Electrical fuel pump issues
kerian159
kerian159 is offline
PostPosted: Sun Jul 30, 2017 3:11 pm    Post subject: Electrical fuel pump issues Reply with quote
I've got a weird issue bus ran perfect last weekend then went to drive it to my parents (half a mile) it makes it about 5 min and dies. Turn the key on and nothing from the fuel pump. Let it sit for a while it fires up and runs (cooler evening temps, nw fl). I've tried searching but it brings up over 900 entries. Thanks in advance.
1976 Type II Westy P22
"Growing older, but not up!"
pioneer1
pioneer1 is offline
PostPosted: Sun Jul 30, 2017 3:14 pm    Post subject: Re: Electrical fuel pump issues Reply with quote
typical of a plugged fuel line or filter. When it sits for a minute without a demand the gas manages to seep through until it runs out again.
"Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project
kerian159
PostPosted: Sun Jul 30, 2017 3:15 pm    Post subject: Re: Electrical fuel pump issues Reply with quote
That's what I thought but I can't even hear the pump running.
pioneer1
pioneer1 is offline
PostPosted: Sun Jul 30, 2017 3:25 pm    Post subject: Re: Electrical fuel pump issues Reply with quote
I don't think the pump runs until the engine is turning over?
kerian159
PostPosted: Sun Jul 30, 2017 6:14 pm    Post subject: Re: Electrical fuel pump issues Reply with quote
It comes on when I turn the ignition on.(normally)
Tcash
Tcash is offline
PostPosted: Sun Jul 30, 2017 10:40 pm    Post subject: Re: Electrical fuel pump issues Reply with quote
It is not supposed to. Someone wired it to the Ignition switch.
Check your fuses.
Check for loose wires at the fuel pump. Positive and ground.
Pull the hose off the inlet to the fuel pump and make sure you are getting good flow. If your not getting a bath, the filter or the gas tank are clogged.
Pull the end of the fuel hose off the engine and put the it in a bottle and test your fuel capacity.
Good luck
Tcash
kerian159
PostPosted: Mon Jul 31, 2017 5:53 am    Post subject: Re: Electrical fuel pump issues Reply with quote
Ok I may have not been clear on when I say the fuel pump is running when I turn the key. It is in the "on" position as it would be during normal operation of the vehicle and the fuel pump normally comes on I turn it a bit further for the starter to engage and it runs normally. I drove the bus a couple times over the weekend and finally had it show the same problems. Fired up normal, backed out of the driveway and started for my parents and got to the same exact spot (i'm guessing the amount of fuel in the carb bowls dictating this Smile ) and it died. When I turned the key on I could not hear the normal fuel pump thump. I'm going to be pulling it apart sometime this week, checking voltage and to see if the pump is actually pumping.
Tcash
Tcash is offline
PostPosted: Mon Jul 31, 2017 9:13 am    Post subject: Re: Electrical fuel pump issues Reply with quote
Note the 3 ignition switch positions.
The fuel pump is supposed to only come on in position #3 as the starter engages. Commonly known as the cranking position.
After the engine starts. A set of contact points in the AFM (air flow meter) close and keep the pump on.
https://www.thesamba.com/vw/archives/manuals/76bus.php
Take a look at this write up on the Fuel pump relay.
thnx to amskeptic
Double Relay Explained. . . In Color!
Good luck
Tcash
kerian159
PostPosted: Mon Jul 31, 2017 9:34 am    Post subject: Re: Electrical fuel pump issues Reply with quote
I'm thinking a PO wired it different when they took out the fuel injection Sad
busdaddy
busdaddy is offline
PostPosted: Mon Jul 31, 2017 9:50 am    Post subject: Re: Electrical fuel pump issues Reply with quote
I suspect you are on to something, sounds like carbs from this statement:
kerian159 wrote:
(i'm guessing the amount of fuel in the carb bowls dictating this Smile ) and it died. When I turned the key on I could not hear the normal fuel pump thump. .
Слава Україні!
kerian159
PostPosted: Thu Aug 03, 2017 6:32 am    Post subject: Re: Electrical fuel pump issues Reply with quote
I figured out the problem. When the PO re-wired the fuel pump they didn't do a very good job of it. It's been on my list of fixes just never got to it Sad
