Tram Samba Socialist
Joined: May 02, 2003 Posts: 22727 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sun Aug 06, 2017 7:51 pm Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
SGKent wrote: |
Colin is in Eureka CA and was in Portland a couple days ago. I doubt if you can convince him to come back to Oregon unless you are not far from Eureka CA but it might be your best bet to try considering this sounds like your first rodeo with a bus. NY is a long way away. He'll charge you what it would cost to take it to a shop but he knows older buses - in fact he is driving his 1970 on this trip, but what he would charge you is less than a 3000 mile tow. Good luck.
Colin - https://www.thesamba.com/vw/forum/memberlist.php |
This ain't my first rodeo with a bus. My first rodeo with a bus was around 1975.
All we need here is to find out WTF is causing the slop issue, and I've learned that 95% of the WTF problems I've never seen before on a VW are due to replacement parts, and the other 5% are due to shit breaking that never used to due to the age of these cars now. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
neena Samba Member
Joined: September 10, 2010 Posts: 581 Location: Brooklyn, NY
Posted: Sun Aug 06, 2017 8:02 pm Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
skills@eurocarsplus wrote: |
the nut not pinching everything together is an issue. it could be the nut "snout" on the drum is incorrect, or the inner "snout" isn't deep enough.
basically, like the pipe idea the drum is nothing more than a spacer to pinch the bearing stack together...you just need to find where the deficit is...either the drum of the aftermarket spacer. sadly, you can't snake the big girl spacer out without removing the bearing.....and getting all covered in poop again |
C'mon Tram, you heard the man...Time to get covered in poop again. We need to get the heck outta OR! |
Posted: Sun Aug 06, 2017 8:09 pm Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
This will not solve all your problems but get hold of some Vanagon nuts and then use the Vanagon torque spec. |
Posted: Sun Aug 06, 2017 8:51 pm Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
neena wrote: |
That ain't poop... that's tar, baby!!!
Bryan67 wrote: |
Posted: Sun Aug 06, 2017 8:52 pm Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
Wildthings wrote: |
Yep, genuine 1 piece Vanagon nuts are comin... _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Tcash Samba Member
Posted: Sun Aug 06, 2017 10:15 pm Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
As suggested switch the drums from side to side. If the problem moves. Shim out Hub/Drum. Install Alternator/Generator pulley shims 111 903 131 A, between the Hub/Drum and the Wheel bearing or Spacer ring. Shims are 0.5mm thick. Adjust accordingly. |
Posted: Sun Aug 06, 2017 10:27 pm Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
Tcash wrote: |
Interesting. I often wondered if generator shims were viable here but figured not because of the torque pressure. This is actually safe? No, I'm not being sarcastic here- I'm just concerned that I am sending a Bus with two nice people in it from Oregon to NYC with a repair I've never heard of in my 42 years in the VW Gulag.
But humor me just for a minute here. Don't forget that one of my issues on the "bad" side is that the nut only snugs on far enough for me to use a thinner cotter key, e.g., the nut doesn't seem to go on the "bad" side as far as it does on the "good" side.
Wouldn't adding shims under the drum make this issue even worse?
Unless I'm just not thinking clearly, the nut not going on as far would tell me that the spacers are already *somehow magically* too long, correct?
I just want you to be clear about the exact problem.
Possibly the shim(s) will take out the play and the Vanagon nut will allow the correct cotter key to be used, I don't know. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Joined: January 01, 2007 Posts: 16878 Location: sticksville, ct.
Posted: Mon Aug 07, 2017 4:45 am Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
I think generator shims will smash flat in short order, but may be a good way to make a shimstack you can measure and have a real 1 piece shim made... _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Joined: August 31, 2013 Posts: 12854 Location: North Carolina
Posted: Mon Aug 07, 2017 6:05 am Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
Tram wrote: |
Tcash wrote: |
Possibly the shim(s) will take out the play and the Vanagon nut will allow the correct cotter key to be used, I don't know. |
Was the stub axle a new aftermarket piece or a used one from a different year bus? Do you still have the old stub axle? If not, you may need to remove the other side to see if there was a difference in the collar length & diameter between the old & new. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Mon Aug 07, 2017 7:25 am Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
Scratching head and trying to picture what we are all talking about here..
Something I was taught years ago,
Was that the inner spacer, (the cylinder-shaped spacer that presses against the inner races,
Rides on the OD of the stub), was specific to any given trailing arm.
There was supposedly enough manufacturing tolerance in the arms that the spacers had to be fitted.
You will see different paint markings on them,
And they will have different length measurements..
Perhaps you have tolerances stacking up with parts from different vehicles?
I would also be measuring everything six ways from Sunday..
How deep is the splined area? a.k.a. how long are the splines?
