Zeitgeist 13 Samba Member
Posted: Sun Sep 04, 2016 2:47 pm Post subject: Double DIN |
I would like to install a double DIN touchscreen head unit in our new '01 EV, but most of those DD installs I've seen have been on vans with the automatic climate control dashes. Mine has manual controls, so I'm wondering if there are any DIY install threads or reference sources out there. We would also like to install a rear view camera _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
markcm2 Samba Member
Joined: September 02, 2015 Posts: 505 Location: Bellingham, Washington
Posted: Mon Sep 05, 2016 8:04 pm Post subject: Re: Double DIN |
Zeitgeist 13 wrote: |
I would like to install a double DIN touchscreen head unit in our new '01 EV, but most of those DD installs I've seen have been on vans with the automatic climate control dashes. Mine has manual controls, so I'm wondering if there are any DIY install threads or reference sources out there. We would also like to install a rear view camera |
There is some discussion on this over at Vortex forum.
The bottom line is that some of our vans (like my 01 MV weekender) have a crash bar in the dash that would have to be cut to install a 2-DIN stereo. Apparently there is a version of crashbar which allows room for a 2-DIN, if you can find the other version of crashbar you could retro-fit it into your van. |
jjvincent Samba Member
Joined: January 11, 2016 Posts: 1268 Location: Bethlehem, PA
Posted: Tue Sep 06, 2016 9:31 am Post subject: Re: Double DIN |
Google: Eurovan Double DIN |
Posted: Tue Sep 06, 2016 9:59 am Post subject: Re: Double DIN |
I did, but I was unable to find any DIY threads that provided anything other than references to the support brace interference and pictures of the finished product. I'm not too keen on pulling the dash, but if I have to, I'll just do that and weld up my own cradle _________________ Casey--
y u rune klassik? |
Posted: Tue Sep 06, 2016 11:04 am Post subject: Re: Double DIN |
Thanks for posting that pic. It's helpful to see what mods I'll need to make. That's pretty much what I had in mind, even with no prior idea what the brace looked like. I figured it was going to be a big old steel tube like on the Mk4s
Cole's install is nice, but there's no info about the installation process. _________________ Casey--
y u rune klassik? |
Posted: Tue Sep 06, 2016 11:53 am Post subject: Re: Double DIN |
I would contact Cole at Cavevan. He's on here quite often. |
Posted: Tue Sep 06, 2016 3:51 pm Post subject: Re: Double DIN |
Good links, its neat that the service is offered but... $1500 once the bar is already removed to cut and weld, is that a typo with an extra zero?! |
Posted: Tue Sep 06, 2016 6:26 pm Post subject: Re: Double DIN |
Since this is more work than I had planned at these initial stages of the build, I'll just swap in the single DIN Kenwood from my Vanagon, and keep the double for another day when I'm ready to pull the dash. Routing the wiring for the backup camera probably requires gutting the interior anyway, so I could just combine those tasks in future phases. _________________ Casey--
y u rune klassik? |
Posted: Tue Sep 06, 2016 10:22 pm Post subject: Re: Double DIN |
Since this is more work than I had planned at these initial stages of the build, I'll just swap in the single DIN Kenwood from my Vanagon, and keep the double for another day when I'm ready to pull the dash. Routing the wiring for the backup camera probably requires gutting the interior anyway, so I could just combine those tasks in future phases. |
If you do go for the camera, I see lots of options for wireless these days, in the $20 price range. Here's an example |
Posted: Wed Sep 07, 2016 5:14 am Post subject: Re: Double DIN |
It's not like the double din is some must have thing. Pretty much a smartphone and a bluetooth radio will be suffice for what most people need. Also, double dins can catch the eye of a thief as opposed to some regular old radio. |
Posted: Wed Sep 07, 2016 10:24 am Post subject: Re: Double DIN |
jjvincent wrote: |
Good points, I have both. A 2-DIN Kenwood DDX6702s with carplay in my daily driver Audi A4 which is really nice yet in our van I have a stock VW Monsoon radio from our Passat (which I ended up putting in a 2-DIN in the passat as well).
The Monsoon Single DIN is a great radio, easy to operate, cheap on ebay (about $50) matches the van interior perfectly and has a CD changer port which we use an iPhone adapter from Amazon like this which provides a powered connection to our iPhones; prices on these adapters range from $20-50 so shop around and watch that you get the right connector for the head unit (blue or white, they are different) You also need to get the adapter with the older 30pin and then get a 30-pin to lightning adapter (MD824AM/A) because the ones the come with Lightning only charge the phone and you have to use the headphone jack for audio. Make sure its a real APPLE adapter, the knock offs don't pass audio. The adapter will start/stop play of the iPhone with the Van's ignition and charges the phone. This is honestly a really good option. We use a vent mounted iPhone holder for when we are using Maps and such. |
Itsamoto Samba Member
Posted: Wed Sep 07, 2016 11:10 am Post subject: Re: Double DIN |
markcm2 wrote: |
Cool - iIm very interested in this solution to keep a blue-clock look and feel to the dash. Can you post any pics? |
Posted: Wed Sep 07, 2016 11:42 am Post subject: Re: Double DIN |
Well...I drove it around today with the lower PNW temps, and got a whiff of coolant smell when the heater got warm. I suspect I'll be removing the dash sooner rather than later.
