Centering Pressure Plate
gimmesomeshelter
gimmesomeshelter is offline
PostPosted: Thu Aug 10, 2017 7:07 pm    Post subject: Centering Pressure Plate Reply with quote
I've been told that the Brazilian pressure plates have a lot more slop than the German ones. I mocked up a German PP today. While it does have much less slop, it isn't perfect. How do I resolve this issue? Are there centering bolts I can use? Can a machinist balance and pin the PP to the flywheel so I have a reproducible reference points?
Cheers,
Paul
"I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman
anthracitedub
anthracitedub is offline
PostPosted: Fri Aug 11, 2017 5:12 am    Post subject: Re: Centering Pressure Plate Reply with quote
You might look around for a engine builder that can do dynamic balancing of your rotating assembly.
I've never had issues with the hole clearance through the mounting of the plate. But I'm sure you could machine some shoulder bolts to take up this small amount of space to ensure a precise, repeatable install... but is the juice worth the squeeze on a low rpm, low hp engine?
Bulli Klinik
Bulli Klinik is offline
PostPosted: Fri Aug 11, 2017 7:55 am    Post subject: Re: Centering Pressure Plate Reply with quote
The problem isn't so much the holes, it's that the ears on the perimeter of the plate are not a snug fit inside of the flywheel.
When I send my parts out to get balanced, I generally have the machine shop center the clutch, bolt it down and have two location pins drilled into the clutch and flywheel. That way it goes on the exact same way, is centered and doesn't affect the balance.
I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs
andk5591
andk5591 is offline
PostPosted: Fri Aug 11, 2017 11:53 am    Post subject: Re: Centering Pressure Plate Reply with quote
Just gonna take a stab if I were in your shoes. get some sheet metal that is damn close to what you need to fill the gap (aluminum flashing is pretty thing). Tape or glue it in place around the perimeter tabs so its centered and nail it down.
D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
Mr. OGPaint
Mr. OGPaint is offline
PostPosted: Fri Aug 11, 2017 10:41 pm    Post subject: Re: Centering Pressure Plate Reply with quote
This is a good approach
https://instagram.com/mr.ogpaint
Patrick Hall
Jacks
Jacks is offline
PostPosted: Fri Aug 11, 2017 10:48 pm    Post subject: Re: Centering Pressure Plate Reply with quote
Get six 8mm countersunk screws. They are commonly used on VW door hinges. Install the pressure plate using the screws in the mounting holes. Tighten well. With a center punch, strike the pressure plate in several places around the perimeter, forcing the pressure to swell in to the gap of the flywheel, giving a tight fit.
Jack Staggs
Actual name
modok
modok is offline
PostPosted: Sat Aug 12, 2017 12:25 am    Post subject: Re: Centering Pressure Plate Reply with quote
Two dowel pins is a good practical solution.
IMO, center it with feeler gauges.
