Putting a different air filter on T4 Bus.
Page: Previous  1, 2
lightice
lightice is offline
PostPosted: Sat Aug 12, 2017 8:23 pm    Post subject: Re: Putting a different air filter on T4 Bus. Reply with quote
The dusty condition oil bath is really long and the oil sits right at the bottom.
Unlikely any oil would be able to go up that far.
I like that filter, but I run a carb.
They also need the special bracket to hold them, which are getting rare.
williamM
williamM is offline
PostPosted: Tue Aug 15, 2017 7:23 am    Post subject: Re: Putting a different air filter on T4 Bus. Reply with quote
Having several of those 181 filters, I was just concerned about them being "smaller" -as they were designed for the 1600 and I need one for the 2.0-- probably not an issue if you keep it under 70mph- but am looking for some real user input here. Could just put some 1700 heads in there and solve the problem- wonder how that would work??
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
lightice
lightice is offline
PostPosted: Tue Aug 15, 2017 7:26 am    Post subject: Re: Putting a different air filter on T4 Bus. Reply with quote
There was a version with 2 of those filters.
But the 2 filters were 'handed', and the intake boot is also hard to find, but I guess you can fabricate it up if you do have both filters.
williamM
williamM is offline
PostPosted: Tue Aug 15, 2017 7:36 am    Post subject: Re: Putting a different air filter on T4 Bus. Reply with quote
Surprised like this?[img]
Because these are for a type 1-[/img]
Don't step in any!
busdaddy
busdaddy is offline
PostPosted: Tue Aug 15, 2017 7:47 am    Post subject: Re: Putting a different air filter on T4 Bus. Reply with quote
williamM wrote:
Tram wrote:
busdaddy wrote:
I seem to recall finding a K&N element in a FI bus's filter a few years ago, not too hard to wash that out and re-oil. I wonder if they still make them?
Exactly what I was going to suggest, and yes:
https://www.knfilters.com/air_filter/1976/volkswag...gKGK_D_BwE
That particular filter fits the 1.6 ltr motor? If they have one for the 2. ltr FI air box, that would be great-
K&N's website doesn't get along with my computer, but a 73+ Euro 1600 bus uses the same 012 129 620 filter element as type 4 FI buses (73/74 carbed bus with the plastic filter and I think early Vanagon too).
NASkeet
NASkeet is offline
PostPosted: Tue Aug 15, 2017 7:59 am    Post subject: Re: Putting a different air filter on T4 Bus. Reply with quote
It might be the late-1973-model-year or 1974-model-year VW 1600 Type 2 which were the first to be equipped with the paper-element air filter. My British specification, early-1973-model-year VW 1600 Type 2 (late-August or early-September 1972), was equipped with an oil-bath air cleaner and a 38A dynamo.
Regards.
Nigel A. Skeet
http://www.vwt2oc.net
busdaddy
busdaddy is offline
PostPosted: Tue Aug 15, 2017 9:51 am    Post subject: Re: Putting a different air filter on T4 Bus. Reply with quote
Ahhhhh..., OK, good to know, I've never had my head in the compartment of a Euro 73, type 4's went to the plastic filter in 73, my bad.
lightice
lightice is offline
PostPosted: Tue Aug 15, 2017 3:07 pm    Post subject: Re: Putting a different air filter on T4 Bus. Reply with quote
Hi william, yes but the one on the right is the wrong unit.
The intakes on both the units should face the rear.
These are type 181 filters right?
Bus filters typically look like this, with less 'attachments' at the snorkel intake.
williamM
williamM is offline
PostPosted: Tue Aug 15, 2017 3:55 pm    Post subject: Re: Putting a different air filter on T4 Bus. Reply with quote
Almost had one of those, but got no reply Embarassed
That is two 181 filters, so one will need surgery, but that manifold isn't for a T-4 motor.- I'm saving it for a 66 EZ which will be worked on 3rd.
I am planning a small square plate with an inlet welded to it that would bolt to the AFM and a 2" flex tubing would fit over and go to a decent oil bath filter.
I think (there I go again) the 1600 paper filter was a long box with an oblong filter in it.- might have been for a beetle, but side by side looked like a rabbit filter.
