Clatter Samba Member
Joined: September 24, 2003 Posts: 7527 Location: Santa Cruz
Posted: Thu Feb 04, 2021 9:26 am Post subject: Re: "Herbie"1964 beetle metal sunroof restoration/ replacing metal |
Just had to read your thread here.
Sweet build.
Glad you decided on factory colors and not another Herbie!
Might be hard work, but there's something about a black car...
Totally reminds me of mine; so many of the same parts.
That, and the White Trash Tarp Garage..
My neighbors really loved it when i had mine, sand or paint fumes and overspray blowing in the wind, compressor running late into the night...
At least your neighbors are more than six feet away like mine.
Stoked to see you taking the time to really fix things right.
Nice work.
Funny how you have the same problems i do;
A beetle, a bus and a type 3.
Now you'll NEVER get anything done.. _________________ Bus Motor Build
What’s That Noise?!? |
carcrazed Samba Member
Posted: Fri Feb 05, 2021 5:42 am Post subject: Re: "Herbie"1964 beetle metal sunroof restoration/ replacing metal |
Clatter wrote: |
Sweet build.
Nice work.
Now you'll NEVER get anything done.. |
_________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
Ceckert64 Samba Member
Joined: September 16, 2015 Posts: 1931 Location: Manitowoc, WI
Posted: Fri Feb 05, 2021 6:12 pm Post subject: Re: "Herbie"1964 beetle metal sunroof restoration/ replacing metal |
carcrazed wrote: |
Looking real nice. Little by little it gets finished. Just keep plugging away. |
Thank you! It’s slowly getting done.
Clatter wrote: |
Sweet build.
Nice work.
Thank you!
I will say the black does look really good. Accept it probably wasn’t the best choice of paint color for learning body work and painting on
Yeah, my parents weren’t thrilled with tent garages and I have two, one in out drive way and another in the woods. Our closest neighbor you can’t even see from our yard, and they all like the VWs and like them so that’s nice.
Yeah! There could be worse problems though
The other day I loaded the bug up with bus parts to take to the one shed in the woods and got stuck getting back to the shed, it took lots of trying to get it in, especially in the dark. the tires shot the boards under them backwards. The snow is fun sometimes but yet a pain _________________ 1964 sunroof Beetle Restoration "Herbie"
1972 Sierra Yellow Tin Top Westfalia Camper
“Fitz” 1971 Westfalia Poptop |
Posted: Wed Apr 28, 2021 7:24 pm Post subject: Re: "Herbie"1964 beetle metal sunroof restoration/ replacing metal |
Finally back to work, I have done nothing since the last update other than to get it out to drive it around once in a while. So I still am procrastinating on body work. But the engine needs some help so I decided to start there. The oil pickup tube isn’t bolted it so it could come out The head chipped off above the head stud and my friend is going to weld up the aluminum. The pushrod tube seals all need to be replaced. The carburetor needs new throttle shaft bushings as I can move it up in down in the shaft and gas leaks out of it So I took it for a drive and dropped the engine. It took me 4 hrs to drop the engine. It is easier on my T3. I got to see and deal with my work from when I was 12-14 years old. Most of it was bad and made life much harder I have learned a lot in the last couple years. I’m hoping I don’t find destroyed internals, everything seems good but who knows.
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Wed Apr 28, 2021 7:32 pm Post subject: Re: "Herbie"1964 beetle metal sunroof restoration/ replacing metal |
if endplay is good, it dont knock, oil preassure ok, and the lobes arent out of spec, i wouldnt even split the case.
you can meassure the cam by placing thedial indicator on the spring retainers, and reading the numbers that way.
just dont get too crazy if you dont have to
also, you can have 32 or 35.5mm SS valves turned down to size at a machine shop.
1.1 ratio rockers will help it breath a bit better. im sure you have a set of those right? _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Posted: Wed Apr 28, 2021 7:41 pm Post subject: Re: "Herbie"1964 beetle metal sunroof restoration/ replacing metal |
Chickensoup wrote: |
just dont get too crazy if you dont have to |
I will check endplay, it seems good though. Oil pressure??? It has good compression and runs well. I would love not to split the case but the nut is gone for the oil pickup tube so it flops around in the case and could fall out and that would lead to a very dry and burnt engine... I didn’t realize it wasn’t supposed to move until I got my T3 and worked on that. I kinda want to throw together the spare 1600 I have and swap it in. But BUT I have a friend that says someone he knows is selling off his VW collection and letting engines go for $25-$50 each for engines. But I also have the original engine, but it can kinda be a dumpster fire some days _________________ 1964 sunroof Beetle Restoration "Herbie"
Posted: Sun May 02, 2021 6:48 pm Post subject: Re: "Herbie"1964 beetle metal sunroof restoration/ replacing metal |
I started and ended today with the case together
I got the case split and got all of the grease and crud cleaned off. I got it reassembled, used assembly lube and sealant. The whole reason I had to split the case was because the oil pickup tube was loose and flipping around. For some reason the one in the engine doesn’t have a tab to bolt it down so I had to add one. I noticed that the tube had been hitting the cam and the cam was starting to gouge the oil pickup tube you can see in this pic the nick
Case getting cleaned.
I messed up and put the cam plug in backwards. After much waffling I decided to fix it. Here is backwards
I got the case together and torqued it down, the 6 main bolts to 25ft pounds and the others to 14fl lbs.
When I was putting the oil cooler on, one of the stud for it snapped off and *ping* the washer falls into my freshly assembled crank case :fist: I tried fishing it out with a magnet to no avail. So I put it in the black bag of shame I hope you learned your lesson
(The bag is actually to make sure nothing else falls in )
Aiden _________________ 1964 sunroof Beetle Restoration "Herbie"
Posted: Sat May 15, 2021 7:53 pm Post subject: Re: "Herbie"1964 beetle metal sunroof restoration/ replacing metal |
This is getting old. my notifications nearly never works for your threads.
other than that i think you will be surprised at how you car will look with fenders. do you have the bolt and fender seals yet? _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Sat May 15, 2021 8:28 pm Post subject: Re: "Herbie"1964 beetle metal sunroof restoration/ replacing metal |
im not sure you would look very good with fenders _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Sat May 22, 2021 8:52 pm Post subject: Re: "Herbie"1964 beetle metal sunroof restoration/ replacing metal |
noice mate! get a video of it running for us! we like quite valvetrains not loud eating itself to death noises my engine makes
also, why are you always up so late on the samba? or why am i always up so late on the samba? _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Sat May 22, 2021 9:10 pm Post subject: Re: "Herbie"1964 beetle metal sunroof restoration/ replacing metal |
also, why are you always up so late on the samba? or why am i always up so late on the samba? |
Hopefully it doesn’t make weird noises... I’m not changing many parts.
Because I was pulling a bus out of the woods today, then going doing VW stuff with VW people. And then kept working on this VW engine. Then had to shower the VW grease off of me so I could post on my VW thread I guess VWs are a time suck that keeps pulling you in _________________ 1964 sunroof Beetle Restoration "Herbie"
calvinater Samba Member
Posted: Tue Jun 01, 2021 3:02 am Post subject: Re: "Herbie"1964 beetle metal sunroof restoration/ replacing metal |
Paint those fenders Bordeaux red. _________________ "Albatross"! |