Our recent family trip in the Audi got us interested in a bigger navigation readout than an iPhone _________________ Casey--
y u rune klassik? |
Posted: Wed Sep 07, 2016 12:14 pm Post subject: Re: Double DIN |
My solution is the iPad Pro I got a while back and a flex mount. Then I can take it out and use it elsewhere. |
Posted: Wed Sep 07, 2016 4:26 pm Post subject: Re: Double DIN |
I pulled the crappy Pioneer unit that was in there today, and found that a Mk4 climate control surround appears to fit perfectly below where the DD will go. I just so happen to have the entire climate plenum from an '02 Jetta (Vanagon donor). _________________ Casey--
y u rune klassik? |
Posted: Thu Sep 08, 2016 9:03 am Post subject: Re: Double DIN |
Itsamoto wrote: |
markcm2 wrote: |
Pictures...
Masta Shake Samba Member
Joined: October 29, 2010 Posts: 198 Location: San Diego, CA
Posted: Thu Sep 29, 2016 9:22 pm Post subject: Soundstream VR-730B |
I'm going to try one of these soon. Soundstream VR-730B. Single DIN with a removable video screen that sits mostly below the unit as opposed to the motorized ones that sit above and block the A/C vents. It's rear view camera ready as well which is mainly why I want a video stereo. The eBay store I'm going to use offers a 2 year warranty. At $125 I figure 2 years is a decent deal. It's probably OK quality. Crutchfield still sells the brand, just not this unit. They make a version with a 10" screen buts it's kind of silly.
http://soundstream.com/product/vr-730b/
_________________ As a good friend told me when I got the Syncro: "Welcome to the an intense love/hate relationship". |
Posted: Sun Aug 20, 2017 8:31 pm Post subject: Re: Double DIN |
If anyone is interested, I just installed the SONY XAV-AX100 in my 01 Eurovan weekender and posted a write up in this thread
mkscott2 Samba Member
Joined: February 16, 2017 Posts: 90 Location: Cincinnati
Posted: Mon Aug 21, 2017 5:44 am Post subject: Re: Double DIN |
I love the integrated look of the Sony unit, however I thought I should post what I went with to be comprehensive. The two main reasons I did not go wit the Sony unit were cost and I did not like the idea of needing to look so far down to read and manipulate a double-din in-dash unit. I did quite a bit of research and the following goals came up along the way:
- Large touch-screen
- Store and play our entire music library
- Provide navigation
- Run Torque app for monitoring transmission temp, distance until tank is empty, and reading codes
- Safe and easy to use
- Reasonably priced: in the end, all goals were met (and then some) for about $100.00!
So here is what I came up with:
- Amp (free): stock headunit (previous owner still had it!), modified: see “audio”
- Tablet: Azpen A1040 (http://www.microcenter.com/product/459766/A1040_Tablet). Sort of an odd dimension for a 10” tablet as it is much wider when in “portrait mode” than your typical tablet. Perfect for getting a large screen without obstructing additional view of the road when mounted on top of the dash. Resolution is not the greatest, but I’m not using it to watch movies or play games. Quite inexpensive (~ $50 on sale) and it has the ability to pick up FM Radio.
- Power for tablet ($5): USB cable plugged into 12v adapter, hard-wired to its own ACC power
- Audio ($20): flat 3.5mm stereo cable, connected to a ground-loop isolator, and soldered to the cassette-tape input of the stock headunit’s circuit board. Old-school tape adapter with cable lopped off inserted to trick the headunit into taking input from the 3.5mm cable. Audio is actually decent with this set-up. Learned how to do this here: http://forums.vwvortex.com/showthread.php?4988871
- OBDII Bluetooth Adapter ($20): https://www.amazon.com/gp/product/B00YY7M4AO?ref_=cm_sw_r_cp_ep_dp_xWVnzbD5B3X96&pldnSite=1 , Also bought an OBDII extension cable so that I could route the adapter to fit perfectly into the blank switch spot in the dash.
- Apps ($5): so many out there, including some that do some of what I wanted, but not all on their own. I chose the following:
o Google Play Music: most of our music library fit on a 64g micro SD card
o Google Maps: with maps downloaded for use offline
o Torque Pro: well worth the $5, just as accurate as the ScanGauge per my tests
o Overlays: for placing buttons on the screen to easily access the above apps
o Auto Sleeper: tells the tablet to “wake” when power is detected (ACC), and sleep when power is cut
- Stand (free): just a wood platform bolted to an old plastic suction cup GPS stand as seen below:
