2017 1:03 pm    Post subject: Carburetor for 1776cc with 110 cam dual port Centermounted Reply with quote
Currently I have a Porsche 356 zenith 32 NDIX center-mounted but I have replaced jets and soaked it in carb cleaner multiple times over the years and im ready to get a more reliable setup.
A friend suggested that I should use the center mount 44 HPMX EMPI CARB for my setup.
I wanted to get more opinions and wanted to know what would be a well rounded carburetor for me?
https://youtu.be/z5yDe0MKzYw
https://youtu.be/MpJoZYZNLLI
https://youtu.be/m8-rsKIvbos
https://youtu.be/bfYDA3-N0fg
vwkirb
vwkirb is offline
PostPosted: Wed Jul 26, 2017 2:53 pm    Post subject: Re: Carburetor for 1776cc with 110 cam dual port Centermounted Reply with quote
I doubt you need a 44 idf/hpmx.. 40 would probably be closer set up out of the box...
Whatever you end up with, clean the carb well, check and set the float and get a good airfiter! I suggest an R2C filter and a sturdy filter base like the billet ones as opposed to stamped steel.
Andrew Kirby
cocopuffsman
PostPosted: Wed Jul 26, 2017 3:34 pm    Post subject: Re: Carburetor for 1776cc with 110 cam dual port Centermounted Reply with quote
alright Thankyou
vwkirb
vwkirb is offline
PostPosted: Wed Jul 26, 2017 3:41 pm    Post subject: Re: Carburetor for 1776cc with 110 cam dual port Centermounted Reply with quote
You may get more advice over in the high-performance form!
Andrew Kirby
Bashr52
Bashr52 is offline
PostPosted: Tue Aug 08, 2017 4:36 am    Post subject: Re: Carburetor for 1776cc with 110 cam dual port Centermounted Reply with quote
Duals would be easier, and give you more power.
