MFEurovan Samba Member
Posted: Wed Aug 09, 2017 9:17 am Post subject: Key FOB has batteries but not working |
Hi there, I have a non factory key fob that I got off of amazon. It was working fine for about 5 months. Recently I had some body work on my car. Both doors were removed (we replaced the wire harness for the driver side door which I'm sure the caused the car computer to be reset). Now my key fob won't work. It's got fresh batteries. When I press the button the red lights come on so I know it has power but it no longer unlocks the car. Super annoying considering the eurovan doesn't have a power unlock buttons. You never miss something till it's gone! Any ideas?
Thanks!
Melissa |
Joshwa Samba Member
Joined: November 18, 2015 Posts: 810 Location: North Seattle WA
jjvincent Samba Member
Joined: January 11, 2016 Posts: 1268 Location: Bethlehem, PA
Posted: Wed Aug 09, 2017 1:56 pm Post subject: Re: Key FOB has batteries but not working |
Do you still have a factory key fob or at least a working one still? |
markcm2 Samba Member
Joined: September 02, 2015 Posts: 505 Location: Bellingham, Washington
Posted: Wed Aug 09, 2017 2:04 pm Post subject: Re: Key FOB has batteries but not working |
There is typically a process (or two) for sync'ing a key Fob remote to VW/Audi. This sometimes needs to be reset when batteries are replaced or the car battery is removed.
If you have vagcom, you can use this tool to sync fobs. If you do not have vagcom but have 2 keys, many VW/audis can be sync'd by putting the original key in the ignition to ACC position and then inserting the key to be programmed in the drivers door. The last steps is something like turning the key to the lock position and pushing the lock button, or maybe its the unlock position and pushing the unlock button.
Google "VW eurovan sync key fob |
Posted: Wed Aug 09, 2017 3:17 pm Post subject: Re: Key FOB has batteries but not working |
Also, those aftermarket key fobs do fail. Just because the red light comes on doesn't mean it's working. Only real way to tell is to use a VAGCOM to check it out. One car I had bought used had the locks disabled because one of the keys had the open button stuck on and someone was smart enough to disable that system but not just eliminate that key from the system and sync the one that actually still did work.
I do know that a battery change in either the fob or the car does not change the sync of either one of them (it is not battery dependent). I do know that the Eurovan will only store 4 different remotes at a time. This is why with a VAGCOM you can reset the whole system ans start over again.
In the end, the red flag I see is this:
Quote: |
Recently I had some body work on my car. Both doors were removed |
pwcgecko Samba Member
Posted: Wed Aug 09, 2017 6:52 pm Post subject: Re: Key FOB has batteries but not working |
I just recently purchased a aftermarket key fob off of ebay, to program. the followig procedure does work:
EUROVAN REMOTE MATCHING:
Put a key in the ignition and turn it on then off within 5 seconds Within 15 seconds turn the ignition back on and lock the drivers door by pushing the button down manually from the inside (you are sitting in the van with the door closed) Press the door unlock button on the remote two times within 30 seconds The remote is now matched to the van. Turn the ignition off. _________________ 2002 Eurovan Weekender in SoCal |
