Blasted Samba Member
Posted: Wed Aug 09, 2017 9:57 am Post subject: How do you decide on how much boost? |
Simple question I hope,
When building a turbo engine how do you determine how much boost you want? From reading various threads I get the impression that people aim for specific figures?
If that’s the case what's a good figure to aim for? (VW type 1)
Thanks |
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2335 Location: Mount Airy, Maryland
Posted: Wed Aug 09, 2017 10:06 am Post subject: Re: How do you decide on how much boost? |
That depends on many variables.
1) Common detonation points known by trial and error.
2) Type of Fuel.
3) Static Compression
4) Dynamic Compression.
5) Shape of Piston Top / Combustion Chamber.
6) Timing Advance / Retard.
For the street the max is usually in the 10-12 PSI range. Some will stretch it and risk detonation. _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
kangaboy Samba Member
Joined: August 28, 2010 Posts: 1063 Location: St. Louis, Mo
Posted: Wed Aug 09, 2017 10:13 am Post subject: Re: How do you decide on how much boost? |
The only thing stopping me is Intake Air Temperatures. I only run 8lbs right now and can't safely run any higher without my IATs skyrocketing because I lack and intercooler or water/meth injection system. _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote: |
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
gprudenciop Samba Member
Joined: July 06, 2008 Posts: 606 Location: portland or
Posted: Wed Aug 09, 2017 11:19 am Post subject: Re: How do you decide on how much boost? |
As much as possible! I'm at 19 with intercooler in my daily. _________________ Never look down at anybody unless you are helping them up..
Loaning someone your strength instead of reminding them of their weakness = kindness.. |
c77owen Samba Member
Joined: July 07, 2017 Posts: 454 Location: Kansas City, MO
Posted: Wed Aug 09, 2017 11:30 am Post subject: Re: How do you decide on how much boost? |
All of it.... |
Posted: Wed Aug 09, 2017 12:38 pm Post subject: Re: How do you decide on how much boost? |
Thanks for the responses.
I'm going to order the turbomania book and do a bit of reading but it would be nice to know I'm on the right path with my thinking.
As I understand it boost is the difference in flow between what the turbo pushes out and what the engine can consume i.e an increased pressure in the inlet side of the system.
Primary factors controlling boost are the rpm of the engine, the size of the impeller/compressors of the turbo, the manifold diameter and the flow rate of the engine.
Secondary factors are the fuel type, fuel injectors, ignition, cylinder head flow rate.
Too much boost is bad for the life of the engine. Too little boost defeats the purpose of turboing.
So hypothetically speaking, I thought about building the following, where does the boost factor into the equation?
2007cc engine – 78x90.5
T3/4 turbo
EFI
CB heads with match ported manifolds |
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Wed Aug 09, 2017 6:11 pm Post subject: Re: How do you decide on how much boost? |
Compression and octane of the fuel. The less the compression the more boost you can run. But not enough compression and its lazy off boost. It's all about compromise. The higher the octane the more boost (within reason) E85 would be your friend if you have access to it. |
modok Samba Member
Posted: Wed Aug 09, 2017 6:20 pm Post subject: Re: How do you decide on how much boost? |
Ultimately you turn it up until you hear a little knock or the clutch starts slipping, then back it down a few pounds.
knock is mainly a function of fuel VS heat. Colder air, colder engine you can get away with more. Lower compression allows more, but important to not go too far with that idea for reasons like you mentioned. What is practical?
Simple setup and premium pump gas, 5-7 pounds
with intercooler and fancier stuff, 10-12
higher octane fuel, or ethanol, 15psi+ |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4028 Location: NW Washington
Posted: Wed Aug 09, 2017 6:58 pm Post subject: Re: How do you decide on how much boost? |
The turbomania book.... while not a bad read is really quite dated especially if you are planning on EFI.
There are setups running upwards of 30 lbs boost with well designed intake and fuel management systems.
You can run 20 plus lbs. boost on a almost stock engine if you pay attention to detonation and IAT's.
Remember.... the cooler the air the more dense it is and therefore the more fuel you can add without getting too rich.
The two easier ways to gain hp with a turbo is rpm and keeping the intake temps as close to ambient as possible.
Water/Alcohol Injection works pretty good for me and allows me to run 22 plus lbs. boost on an almost stock engine.
Without water injection I might be able to run 15 lbs but with severely retarded timing and only in the cooler times of year.
If I switch off my Electronic Boost Control and go with the stock 6 lb. Subaru waste gate I can go anywhere and everywhere without a worry in the world. I need very little timing retard and no water injection.
It gives me enough extra power to climb any mountain grade at 60 plus mph and no shifting down.
In fact I went 3500 miles to California and back that way.
Flip two switches and I am right back to 22 lbs. boost.
