chamilka Samba Member
Joined: March 18, 2006 Posts: 197 Location: San Deigo
Posted: Sat Aug 05, 2017 10:27 pm Post subject: 71 vw bus: rear bumper brackets qn - UPDATE!! So mad!! |
I bought two new aftermarket rear bumper brackets set for my 1971 VW bus. It seems they have given me two rear right side ones. I also have one original rear bracket with two hoops which came as a spare part so I assume it is for the 71.
Q1 : do 67-72 have the same brackets?
Q2: the one with two hoops, is it for left or right?
Thank you in advance
aeromech Samba Member
Joined: January 24, 2006 Posts: 16922 Location: San Diego, California
Posted: Sat Aug 05, 2017 11:45 pm Post subject: Re: 71 vw bus: rear bumper brackets qn |
Just today I installed an aftermarket rear bumper with aftermarket brackets on a 1967 split bus. I had to order the mount brackets (which are both the same for left and right) because the later bay brackets I already had were different. In your picture the top looks like a bay brackets and the bottom two look like what I installed on the 1967. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Angus II Samba Member
Joined: June 01, 2016 Posts: 706 Location: Mammoth Lakes Ca. 93546
Posted: Sun Aug 06, 2017 6:10 am Post subject: Re: 71 vw bus: rear bumper brackets qn |
Hello, The original one with the two hoops on it, goes on the right side. It's that way on my 71. |
babysnakes Samba Member
Posted: Sun Aug 06, 2017 7:04 am Post subject: Re: 71 vw bus: rear bumper brackets qn |
211-707-336/A is the right side, 211-707-335/C is the left side. |
Posted: Sun Aug 06, 2017 9:10 am Post subject: Re: 71 vw bus: rear bumper brackets qn |
Thanks All
That makes sense, looks like all three are for the right side hence not fitting to the bumper well. I will order the left side.
Thank you all again |
Posted: Wed Aug 16, 2017 10:21 pm Post subject: Re: 71 vw bus: rear bumper brackets qn - UPDATE!! So mad!! |
I figured out why the bumper brackets don’t fit – I have been supplied with a wrong bumper.
Per the link below: bumper hole distance is different between 68-71 & 72.
https://www.thesamba.com/vw/forum/viewtopic.php?t=609990
The bumper that Jbugs had given me is defiantly for 72 unfortunately, the bumper holes measure 38.5 and 46.5 . I had the bumper painted in pastel white as a part of the restoration. Now I am stuck with a painted bumper that will not fit. I called Jbugs, they looked at my old invoice, the invoice has the correct item (211707311F - VW Rear Bumper, Type 2 Bus models 1968-71) but when they gave be the bumper from the warehouse they must have given the 72. I actually collected it personally from the shop.
I guess I can drill some new holes, but then the bumper will end up with extra holes which can be unsightly.
Another question: Do I need to buy the splash pans in order to be able to mount rear bumper to the L/R corners. |
Joined: January 01, 2007 Posts: 16802 Location: sticksville, ct.
Posted: Thu Aug 17, 2017 4:44 am Post subject: Re: 71 vw bus: rear bumper brackets qn - UPDATE!! So mad!! |
Drill new holes weld up old ones repaint and move on....sucks you got the wrong one but its easily solved _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Manfred58sc Samba Member
Posted: Thu Aug 17, 2017 5:30 am Post subject: Re: 71 vw bus: rear bumper brackets qn - UPDATE!! So mad!! |
You need splash pans to avoid "flop" at the end of the bumper. Once you re-drill the holes the 72 bumper will fit fine. The aftermarket bumpers are on the thin side so tack in a strip on the back of the un-needed holes before you fill in on the front. I would also clamp in a heat sink before welding to avoid distortion. _________________ Fat chick owner/operator |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Aug 17, 2017 7:21 am Post subject: Re: 71 vw bus: rear bumper brackets qn - UPDATE!! So mad!! |
Or find some pretty chrome or rubber plugs for the bonus holes, maybe even a sticker?
