1970 Transporter - Alternating Current?
mfeinstein
mfeinstein is offline
PostPosted: Fri Aug 11, 2017 3:38 pm    Post subject: 1970 Transporter - Alternating Current? Reply with quote
I have a beautiful 1970 Transporter and am looking to expand the electricity options while traveling out of the vehicle.
I know there is the option to have a heavy weight power cord connected to the outside of the vehicle to get electrical power on the side panel on the inside - and I have such a cord. I also know that there is no cigarette lighter outlet in the front into which an adapter can be plugged in to get direct alternating current, the way many other vehicles of the era had.
My question is, is there anything in the front of the vehicle that can be modified in order to have it operate like the cigarette lighter outlets did in other older vehicles of that era, so that I could use that to use the vehicle's battery to charge my lap top computer and other such devices
Thanks
busdaddy
busdaddy is offline
PostPosted: Fri Aug 11, 2017 4:16 pm    Post subject: Re: 1970 Transporter - Alternating Current? Reply with quote
Welcome,
A cig lighter can be installed anywhere you like if you have basic wiring skills, but they provide direct current (12 volts), to make AC (110 volts) you'll need an inverter: https://www.thesamba.com/vw/forum/search.php?searc..._chars=200
Wildthings
Wildthings is offline
PostPosted: Fri Aug 11, 2017 4:49 pm    Post subject: Re: 1970 Transporter - Alternating Current? Reply with quote
Don't expect unlimited power from your battery and charging systems. They are absolutely tiny when compared to the Hoover dams and coal fired monoliths you are used to plugging your devices into. If you do not have a second "house" battery to store energy to handle these extra loads you may find yourself with an engine that will not start when you need it most.
Abscate Premium Member
Abscate is offline
PostPosted: Fri Aug 11, 2017 5:06 pm    Post subject: Re: 1970 Transporter - Alternating Current? Reply with quote
The phrasing here, needs work.
There is a great book on sailboat electrics by Don Casey that I recommend budding electrical techs read. If you carry boat practices into,your land yacht, you will have a really safe install.
.ssS!
BayCreamPuff
BayCreamPuff is offline
PostPosted: Fri Aug 11, 2017 5:32 pm    Post subject: Re: 1970 Transporter - Alternating Current? Reply with quote
If you want to run laptop and other devices you're in luck. They run on DC (the same current coming out of your car battery). Just buy a DC receptical and charger for your laptop (so it can plug into the outlet).
Inverters are good if you're trying to run something that only runs on AC and even then they're pretty inefficient. Charging a laptop from an inverter means you're converting DC -> AC -> DC.
Cream Puff
'79 CA Stock FI Deluxe Campmobile
Earl Grey
'87 Stock 2.1 Westfalia
busdaddy
busdaddy is offline
PostPosted: Fri Aug 11, 2017 5:55 pm    Post subject: Re: 1970 Transporter - Alternating Current? Reply with quote
BayCreamPuff wrote:
If you want to run laptop and other devices you're in luck. They run on DC (the same current coming out of your car battery). Just buy a DC receptical and charger for your laptop (so it can plug into the outlet)..
But many run more than 12 volts DC, like closer to 18 if I recall, unless the car charger incorporates some sort of step up converter (inverter) you may have a problem.
Little cig lighter size inverters can charge laptops through house current adaptors, but if you plan on making a latte and blow drying your beard while it charges you'll need more amps. Or a really really long extension cord.
SGKent Premium Member
SGKent is offline
PostPosted: Fri Aug 11, 2017 7:08 pm    Post subject: Re: 1970 Transporter - Alternating Current? Reply with quote
To charge different items I bought a 12V receptacle with heavy duty battery clips. It has about a 6' cable attached. Then used that on the battery to a plug-in 100 watt inverter. Then let the bus idle while charging big lithium batteries to be sure it didn't pull the car battery down. Worked like a charm. The only thing I still have to do is put a fuse inline even though the inverter has one. We use it when camping to charge things. Since things are charged when we leave home, they don't need to be recharged while driving on 1 - 2 day trips. The inverter draws about 9 amps at 12V DC to put out 100 watts at 120V AC.
from Amazon
machine work recommendations: http://kentcomputer.com/77VW/machinework.pdf
Pointers on rebuilding an engine:
http://kentcomputer.com/77VW/rebuilding_a_vw_engine.pdf
Setting Engine Timing: http://kentcomputer.com/77VW/Timing.pdf
KentPS Premium Member
KentPS is online now
PostPosted: Fri Aug 11, 2017 7:13 pm    Post subject: Re: 1970 Transporter - Alternating Current? Reply with quote
I bought this...
https://www.amazon.com/MEIDI-2-Socket-Cigarette-Sp...&psc=1
...and attached it with Velcro under the dash. Cut off the plug-in cigarette adapter, and splice it into a spare prong on your fuse panel. When you're done, you will not only have two cigarette outlets but, more importantly, two USB charging ports. It was very helpful on our camping trip.
