brokevwguy Samba Member
Joined: November 03, 2012 Posts: 269 Location: Upstate New York
Posted: Sat Aug 05, 2017 7:21 am Post subject: 1961 Bus roof needs replacing |
I just bought my bus and I have a roof that I feel is to far gone to be fixed. Do they make full roof skins? If the do who sells them. Also does anyone know of a thread that shows a roof replacement being done. I looked on youtube as well with no luck.
_________________ Be happy with what you have, you will save allot of money that way....
1961 Standard |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Sat Aug 05, 2017 3:03 pm Post subject: Re: 1961 Bus roof needs replacing |
I hope you are an established intermediate welder or better because it will be quite a burden to learn metal forming skills at the same time.
I don't have the resources for a bus project but when I looked into it a splitwindow that needed body panels welded on plus a full restoration otherwise ,started at $3,000 and up.
More critical bus panels are available verses a type 1 but if the roof is that bad the rest of the bus would have to make it worth it. I have never seen roof sections new. I think you need at least another Parts Bus for your project.
The only other advice I can offer is for you to learn how to use a English/forming wheel. I think a HF model is under $500 complete. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Ran When Parked Samba Member
Joined: September 26, 2013 Posts: 781 Location: Birmingham, AL
Posted: Sat Aug 05, 2017 5:47 pm Post subject: Re: 1961 Bus roof needs replacing |
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=20
There are some used ones in the classifieds and a few ads for drip rail sections. Also, at least one tread on roof replacement is around here somewhere.
I need to do one but I'm lazy. I bought the entire roof clip from a member here for $400 about a year and a half ago.
If you do it, please start a thread and name it where the next guy can easily find it via search. |
Posted: Sat Aug 05, 2017 7:11 pm Post subject: Re: 1961 Bus roof needs replacing |
Great find! If you go through with the BBT roof please report back on how the cost breaks down and where it shipped from. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Z Samba Member
Joined: June 15, 2003 Posts: 2517 Location: galveston, tx
Posted: Sat Aug 05, 2017 7:37 pm Post subject: Re: 1961 Bus roof needs replacing |
This thread was referenced here just a couple days ago, I think. They are doing a full roof panel, and IIRC, its the BBT ones. Not sure how much detail they go into.
http://www.retro-resto.co.uk/?p=151 |
Posted: Sun Aug 06, 2017 5:31 am Post subject: Re: 1961 Bus roof needs replacing |
I sent BBT a message asking for info on the roof. It looks like they do not ship them though. I will report back with any further info. I might have to do like you did and buy a donor roof. _________________ Be happy with what you have, you will save allot of money that way....
1961 Standard |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Sun Aug 06, 2017 7:07 am Post subject: Re: 1961 Bus roof needs replacing |
Welcome to the club! I hope your welding skills are up to par. They will be when you are done. If you expect the worst you will likely be rewarded with something beyond your expectations. Here is my journey so far. The fun begins with the roof about halfway down-
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=40
The work is not impossible. Parts are relatively easy to find and sometimes they are affordable. I think the most important lesson I am learning is to ask for help when you are stumped. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Sun Aug 06, 2017 7:30 am Post subject: Re: 1961 Bus roof needs replacing |
Fabricator John put one on my late bay and its a challenge to find the marks.
All started with a 68 carcass found in Yuma for $250 plus $100 for the u-haul.
Then he cut off the old roof and built fillers for the windows - so they would fit back on. and welded till it all fit. minimum of bondo and som old headliner in side on the verticals-
_________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Braukuche Samba Member
Posted: Sun Aug 06, 2017 8:57 am Post subject: Re: 1961 Bus roof needs replacing |
The roof is going to be the least of you worries, the rot is likely to go all the way down the pillars and eat up all the holllow framing around the inside of the roof. A skin would do you no good. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24736 Location: Olympia Wash Rinse & Repeat
Posted: Sun Aug 06, 2017 9:25 am Post subject: Re: 1961 Bus roof needs replacing |
Braukuche wrote: |
The roof is going to be the least of you worries, the rot is likely to go all the way down the pillars and eat up all the holllow framing around the inside of the roof. A skin would do you no good. |
Got to agree. Procured a roof for our SO-34, that afterward found there had been a very small leak in the left front of the roof. This lead to some rust in the roof, but most of the damage in the upper frame over the LF door. Had to find another smaller donor piece that had the door frame....
https://www.thesamba.com/vw/forum/viewtopic.php?t=462164&highlight=wounded+westie _________________ In Stereo, Where Available! |
Posted: Sun Aug 06, 2017 9:47 am Post subject: Re: 1961 Bus roof needs replacing |
Eric&Barb wrote: |
Braukuche wrote: |
Got to agree. Procured a roof for our SO-34, that afterward found there had been a very small leak in the left front of the donor roof. This lead to some rust in the roof, but most of the damage in the upper frame over the LF door. Had to find another smaller donor piece that had the door frame....
https://www.thesamba.com/vw/forum/viewtopic.php?t=462164&highlight=wounded+westie |
Jacco Verveer Samba Member
Posted: Sun Aug 06, 2017 11:40 am Post subject: Re: 1961 Bus roof needs replacing |
Good to know they make roofs
But when a roof is rotten almost always the "bare" metal is very rusty airbox etc
Did a swap but that was a small roof
The bottom was in fair condition but only because isolation soaked up all the moister
finding good donor metal is almost impossible now
Posted: Sat Aug 12, 2017 4:59 pm Post subject: Re: 1961 Bus roof needs replacing |
Does anyone know what roof years will fit on my 61? _________________ Be happy with what you have, you will save allot of money that way....
1961 Standard |
Posted: Sat Aug 12, 2017 5:46 pm Post subject: Re: 1961 Bus roof needs replacing |
brokevwguy wrote: |
Does anyone know what roof years will fit on my 61? |
Later 55 thru 67. _________________ In Stereo, Where Available! |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Sun Aug 13, 2017 6:15 am Post subject: Re: 1961 Bus roof needs replacing |
We did the roof replacement on a bay a few months ago for my one tech. Did it in the parking lot of another shop with minimal tools (the other shop was locked and you would laugh at what we did - than God I brought my sawzall) Did like the one set of pics, but cut about 4" down each of the pillars except at the rear. We cut at the body line at the crease near the bottom of the windows back there. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Sun Aug 13, 2017 6:37 am Post subject: Re: 1961 Bus roof needs replacing |
Did BBT get back to you yet? Is their interpreter on vacation? _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Mon Aug 14, 2017 7:34 pm Post subject: Re: 1961 Bus roof needs replacing |
Eric&Barb wrote: |
brokevwguy wrote: |
Later 55 thru 67. |
Didn't the rear corner profile change slightly with the swap to the wider rear hatch for the 64 model year? Not talking about the profile at the rain gutter, but the actual roof compound curve at the rear corners. _________________ nothing |
Posted: Tue Aug 15, 2017 6:43 am Post subject: Re: 1961 Bus roof needs replacing |
Looks like it did change at end of 1963 model year.
Still the later roof with the slight change will fit the earlier bus.
More of the parts manual here:
http://www.oacdp.org/ _________________ In Stereo, Where Available! |
Posted: Sun Aug 20, 2017 8:29 am Post subject: Re: 1961 Bus roof needs replacing |
It's been 2 weeks. Any word from BBT yet? _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Posted: Tue Aug 22, 2017 6:01 pm Post subject: Re: 1961 Bus roof needs replacing |
They have sent me messages saying they will have sales get in contact with me. Have not heard from them though. _________________ Be happy with what you have, you will save allot of money that way....
1961 Standard |
