Bolt On Sand Seal
limon
limon is offline
PostPosted: Wed Aug 09, 2017 4:49 pm    Post subject: Bolt On Sand Seal Reply with quote
I just finished installing an EMPI pulley and sand seal kit; instructions said to use #9118 Crank Bolt and Washer. I bought that too, but it stuck out about 1/16" of an inch after torquing it down. I reused the bolt that was on the engine, and it looks much better now. 30mm Kobalt socket was $6 at Lowes.
Wildthings
Wildthings is offline
PostPosted: Wed Aug 09, 2017 5:56 pm    Post subject: Re: Bolt On Sand Seal Reply with quote
You want to have 5 threads or so screwed into the end of the crankshaft. Maybe add an additional grade 8 washer under the head of the longer bolt, and/or grind a thread or two off of it.
limon
limon is offline
PostPosted: Wed Aug 09, 2017 7:15 pm    Post subject: Re: Bolt On Sand Seal Reply with quote
Thanks Wildthings. I didn't count how many threads are seated - if it's not enough - I'll "Stack" both washers on the longer bolt.
Wildthings
PostPosted: Thu Aug 10, 2017 5:35 pm    Post subject: Re: Bolt On Sand Seal Reply with quote
You just want to be 100% sure that the bolt doesn't bottom out in the hole. It also looks like one of your washers is concave, if you use two washer think carefully about which one to use where.
Bashr52
Bashr52 is offline
PostPosted: Mon Aug 14, 2017 4:24 am    Post subject: Re: Bolt On Sand Seal Reply with quote
You need that longer bolt due to the shim that goes between the crank and pulley. Without it the pulley with bottom out on the seal and destroy itself.