Tom Powell
Tom Powell is offline
Thanks
There is no such thing as direct alternating current. I have a 12VDC cigarette lighter under the dashboard of my '69 camper and another on the jumpseat box. You can use those with a cord like this to charge your Apple laptop.
https://www.amazon.com/Magsafe-Adapter-Charger-Mac...le+charger
You can use this to charge your iPhone.
https://www.amazon.com/Charger-Adapter-Built-Light...ne+charger
These devices should be used with caution because there is no overcharging protection.
You can add a 12VDC cigarette outlet anywhere with this.
https://www.amazon.com/Foxnovo-Waterproof-Motorcyc...%3AFoxnovo
or this
https://accessories.lazydays.com/prime-products-du...WCEALw_wcB
Aloha
tp
Tcash
Tcash is offline
PostPosted: Sat Aug 12, 2017 8:09 am    Post subject: Re: 1970 Transporter - Alternating Current? Reply with quote
Welcome to TheSamba, Bay Window Bus Forum!
69-71 NEWBIE
Here is a little information. Good Luck
Pictures would be cool.
How to post photos/How to post a photo in the Forums
Pronunciation (Samba) English
I am thinking of buying a VW van
Cleaning+Rodents+Hantavirus
Up in smoke... Bus fires... don't let it happen to you!
M-Plate Location
M-Plate Decoder Volkswagen Type 2 Bus
Bus VIN / Chassis Numbers
Type 2/Bus Owner's Manuals
Bus repair manuals
Bus parts manuals
Early Baywindow Bus Parts Book
Late Baywindow Bus Parts Fiche
Type 2 Wiring Diagrams
Model and Year Variations
Type 4: Secrets Revealed
Distributor Parts & Specifications
PARTS INTERCHANGE MANUAL
Youtube Videos
There is a ton of information located at the top of the Forum section.
NASkeet
NASkeet is offline
PostPosted: Sat Aug 12, 2017 8:16 am    Post subject: Re: 1970 Transporter - Alternating Current? Reply with quote
Don't forget that a large proportion of the World's domestic AC single-phase electrical supplies, are nominally 240 Volts RMS, at a frequency of 50 Hz; unlike the USA which is 110 Volts RMS at a frequency of 60 Hz.
If your electrical equipment is frequency sensitive, there might be a problem!
Regards.
Nigel A. Skeet
http://www.vwt2oc.net
kreemoweet
kreemoweet is offline
PostPosted: Sat Aug 12, 2017 12:06 pm    Post subject: Re: 1970 Transporter - Alternating Current? Reply with quote
The standard USA domestic nominal supply voltage has been 240V nominal for something like the last 50 years. It is provided with a transformer center tap wire, giving two phases of 120V (not 110V). All V's RMS of course.
'67 bug: seized by the authorities
Wildthings
PostPosted: Sat Aug 12, 2017 12:11 pm    Post subject: Re: 1970 Transporter - Alternating Current? Reply with quote
Most of our small appliances run on 120v though, whereas small appliances elsewhere may well use 240V.
telford dorr
telford dorr is offline
PostPosted: Sat Aug 12, 2017 11:49 pm    Post subject: Re: 1970 Transporter - Alternating Current? Reply with quote
And the voltage is slowly creeping up. It's typically around 125 and 250 volts now. Many years ago, it actually was 110 volts, then increased to 115, 117, 120, etc. [The cynic in me thinks: instant revenue increase for power companies: P = EČ / R.]
'71 panel, now with FI
To steal ideas from one person is plagiarism; to steal from many is research - Steven Wright
All models are wrong; some are useful - George Box
More VW electrical at http://flowcon.us/td/ (available 9am to 9pm PST)
SGKent is offline
PostPosted: Mon Aug 14, 2017 10:07 am    Post subject: Re: 1970 Transporter - Alternating Current? Reply with quote
The bean counters find lots of little ways to jack up their profits. It is like their billing. The late charges actually make them money - many companies fish different billing dates trying to find the ones that customers will be late on. I am not making that up - I came from the credit industry before IT. Or like I sometimes wonder if the foamy gasoline throws the amount off a little. Air is cheap to introduce and I wonder what percentage of air stays in suspension 1%? 2%? 3%? Some stations a couple years ago here in California were caught pumping warm gasoline according to the news back then - warm fluids expand...
