Trav'ler Stove questions
Schwing
Schwing is offline
PostPosted: Mon Aug 07, 2017 7:36 pm    Post subject: Trav'ler Stove questions Reply with quote
Hey guys I recently picked up an original Westy Trav'ler stove for my 72 that was not equipped with one from the factory. My original sink was missing so I decided to modify it so I could install this stove/fridge combo. Plan is to make this unit removable since I have a family of four.
Has anyone ever hooked up their stove to a 1lb green bottle? If so, do I need a regulator or just a simple adaptor?
Thanks guys. Oh and some pics.
Shadetree Westy
http://www.thesamba.com/vw/forum/viewtopic.php?t=657279&highlight=
Single Cab - slow goes it
williamM
williamM is offline
PostPosted: Mon Aug 07, 2017 7:47 pm    Post subject: Re: Trav'ler Stove questions Reply with quote
you will need a regulator
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
otiswesty
otiswesty is offline
PostPosted: Mon Aug 07, 2017 9:05 pm    Post subject: Re: Trav'ler Stove questions Reply with quote
The first time you turn it on without a regular is very interesting. Ask me how I know. Shocked
If you have any supply house with a fitting and regulator for the 1# bottle, you can get the threaded adaptor to the stove at Ace hardware that has a barbed house fitting.
1989 Syncro Westfalia
1978 Sage Green P22 Westfalia
Mercedes Gwagens
Just a regular guy
Schwing
Schwing is offline
PostPosted: Tue Aug 08, 2017 3:30 am    Post subject: Re: Trav'ler Stove questions Reply with quote
Ok thanks for the advice fellas. I will try to run to the depot today to see what I can find, and update what I figure out here.
Shadetree Westy
vwwestyman
vwwestyman is offline
PostPosted: Tue Aug 08, 2017 6:09 am    Post subject: Re: Trav'ler Stove questions Reply with quote
You'll have better luck at a place like Ace Hardware (or other locally owned hardware store) than Home Depot finding what you need, and a much better chance finding someone working there who can help you put together the kit you need to hook up your small cylinder safely.
You'll need a regulator for the small bottle, hose from the regulator to the flexible metal line I see there, and an adapter connector between the two.
If possible, if I were you, I would see if you can remove the flexible metal line and hook up your new rubber line directly to where the metal line connected.
Dave Cook
Stuartzickefoose wrote:
I'm gonna punch vwwestyman then shake his hand when I meet him.
notchboy wrote:
Ill just punch you in the face. Wink
1973 Wild Westerner
My Thing
danfromsyr
danfromsyr is offline
PostPosted: Tue Aug 08, 2017 7:21 am    Post subject: Re: Trav'ler Stove questions Reply with quote
farm & fleet or Tractor supply often has a nice propane fitting rack.
you need one of these threaded into a propane BBQ regulator/hose assembly
it will replace the plastic tank adapter, it can be tough to remove, the inside of the plastic will accept a socket, the outside of the regulator will accept a crescent wrench. unscrew the old and screw on the new. USE THREAD SEALANT.
and ditch the metal corrugated line.
the fitting on the stove is 3/8 flare
Vanagon List Archives
The only cheap thing in a classic VW sits behind the steering wheel
THE List ala Sanchius
syncroserge wrote:
The way these vans have shaped and enriched our family life would make one believe these darn things have a soul Cool
Abscate Premium Member
Abscate is offline
PostPosted: Tue Aug 08, 2017 7:25 am    Post subject: Re: Trav'ler Stove questions Reply with quote
Define "need" - do you mean if you wish to continue living?
Good on OP for researching this first.
.ssS!
williamM
williamM is offline
PostPosted: Fri Aug 11, 2017 2:04 pm    Post subject: Re: Trav'ler Stove questions Reply with quote
I always encourage independent thought and the chance to "Learn by doing"-- or not doing-- We studied Darwin in high school.
Don't step in any!
busdaddy
busdaddy is offline
PostPosted: Fri Aug 11, 2017 4:30 pm    Post subject: Re: Trav'ler Stove questions Reply with quote
Eyebrows are over rated, who needs them? Wink
williamM
williamM is offline
PostPosted: Sat Aug 12, 2017 6:05 am    Post subject: Re: Trav'ler Stove questions Reply with quote
Shocked Shocked Shocked Shocked Shocked Very Happy Does Blazecut make a hat???- like birthday party balloons
Don't step in any!