X2 on needing the pans, the ends flap up and down without them. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Thu Aug 17, 2017 7:27 am Post subject: Re: 71 vw bus: rear bumper brackets qn - UPDATE!! So mad!! |
busdaddy wrote: |
X2 on needing the pans, the ends flap up and down without them. |
or some overriders? |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5778 Location: Los Alamos, New Mexico
Posted: Thu Aug 17, 2017 7:39 am Post subject: Re: 71 vw bus: rear bumper brackets qn - UPDATE!! So mad!! |
Or sell the '72 bumper (it is a one-year-only part, so some '72 restorer would want it I should think) and get the proper one. Maybe the seller would do you a solid since they screwed this up in the first place. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Tcash Samba Member
Posted: Thu Aug 17, 2017 9:51 am Post subject: Re: 71 vw bus: rear bumper brackets qn - UPDATE!! So mad!! |
X2 ^^^^^^
68-71 Bumper on top, 72 on bottom
Tcash |
SGKent Samba Member
Posted: Thu Aug 17, 2017 2:05 pm Post subject: Re: 71 vw bus: rear bumper brackets qn - UPDATE!! So mad!! |
I think that 1972 bumper is a rarity. There have been threads where folks are looking for good ones and can't find them. You may be able to make money on the deal by selling it rather than drilling it. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Aug 17, 2017 2:14 pm Post subject: Re: 71 vw bus: rear bumper brackets qn - UPDATE!! So mad!! |
he bought this from J-Bugs....so it's not like he's sitting on a gold mine here... _________________
Jake Raby wrote: |
Brian wrote: |
djdh68dlux Samba Member
Joined: February 24, 2005 Posts: 770 Location: I.E., SoCal
Posted: Thu Aug 17, 2017 2:33 pm Post subject: Re: 71 vw bus: rear bumper brackets qn - UPDATE!! So mad!! |
SGKent wrote: |
I think that 1972 bumper is a rarity. There have been threads where folks are looking for good ones and can't find them. You may be able to make money on the deal by selling it rather than drilling it. |
They may be somewhat rare, but apparently not in high demand. I've had a decent one on sale here for over a month. Haven't got one email for it yet. Maybe I'm overpriced, or maybe it's because I put "local pick up only". I don't know. _________________ 1968 Deluxe "Clipper L" Type 2
Looking for a VW club in Southern California? Check out Inland Valley Volkswagens: www.ivvw.org |
SGKent Samba Member
Posted: Thu Aug 17, 2017 2:37 pm Post subject: Re: 71 vw bus: rear bumper brackets qn - UPDATE!! So mad!! |
djdh68dlux wrote: |
SGKent wrote: |
They may be somewhat rare, but apparently not in high demand. I've had a decent one on sale here for over a month. Haven't got one email for it yet. Maybe I'm overpriced, or maybe it's because I put "local pick up only". I don't know. |
local pickup only pretty much guarantees that if there is no 1972 bus that needs a bumper in your area you have no buyers. You need to get an account with Golden State Overnight. Really reasonable trucking in CA, AZ and I think OR now too. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Aug 18, 2017 12:23 am Post subject: Re: 71 vw bus: rear bumper brackets qn - UPDATE!! So mad!! |
Thanks for all your comments. This project has become very expensive as I try to do everything right, got the entire bus rust free/proof, got it painted professionally, pretty much nuts and bold restoration.
It sucks that I have to get a new bumper and send it for painting etc. again.
thanks all, its good to have a place to vent |
chabanais Samba Member
Posted: Fri Aug 18, 2017 3:51 pm Post subject: Re: 71 vw bus: rear bumper brackets qn - UPDATE!! So mad!! |
I ended up with a 72 Bumper and didn't know it.
These are measurements I took at the time:
_________________ "I spud therefore I yam." |
Posted: Fri Aug 18, 2017 7:24 pm Post subject: Re: 71 vw bus: rear bumper brackets qn - UPDATE!! So mad!! |
SGKent wrote: |
local pickup only pretty much guarantees that if there is no 1972 bus that needs a bumper in your area you have no buyers. You need to get an account with Golden State Overnight. Really reasonable trucking in CA, AZ and I think OR now too. |
Eh, you're probably right. I figured since my area was Southern California someone with a 72 would materialize. You know us SoCal people... we think the world revolves around us _________________ 1968 Deluxe "Clipper L" Type 2
Posted: Sat Aug 19, 2017 11:32 pm Post subject: Re: 71 vw bus: rear bumper brackets qn - UPDATE!! So mad!! |
chabanais wrote: |
Thank you, yes I looked at your post and that how I knew I got the wrong one. |
