brando06 Samba Member
Joined: November 03, 2006 Posts: 191 Location: Vancouver, BC, Canada
Posted: Thu Aug 17, 2017 4:29 pm Post subject: Re: Alternator question |
Charged the battery, its now reading 12.38. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5995 Location: Brooklyn
Posted: Thu Aug 17, 2017 4:39 pm Post subject: Re: Alternator question |
That is way low. If that was after charging overnight, suspect battery is on the way out. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Thu Aug 17, 2017 6:54 pm Post subject: Re: Alternator question |
sjbartnik wrote: |
That is way low. If that was after charging overnight, suspect battery is on the way out. |
Really? It was brand new. Maybe I'll try charging for longer. It wasn't overnight. It was just til the light turned green on the charger.
What should it be at? I thought from that chart on page 1, it is at about 70%. |
rottenkid Samba Member
Joined: June 19, 2015 Posts: 236 Location: Warkworth, ontario
Posted: Thu Aug 17, 2017 7:00 pm Post subject: Re: Alternator question |
Where did you purchase the battery from? Maybe you should take it back and have the battery checked out. |
Posted: Thu Aug 17, 2017 7:03 pm Post subject: Re: Alternator question |
rottenkid wrote: |
NAPA |
Posted: Thu Aug 17, 2017 7:08 pm Post subject: Re: Alternator question |
I have Napa batteries in my motorhome. Good batteries. They are Four years old, which is good four deep cell batteries.
I know my meters never show batteries charged beyond what your getting. Do you have anyone in the Vancouver area that can help you remove your alternator so you can have it tested. Any rebuilder will test the alternator for free. |
Posted: Thu Aug 17, 2017 7:12 pm Post subject: Re: Alternator question |
rottenkid wrote: |
I see people from Vancouver on here, but not sure of anyone who would be willing to help. |
Posted: Thu Aug 17, 2017 7:42 pm Post subject: Re: Alternator question |
Try emailed the people in your area for help. VW people usually stick together. I'm sure someone will lend you a hand.
When you own a bus, you have to learn to work on the bus yourself. If someone can guide you, then you will gain the confidence to work on your own. |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Thu Aug 17, 2017 8:43 pm Post subject: Re: Alternator question |
rottenkid wrote: |
Earlier this year, when I pulled the engine to do the carb to FI swap, I removed the alternator and took it to O'Reilly's to test it. Wouldn't you know.... their diagnostic computer said it could only be tested when it's mounted on the vehicle!
So it may be worth a call to a local FLAPS to find out if their computer tells them the same thing. (BTW... I haven't taken it back to have it checked, even though it's been installed for several months. "If it works, don't fix it!") _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
Posted: Thu Aug 17, 2017 8:55 pm Post subject: Re: Alternator question |
brando06 wrote: |
70% is pretty crap for a battery that just sat on the charger.
When it's fully charged it should read 12.6v or so. That's measured directly across the battery terminals with no load on it. _________________ 1965 Volkswagen 1500 Variant S
Posted: Thu Aug 17, 2017 9:14 pm Post subject: Re: Alternator question |
rottenkid wrote: |
Thanks buddy. |
Posted: Thu Aug 17, 2017 9:16 pm Post subject: Re: Alternator question |
sjbartnik wrote: |
brando06 wrote: |
When it's fully charged it should read 12.6v or so. That's measured directly across the battery terminals with no load on it. |
Fair enough. That's with the bus turned on though. |
Posted: Fri Aug 18, 2017 3:19 am Post subject: Re: Alternator question |
I had picked up a $35 70 amp alternator at a swap. I had a rebuilder test that alternator without a problem. The alternator tested Ok. That alternator is in my bus now, for a few months now. The rebuilder had my old alternator rebuilt within two days. I had told the rebuilder there was no rush. |
rusty busty Samba Member
Joined: May 27, 2015 Posts: 310 Location: Vancouver BC
Posted: Fri Aug 18, 2017 4:16 am Post subject: Re: Alternator question |
I'd recommend going to Ashnat alternators and starters. They're on Broadway near Frasier in Vancouver. They're reasonably priced and honest. They can test the alternator weather it's in the vehicle or removed. If it needs to be removed and rebuilt they can probably do that too.
They just rebuilt a 70 amp alternator for me a few weeks ago. _________________ 1978 CEII Get-away hightop |
Posted: Fri Aug 18, 2017 6:44 am Post subject: Re: Alternator question |
rusty busty wrote: |
They just rebuilt a 70 amp alternator for me a few weeks ago. |
Thanks man. Good to see someone from Vancouver. |
Posted: Fri Aug 18, 2017 8:33 am Post subject: Re: Alternator question |
brando06 wrote: |
OK that's a different story. You will see the voltage go down a bit if the dome light is on or more if you turn the ignition on.
So if you're saying it's 12.38 with ignition on but engine not running I could see that.
If it's 12.38 with engine running, then your alternator isn't doing anything. _________________ 1965 Volkswagen 1500 Variant S