Something has an OD too big, and is hanging against something it's not supposed to?
Have to start looking at these things like a machinist now instead of a mechanic, unfortunately.
Find out where the flunky messed up in making his parts that day...
Maybe just best to wait until Colin makes it there..! _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Mon Aug 07, 2017 10:34 am Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
TDCTDI wrote: |
Tram wrote: |
Tcash wrote: |
Was the stub axle a new aftermarket piece or a used one from a different year bus? Do you still have the old stub axle? If not, you may need to remove the other side to see if there was a difference in the collar length & diameter between the old & new. |
It's a used stub. I still have the old one and am planning on comparing all surfaces with a caliper. I already pulled it back out to do a visual comparison new v old but just on general length and they are identical. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Mon Aug 07, 2017 10:51 am Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
Clatter wrote: |
Maybe just best to wait until Colin makes it there..! |
As it winds up, the spacers actually ARE original and were not replaced, and they are in top condition. I got cornfused because I had the Disciple (aka the Go- Rilla) put the back end together while I was working on other things. Since all I need to do to get to work is walk out my back door to the shop, I usually have him pick up parts on his way in, and in talking to my parts guy those spacers "haven't been available for 20 years" so the originals are still there. All the bearings, seals, and drum are new, though.
So... my first suspect is the stub. However, I am basing this solely on the fact that after I replaced the stub the cotter key that came out would no longer go in- that's when I needed the next thinner one.
I'm going to do a bunch of measuring from the new used stub to the old one and see if I can find anything. Hang tight.
BTW, Mr. C. ... those seat releases you were whining about over yonder have been done for quite awhile. When I get done with this tar baby I need you to PM me an address though, so I can dig them out and send them. I ain't the Amazing Kreskin, yaknow. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Mon Aug 07, 2017 10:53 am Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
If it all measures correctly, the only thing I can think of is severely loose tolerances in the bearings, with the stub out, check side play in the bearings. if the balls used were smaller than the races needed then this would cause excessive side to side & lateral play, which kinda sounds like what you're dealing with.
Were the outer races loose in the housing, or the stub loose in the inner? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
SGKent Samba Member
Posted: Mon Aug 07, 2017 10:58 am Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
Tram - I did not know you were in Oregon working on this bus. Had I realized it was you doing the work, the appropriate response would have been to send you original German parts. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
Posted: Mon Aug 07, 2017 11:01 am Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
TDCTDI wrote: |
Were the outer races loose in the housing, or the stub loose in the inner? |
Nein und nein.
Some people, including my longtime trustworthy parts guy, tell me that these bearings should have "float". Not only does this go against my experience, the "good" side is tight with zero play as I remember it should be. I also peeked at Amskeptic's site, and he said that play= bad bearings which is how I remember it too. All the British forum Bay guys say end play is "normal" but all they seem to be concerned with is passing MOT, not actual 3000 mile treks in 90 degree- plus heat.
Besides, this ain't "float". It's more like full steam ahead.
I'm going to go beat the vacuum where my brain used to be against it some more then I'll report back, with pics and video if necessary.
Is there a snowball's chance that when I drove the new used stub in that I somehow moved or cocked the outer bearing just a hair? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
D/A/N Samba Member
Posted: Mon Aug 07, 2017 11:04 am Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
Clatter wrote: |
Colin is coming? I don't even know how to contact him. Did someone else? If he's on his way and has a solution, I'm game. We were supposed to leave OR 3 weeks ago. |
Posted: Mon Aug 07, 2017 11:06 am Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
SGKent wrote: |
Tram - I did not know you were in Oregon working on this bus. Had I realized it was you doing the work, the appropriate response would have been to send you original German parts. |
No worries. Actually, Colin is a good egg and in these cases multiple heads are always better than one. I actually built the bus for D/A/N and neena. It was a typical Oregon field terrarium with a solid body but everything else rat- boinked. I mean everything else!
I did browse the issue on Colin's site actually, and his take is that play should not be there and if it is you have bad bearings, which tallies with what I remember- so we're on the same page there. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Mon Aug 07, 2017 11:10 am Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
D/A/N wrote: |
Clatter wrote: |
News to me. If he is, I'll let him deal with it and we'll join you guys at the coast... and bring booze. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
SGKent Samba Member
Posted: Mon Aug 07, 2017 11:18 am Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
was the replacement stub new or used? Is it possible someone substituted a 1971 - 1979 stub?
8/67 - 7/70 211 501 265
8/70 > 211 501 265C _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
D/A/N Samba Member
Posted: Mon Aug 07, 2017 11:21 am Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
SGKent wrote: |
8/70 > 211 501 265C |
The replacement stub is used and the same length as the original. Is there another difference between the early and later ones? |
