cchris Samba Member
Joined: March 16, 2015 Posts: 91 Location: United States
Posted: Mon Aug 07, 2017 3:54 pm Post subject: 76 Baywindow oil pressure issues |
I just rebuilt a type 4 2.0 New pistons cylinders and head work just got it running got it fired up and running good for 5 minutes at a time to set timing and fix minor issues gas leak etc. I went to check the valves and noticed they were wet but not as much as they should be Oil wasn't dripping out of the covers when i pulled them off The oil pressure light has always turned off when ever i started the motor I also cleaned and inspected the pushrods to make sure they weren't plugged when i installed them All my other Vw's would be dripping in oil after 5 minutes Other that noisy valve train engine sounds great Any ideas on checking the oil pressure? PS the rocker shaft block has been fixed blame it on bad eye sight and poor lighting
timvw7476 Samba Member
Posted: Mon Aug 07, 2017 4:02 pm Post subject: Re: 76 Baywindow oil problems |
Quick & Dirty way is: unthread the oil pressure switch, pull the coil lead to
the distributor & crank a few seconds, cardboard under the oil filter area
optional. If you get a slight puddle of oil, the pump is moving oil.
Not a good indicator for proper pressure, just a function check. |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
cchris Samba Member
Posted: Mon Aug 07, 2017 4:26 pm Post subject: Re: 76 Baywindow oil pressure issues |
Good Eye lil-jinx didn't notice that fixing that right now |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4539 Location: Arizona Highways
Posted: Mon Aug 07, 2017 6:33 pm Post subject: Re: 76 Baywindow oil pressure issues |
something weird is going on in there.
your adjuster screws are all over the place.
other than that, it looks normal for 5 minutes of run time.
when you say "rebuilt" do you mean "top end"? or did you open the crankcase?
either way, you need to know if you have hydraulic or solid lifters.
T4s have a relatively quite valve train as far as VWs go.
especially the hydros.
your problem could be as simple as pushrods that are not seated properly--most common on the lifter end.
or as complicated as a hydro/solid mismatch with the cam & lifters; or even worse.
a mechanical oil pressure gauge is a must.
so much amature shit has been done to these poor engines over the years (not implying anything )
what was done to your heads? what kind of P/Cs did you use? so many variables and so many known problems with appropriate solutions. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
cchris Samba Member
Posted: Mon Aug 07, 2017 7:28 pm Post subject: Re: 76 Baywindow oil pressure issues |
I didn't split the case just a top end rebuild and when i flipped the rocker shaft block over it brought all the adjustment screws back in line with each other It's got solid lifters and double checked the pushrods and they're seated in the rockers The heads were resurfaced installed new exhaust valves seats and guides at a local head shop where thats all they do This is what i started with the water never made it past the rings
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Mon Aug 07, 2017 7:40 pm Post subject: Re: 76 Baywindow oil pressure issues |
Your oil pressure sensor / switch-- is right near the distributer. You can put a mechanical gauge on a grease gun line and it will thread right in the hole- no need to tighten it for just a check.
That thermostat is a goner- _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Mon Aug 07, 2017 8:38 pm Post subject: Re: 76 Baywindow oil pressure issues |
Pressure gauge would be the way to go,could run it with the valve cover off to see what is going on,it should make a mess,be prepared to shut it off quickly. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy
1974 parts bus
Posted: Mon Aug 07, 2017 10:23 pm Post subject: Re: 76 Baywindow oil pressure issues |
It might take more than 5 minutes for cold thick oil to make its way into the rocker boxes. Not sure. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Tue Aug 08, 2017 8:08 am Post subject: Re: 76 Baywindow oil pressure issues |
Well, it looks like you found an old engine and dolled it up some. You may have a new top end but you have no idea what's going on in the case. You should pull all the spark plugs so the engine will rotate freely. Screw an aft left hand rubber brake hose into the oil pressure switch port and a 0-60 gauge with 1/8 NPT fitting into the other end of the hose. Crank the engine and see what kind of pressure you get. Running an unknown engine without at least oil pressure monitoring is pretty risky.
The left aft bus rubber brake hose has a 10mx1.0 male on one end and a female on the other. The 1/8 x 27 NPT will screw into the female end and not leak. The male end will screw into the oil pressure switch port perfectly. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
cchris Samba Member
Posted: Tue Aug 08, 2017 2:00 pm Post subject: Re: 76 Baywindow oil pressure issues |
williamM I've replaced the thermostat figured it was shot And aeromech i have brand new brake lines that came with the bus got it screwed in just waiting for the gauge to get here I'm hoping the bottom end is all right the oil was surprisingly clean i drained it through a paint strainer to check for any debris and inspected the rods the all looked good I am running a Fram filter and i read that they could also cause low oil pressure Does anyone have any problems with Fram filters? I know Busdepot offers the German replacement i planned on changing the oil and filter soon |
Posted: Tue Aug 08, 2017 2:06 pm Post subject: Re: 76 Baywindow oil pressure issues |
You can get a Motorcraft FL-1a or FL-300 filter (or equivalent) most anywhere, no need to search for specialty filters for these rigs, they accept the most common filters out there. |
Posted: Tue Aug 08, 2017 2:20 pm Post subject: Re: 76 Baywindow oil pressure issues |
I've never heard of a Fram causing low oil pressure _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Tue Aug 08, 2017 3:00 pm Post subject: Re: 76 Baywindow oil pressure issues |
aeromech wrote: |
I've never heard of a Fram causing low oil pressure |
I have heard of it, but don't understand how it could happen. If the filter was plugged and didn't internally bypass the bypass in the filter mount would continue to permit a normal flow of oil.
Also if a filter dead headed the pump the filter should bulge and blow up or the pump should fail. |
cchris Samba Member
Posted: Tue Aug 08, 2017 7:46 pm Post subject: Re: 76 Baywindow oil pressure issues |
Off Ratwell's baywindowfax page---The Bosch 72137 filter is an American aftermarket filter with the Bosch name slapped on it. No one knows if it's suitable and fits the VW engine filtering requirements. I know of at least one person who removed this filter and it solved their oil pressure woes. Searching the web I found this information to support the claim it's inappropriate: While both the STP and the Bosch filters were at one point good filters, they are now manufactured off shore of sub-standard parts. The filter assemblies tended not to have even pleats and generally less media than other comparable filters. There was also a complete lack of a well functioning by-pass valve. With most filters there is an obvious and discrete by-pass valve, but with these filters the can spring and the by-pass valve are the same. The real issue is that in order for the filter to properly by-pass the entire filter assembly would have to move down during use. That is actually not possible with filter assembly properly seating into the anti-drain back valve. This means that the by-pass will effectively never work. |
Posted: Tue Aug 08, 2017 8:06 pm Post subject: Re: 76 Baywindow oil pressure issues |
Fram 2870A, usual app rabbit golf dasher & whatever else from the
seventies/eighties, in a pinch, for type IV. Not the best capacity but then
again these didn't come with a 10k oil interval change. |
cchris Samba Member
Posted: Wed Aug 09, 2017 4:25 pm Post subject: Re: 76 Baywindow oil pressure issues |
Just checked the pressure with the gauge and it's a little low it's around 20-25 PSI at idle with the engine warm and goes up to around 55 PSI at 2500 RPM The book says the minimum should be 28 PSI I'm sure the bottom end is tired but is there any problem installing a heavier pressure valve (spring) to boost the pressure back up? Or anything else i should try first? |
Posted: Wed Aug 09, 2017 4:41 pm Post subject: Re: 76 Baywindow oil pressure issues |
20 psi at hot idle is just fine. A lot of new rebuilds don't do that well.
If you are running a thick oil like a 20w50 you might want to go to something thinner so the oil will move up into the rocker boxes faster. |
cchris Samba Member
Posted: Wed Aug 09, 2017 5:09 pm Post subject: Re: 76 Baywindow oil pressure issues |
Okay thats what i wanted to hear i am running 20/50 i'll keep a eye on it and see if i need to go lighter when i do my oil change coming up Thanks Wildthings |
cchris Samba Member
Posted: Mon Aug 21, 2017 12:31 pm Post subject: Re: 76 Baywindow oil pressure issues |
Finally got what i needed to finish installing my oil pressure gauge Due to the sender location i opted for a remote sender If anyone needs lines and fittings in the North Los Angeles area I highly recommend Orme Bros .they're very knowledgeable with reasonable prices with everything you need They also make lines to order on the spot