Don't step in any!
busdaddy
busdaddy is offline
PostPosted: Tue Aug 15, 2017 4:36 pm    Post subject: Re: Putting a different air filter on T4 Bus. Reply with quote
Later beetles used a long rectangular filter, the 1600 bus uses the same square filter and mount as our FI versions, but with a different outlet: (click twice to rebigulate)
williamM
williamM is offline
PostPosted: Tue Aug 15, 2017 4:49 pm    Post subject: Re: Putting a different air filter on T4 Bus. Reply with quote
One of those from KB with wash n oil replenish would solve the problem.
Don't step in any!
lightice
lightice is offline
PostPosted: Tue Aug 15, 2017 4:57 pm    Post subject: Re: Putting a different air filter on T4 Bus. Reply with quote
William, I don't think you should mod it, instead look to swap it. When I was looking for my dusty filter, I had more luck getting as there were more ads for the 'right' version than the 'left'.
busdaddy
busdaddy is offline
PostPosted: Tue Aug 15, 2017 5:29 pm    Post subject: Re: Putting a different air filter on T4 Bus. Reply with quote
williamM
williamM is offline
PostPosted: Wed Aug 16, 2017 6:37 am    Post subject: Re: Putting a different air filter on T4 Bus. Reply with quote
busdaddy wrote:
$60 and never buy a filter again--think we have a winner.---thanks for the link-
Don't step in any!
NASkeet
NASkeet is offline
PostPosted: Wed Aug 16, 2017 8:22 am    Post subject: Re: Putting a different air filter on T4 Bus. Reply with quote
Noting Photobucket's recent awkward behaviour, the following links might not be as useful as they could be:
Home Forums > Help and Assistance > Bay Tech Clinic > Engine & Transmission > Engine air filters, for very-dusty conditions?
http://forums.kombiclub.com/threads/engine-air-filters-for-very-dusty-conditions.20162/#post-256786
http://forums.kombiclub.com/threads/air-cleaner-identification.28937/page-2#post-371478
Home Forums > Help and Assistance > Bay Tech Clinic > Engine & Transmission > Stock air cleaner
http://forums.kombiclub.com/threads/stock-air-cleaner.23366/page-2#post-256791
Regards.
Nigel A. Skeet
williamM
williamM is offline
PostPosted: Wed Aug 16, 2017 9:56 am    Post subject: Re: Putting a different air filter on T4 Bus. Reply with quote
Embarassed Sad couldn't get any pics or links to work-- But do agree as I put the stock oil bath little air cleaner on the roof of my kombi when stuck in Katherine and it worked great till the attached inlet on the carb split and sanded the new motor- but thats another story.
I plan a snorkel up the inside of the passenger side to go to either a KD stock filter, or a modified 181 filter.
Agree it's not rocket science to know high and ahead of the rear axle is where the clear air is.
Don't step in any!
Tcash
Tcash is offline
PostPosted: Wed Aug 16, 2017 11:09 am    Post subject: Re: Putting a different air filter on T4 Bus. Reply with quote
I have not quite figured out how to search for them yet. But Google Gallery seems to have the pictures.
Tcash
Filter-Mate air pre-cleaner naskeet, search
https://www.google.com/search?biw=1242&bih=602...I4#imgrc=_
SGKent Premium Member
SGKent is offline
PostPosted: Wed Aug 16, 2017 1:38 pm    Post subject: Re: Putting a different air filter on T4 Bus. Reply with quote
FWIW by the time the filter is purchased, the cleaners and oils etc, and the frequency they have to be washed I'll never do it again for any car. I could not notice any extra power and the gauze on the ones I had did not stop as much dust as a stock wix, motorcraft, fram NAPA etc filter.
Read: https://www.bobistheoilguy.com/airfilter/airtest1.htm
*You can do it right the first time, or do it over, the choice is yours. It is a free country. As to brakes, steering, tires, axles etc. - you may only get one chance at doing it right.
* VW Buses and VW cars share many of the same systems but if you haven't owned a bus and maintained it for awhile, you really don't know how different it is.
Abscate Premium Member
Abscate is offline
PostPosted: Wed Aug 16, 2017 2:44 pm    Post subject: Re: Putting a different air filter on T4 Bus. Reply with quote
I call this one for sig
.ssS!
busdaddy
busdaddy is offline
PostPosted: Wed Aug 16, 2017 3:40 pm    Post subject: Re: Putting a different air filter on T4 Bus. Reply with quote
You've gotta be a long time Simpsons fan to get that one. Wink
Page: Previous  1, 2
Page 2 of 2
