crank pulley nut
[email protected]
waugamans@aol.com is offline
PostPosted: Sat Aug 05, 2017 6:02 pm    Post subject: crank pulley nut Reply with quote
Just curious if there is a special procedure to remove the crank pulley nut? I want to install the hand crank nut, which I have, without removing the belt if thats possible. Been so long since I have pulled apart an engine, 70's, I just don't want to screw something up. Also, what size wrench will I need, I have a 24mm, and it's not big enough.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Aug 05, 2017 6:06 pm    Post subject: Re: crank pulley nut Reply with quote
30mm
And you don't need to remove the belt.
Glenn
iRide4Sue.org Please Donate to fight Cancer. $31,000 raised in 2018, hoping for the same in 2019
mondshine
mondshine is offline
PostPosted: Sat Aug 05, 2017 6:12 pm    Post subject: Re: crank pulley nut Reply with quote
The stock crank pulley nut is removed with a 30mm wrench. If you already have the rear tin for the hand crank nut (with the hole in it), you can use a 30mm socket with an extension that passes to outside the rear bumper with your ratchet behind the rear bumper.
Remove the nut with the transmission in gear, brake on.
Good luck, Mondshine
[email protected]
PostPosted: Sat Aug 05, 2017 7:19 pm    Post subject: Re: crank pulley nut Reply with quote
Thanks guys, the tin with the hole was in the car when I bought it, just need to get the 30mm wrench. I know it was discussed this year, but what was the torque on the nut? I think it was 36-38 ft. lbs.
[email protected]
PostPosted: Sat Aug 05, 2017 7:24 pm    Post subject: Re: crank pulley nut Reply with quote
I found an old post answered by Al Acapulco that the torque is 25-36 ft. lbs. thanks.
[email protected]
PostPosted: Mon Aug 07, 2017 6:44 pm    Post subject: Re: crank pulley nut Reply with quote
Well I just did it, started awesome on 2nd crank. It's 30mm to remove the normal bolt at the crank, 36mm to torque the hand start cog.[/img][youtube][vimeo][/vimeo][/youtube]
[email protected]
PostPosted: Mon Aug 07, 2017 6:46 pm    Post subject: Re: crank pulley nut Reply with quote
I tried to include a video, did not work, will try again later.
Captain Spalding
Captain Spalding is offline
PostPosted: Mon Aug 07, 2017 11:07 pm    Post subject: Re: crank pulley nut Reply with quote
For those of us with an alternator, and hand crank setup is basically useless, right? I mean, if the point of a hand crank is to be able to start the car with a dead battery . . .
Thing7
Thing7 is offline
PostPosted: Tue Aug 08, 2017 8:03 am    Post subject: Re: crank pulley nut Reply with quote
I have a hand crank nut but unfortunately we could not get the old crank nut off...even with a breaker bar Sad
doublecanister
doublecanister is offline
PostPosted: Tue Aug 08, 2017 10:00 am    Post subject: Re: crank pulley nut Reply with quote
Hey Thing7,
dang yall couldn't get the old one off? That sucks!
Mine came off fairly easy, I didn't have a breaker bar but my torque wrench is long enough it worked like one.
I wonder if you used a impact wrench gun on it would that work?
And Captain;
Even with a alternator, if the battery is dead enough it wont crank the starter, (using the hand crank) the battery should have enough power to spark the plugs, just like doing a "push start" I'd think.
T
73'- Thing
66' -Mustang GT- Fastback
51'- Ford F1 pickup Flathead V8
[email protected]
PostPosted: Tue Aug 08, 2017 11:32 am    Post subject: Re: crank pulley nut Reply with quote
I tend to agree with doublecanister, if the battery is working, then what's the point of the hand crank? My nut came off fairly easy, and it has never been off since the motor was rebuilt by the PO in 1996. I know for sure that the PO was an absolute fanatic for proper torques, as am I.
limon
limon is offline
PostPosted: Tue Aug 08, 2017 4:57 pm    Post subject: Re: crank pulley nut Reply with quote
Not to hijack the thread,but...
I just installed a stock size pulley and sand seal from Empi (torque spec is 33 ft.lb.,). Anyhow, I used the longer bolt and it's hanging out about a 16th of an inch when fully torqued.
I didn't try the old bolt and flat washer yet - anyone else seen this problem?
Thing7
Thing7 is offline
PostPosted: Wed Aug 09, 2017 12:32 pm    Post subject: Re: crank pulley nut Reply with quote
doublecanister wrote:
Hey Thing7,
And Captain;
T
Unfortunately it wouldn't break loose. The guy that tried told me if the engine comes out he could try the impact gun on it. Kind of bummed because I wanted to install that hand crank nut
limon
limon is offline
PostPosted: Wed Aug 09, 2017 4:29 pm    Post subject: Re: crank pulley nut Reply with quote
Maybe put the socket on the bolt, and then pass an extension through the hole that's in the bumper for the hand crank and hit it with the impact gun.
Good Luck
Kubel 74
Kubel 74 is offline
PostPosted: Wed Aug 09, 2017 11:23 pm    Post subject: Re: crank pulley nut Reply with quote
Could you please post a picture of the tin with the hole in it?
limon
limon is offline
PostPosted: Thu Aug 10, 2017 10:55 am    Post subject: Re: crank pulley nut Reply with quote
I have the hole in my bumper, but not the "Tin". You can see in the picture I posted earlier that I removed the back piece of tin (mine only had 4 screws) - a lot easier then pulling the engine.
Kubel 74
Kubel 74 is offline
PostPosted: Thu Aug 10, 2017 12:17 pm    Post subject: Re: crank pulley nut Reply with quote
So after you get the hand crank nut on, do you plan on putting the tin back on?
limon
limon is offline
PostPosted: Thu Aug 10, 2017 1:15 pm    Post subject: Re: crank pulley nut Reply with quote
Kubel 74,
I was just adding my 2 cents to Thing7's problem with the stuck pulley bolt.
I don't have a bolt that accepts the hand crank installed, so when I reinstall my tin it won't matter that it blocks the hole.
Sorry for the confusion...
doublecanister
PostPosted: Wed Aug 16, 2017 8:19 pm    Post subject: Re: crank pulley nut Reply with quote
Hey Kubel 74
this link has some tin photos for you.
That plug I made for mine is working great so far, it hasn't popped out on its own yet. Very Happy
T
73'- Thing