Oh.... and don't forget......once you taste the boost you will be addicted and will turn it up at any cost.......
Here is a log when I was testing boost and hit my overboost protection.
It's kind of hard to read ....
23.2 lbs boost
3608 rpm
129 degrees MAT
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
oprn Samba Member
Joined: November 13, 2016 Posts: 12744 Location: Western Canada
Posted: Wed Aug 09, 2017 10:26 pm Post subject: Re: How do you decide on how much boost? |
Way too many variables to give a single answer!
One thing that I found was huge was the ambient air temperature. Summer temps would only allow 10 or 11 psi before detonation reared it's ugly head but at -30 she would run well over 18 psi with no sign of the problem at all! That was running 9.5/1 CR and 120 octane fuel.
Intake air cooling is so important to get consistency! |
Posted: Thu Aug 10, 2017 4:00 am Post subject: Re: How do you decide on how much boost? |
Thanks for the great replies.
Two things I'm going to have little control over is the quality of the fuel and air temperature/humidity. The UK is variable at best but I would expect more of my driving to be in the summer than the winter.
So, going back to my original point. My confusion came from do you:
1. Build an engine aiming for a specific boost figure,careful components selection and a bit of maths?
or,
2. Build an engine around personal preferences and with turbo in mind, find out your boost and then just tweak the engine to make the most of what you get?
What I'm essentially doing is building a set of requirements, these requirements then influence the engine build plan and component selection.
Requirements to date:
Reliable,requires little ongoing work aside from general maintenance.
Value for money, I don't want to spend a lot of money for small gains when a different set up for a similar price produces a lot more power.
I don't want to have to chop into the body or drill holes in firewalls etc. Rear lids got to close.
Combination of steady town motorway driving, but picks up quick from low down and puts a smile on my face if I plant it.
Thanks |
oprn Samba Member
Posted: Thu Aug 10, 2017 5:07 am Post subject: Re: How do you decide on how much boost? |
Here is my read on this.
Blasted wrote: |
Reliable,requires little ongoing work aside from general maintenance. |
Find a turbo kit supplier with a good reputation, go modest on both boost and compression ratio, then build a good solid engine with quality parts. Avoid the bargain outlets.
Look for a single carb draw through setup for simplicity of tuning and low on going maintenance.
Blasted wrote: |
Value for money, I don't want to spend a lot of money for small gains when a different set up for a similar price produces a lot more power. |
Turbocharging fits the bill here!!
Blasted wrote: |
Combination of steady town motorway driving, but picks up quick from low down and puts a smile on my face if I plant it. |
This is the bit that will require the math and careful planning! Turbos tend to take a bit of time to get into action. Matching a turbo for quick low end response and good open road action is a tough one. Generally there are compromises to be made between the two unless you do the twin turbo thing that some car manufacturers are doing now. A small one for good quick off idle snap and a bigger one for the open road. |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Thu Aug 10, 2017 5:24 am Post subject: Re: How do you decide on how much boost? |
Bullet proof it
build it with the best parts
I think about the 'stock rods" in my 1915cc ,,, sometimes (8-12lbs)
I don't know how their holding up so far so good
I have a set of Carillo's in the 2276 and no worry's 15-18 lbs with higher octane, "Your fuel Quality availability will determine your boost levels " _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Splitdog Samba Split Personality
Joined: February 16, 2004 Posts: 4125 Location: Planet VW
Posted: Thu Aug 10, 2017 6:43 am Post subject: Re: How do you decide on how much boost? |
Go water injection. Huge gains for the money. I'm running 15 lbs on pump gas and can drive the car 100 miles in 90* heat. Stock head studs-8mm-static CR=7.1. More boost, less compression is better I think than more compression, less boost. More boost= more fuel and air. Good luck. _________________ CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker |
Posted: Thu Aug 10, 2017 11:39 am Post subject: Re: How do you decide on how much boost? |
Thanks again, plenty of stuff for me to think about. |
Dauz Samba Member
Posted: Thu Aug 10, 2017 11:50 am Post subject: Re: How do you decide on how much boost? |
What gearbox? |
Posted: Thu Aug 10, 2017 1:29 pm Post subject: Re: How do you decide on how much boost? |
Dauz wrote: |
What gearbox? |
That's for a different question, my mind is full up with turbo information at the moment. Of course its something that will have to be taken into account. |
Dauz Samba Member
Posted: Thu Aug 10, 2017 3:51 pm Post subject: Re: How do you decide on how much boost? |
Blasted wrote: |
Dauz wrote: |
What gearbox? |
Right on. It is a limiting factor. |
mark tucker Samba Member
Posted: Thu Aug 10, 2017 4:26 pm Post subject: Re: How do you decide on how much boost? |
I wood think it's one of 2 things, deeper pocket or butt dyno getting used to it. well you asked. |
