dschwerdt Samba Member
Joined: November 03, 2005 Posts: 29 Location: Upstate New York
Posted: Sat Aug 05, 2017 2:22 pm Post subject: Split trans case CHASSIS |
Does anyone have pictures of the difference for early vs late(non
split case) chassis? I don't know what I have right now. Can't trust the chassis serial number! I have a split case rebuilt and ready to install and don't really know if the frame or current trans has been modified.
Thanks in advance for the help. _________________ Corvair powered ManxClone |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Sat Aug 05, 2017 2:52 pm Post subject: Re: Split trans case CHASSIS |
The only difference on the chassis would be the front transaxle mount which could be solved by changing the transaxle nosecone to fit the type of mount on your chassis. |
Posted: Sat Aug 05, 2017 5:53 pm Post subject: Re: Split trans case CHASSIS |
Thanks for the advice. I was just wondering if I could get some idea of what I was getting into before I start tearing things apart. It may be as simple as changing the front mount or more involved with changing the nosecone and hockey stick. _________________ Corvair powered ManxClone |
Posted: Sat Aug 05, 2017 6:00 pm Post subject: Re: Split trans case CHASSIS |
Changing the front mount is a welding job. The nose cone just bolts on.
If its an option, I would weld on a late model mount.
However, I'd also run the latest model transaxle I could find with standard upgrades, but at least one with full synchro.
If I was running a Corvair engine on a VW swingaxle transaxle(as your signature block mentions), it would be the last year transaxle with two side covers or a reinforced White Rhino case. I'd also install a transaxle mid-mount.
https://www.thesamba.com/vw/classifieds/detail.php?id=1131801 |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20377 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Aug 06, 2017 6:31 am Post subject: Re: Split trans case CHASSIS |
If you have this style mount on chassis (61 to 69 (maybe 70)) its most popular and easiest to work with..
Uses this style rubber mount...
IF you have this style rubber mount it is a 70 (mabe 71) and later... No so good, but will work...
EVfun Samba Member
Posted: Sun Aug 06, 2017 8:19 am Post subject: Re: Split trans case CHASSIS |
Hey Dale, do you have good pictures of the '59 down front frame mount and rubber mount? At a glance they look similar, but when on a chassis they look quite different.
The '61 to ?? mount sits a bit below the torsion tube, you can see that in the far side of mount that welds to the chassis. The ?? to '59 front mount comes strait out from the rear torsion housing. The '60 only is a couple of studs coming out of the torsion housing.
There are other hints as to what year the chassis is. Are the rear shock mounts strait or twisted to about a 45 degree angle? Does the chassis have pads in the rear shock towers for the rubber rear suspension stop? _________________
Wildthings wrote: |
Posted: Sun Aug 06, 2017 8:21 pm Post subject: Re: Split trans case CHASSIS |
I believe this is 60 only
This is 57
Posted: Mon Aug 07, 2017 6:54 am Post subject: Re: Split trans case CHASSIS |
EVfun wrote: |
There are other hints as to what year the chassis is. Are the rear shock mounts strait or twisted to about a 45 degree angle? Does the chassis have pads in the rear shock towers for the rubber rear suspension stop? |
Cant help, all my chassies and ones I have worked on have been 61 and later...
joescoolcustoms Samba Member
Posted: Mon Aug 07, 2017 8:22 am Post subject: Re: Split trans case CHASSIS |
Dale M. wrote: |
Dale |
The mounts run as follows:
- up to 1959
1960
1961 - 1972
1973 - 1979
The last mount design is the strongest for the nose cone in stock form. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Mon Aug 07, 2017 2:24 pm Post subject: Re: Split trans case CHASSIS |
[quote="joescoolcustoms"]
Dale M. wrote: |
The last mount design is the strongest for the nose cone in stock form. |
Joe, You ever seen a prefabbed 71 and later mount which can be welded to a torsion housing? |
BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1104 Location: North East Pennsylvania
Posted: Mon Aug 07, 2017 3:24 pm Post subject: Re: Split trans case CHASSIS |
[quote="BL3Manx"]
joescoolcustoms wrote: |
Dale M. wrote: |
'71 and '72 are the same as '70 and earlier. Do you mean '73 and later?
If you refer to '73 and later, yes I have. Been a few years and I have not searched for them, just cut them off of a bad chassis and grafted them on where I need them. That stock rubber mount of the last design will not separate like the earlier mount will, no matter the beating it is given. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
glassbuggy Samba Member
Posted: Tue Aug 08, 2017 3:57 am Post subject: Re: Split trans case CHASSIS |
I had a friend with a Steven's Sandbuggy in high school ( around 1983 ) his buggy was based on a 1960. It sat at a local garage for weeks because theycould not locate a transmission for him. The '60 had a one year mount. |
Posted: Tue Aug 08, 2017 5:25 am Post subject: Re: Split trans case CHASSIS |
This is why I come here! Those pictures are exactly what I was looking for. Also the dates will help me dating my chassis. (Unless the mount was replaced!) Thanks again. _________________ Corvair powered ManxClone |
Posted: Wed Aug 09, 2017 6:02 am Post subject: Re: Split trans case CHASSIS |
[quote="joescoolcustoms"][quote="BL3Manx"]
Dale M. wrote: |
If you refer to '73 and later, yes I have. Been a few years and I have not searched for them, just cut them off of a bad chassis and grafted them on where I need them. That stock rubber mount of the last design will not separate like the earlier mount will, no matter the beating it is given. |
Yes, I meant 73 and later, thanks |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 851 Location: South Florida
Posted: Wed Aug 09, 2017 9:29 am Post subject: Re: Split trans case CHASSIS |
That mount's so rare, I can't even believe you found its picture! Any idea of where or how I could get ahold of one like that with good rubber in it?
Also, what do you guys think about the EMPI 9520 solid front mount? My feeling is that it'd put unnecessary stress on tranny nose cone. So, what do you think about urethane?
Posted: Wed Aug 09, 2017 4:56 pm Post subject: Re: Split trans case CHASSIS |
MrGoodtunes wrote: |
https://www.thesamba.com/vw/classifieds/detail.php?id=2064184
Also, what do you guys think about the EMPI 9520 solid front mount? My feeling is that it'd put unnecessary stress on tranny nose cone. So, what do you think about urethane? |
Urethane usually breaks fairly quickly
Solid transmit noise. |
Posted: Wed Aug 09, 2017 5:00 pm Post subject: Re: Split trans case CHASSIS |
That mount's so rare, I can't even believe you found its picture! Any idea of where or how I could get ahold of one like that with good rubber in it? |
Here
CB Perf Rhino mounts have a good reputation but mid-mounts are best
Posted: Wed Aug 09, 2017 5:58 pm Post subject: Re: Split trans case CHASSIS |
Not in favor of poly mounts ... Only place they seem to work is suspension bushings where they are supported on full circumference, absolutely do no use them on shift couplers and steering couplers...
With solid mounts I usually use front trans strap on transaxle case to relieve some of the cantilever pressure on nose cone..
(image unscrupulously stolen from GOOGLE Images)
fiaroadster Samba Member
Joined: September 29, 2015 Posts: 24 Location: BAKERSFIELD CA
Posted: Wed Aug 09, 2017 9:58 pm Post subject: Re: Split trans case CHASSIS |
Please tell me you are not running a Corvair thru a split case trans. |
