Yet another engine rattle at idle..
Dogsled
Dogsled is offline
PostPosted: Fri Aug 11, 2017 5:54 pm    Post subject: Yet another engine rattle at idle.. Reply with quote
This is an AC Vanagon, but figured this forum may have some responses - same engine as late bays. Two videos, one before valve adjust, one after (with the Blue gloves). Engine warm, new cap & rotor, timing correct, valves set to zero C, then 1.5 turns preload; hydraulic lifters.
The weird rattle noise is most likely related to valve train, but what? Turns out #1 & #2 cyl were a bit too much preload (3T+), and #3 & #4 were a bit too loose, 1/2 to 1 T. After the adjustment, the noise changes a bit but...
Ideas?
Don't make a fuss, just get on the bus...
Wildthings
Wildthings is online now
PostPosted: Fri Aug 11, 2017 7:26 pm    Post subject: Re: Yet another engine rattle at idle.. Reply with quote
Dump some Marvel Mystery Oil into the crankcase and let it run for a bit and it should quiet down. You probably had your adjusters set at 2 turns and backed them off to 1 1/2 turn and they will need a while to pump back up.
Also starting an engine cold and then letting it run for only a short while is a sure way to get the lifters to leak down and then rattle bad the next time the engine is started.
Running synthetic oil will help keep the lifters (and the entire engine) clean and working their best. A high viscosity index oil like a 5w40 or 5w50 will help the lifters pump up quickly in a cold engine.
SGKent Premium Member
SGKent is online now
PostPosted: Fri Aug 11, 2017 7:33 pm    Post subject: Re: Yet another engine rattle at idle.. Reply with quote
fwiw the VW factory supplement on hydraulic lifters says tell the customer lifter noise is normal, just drive the car and it will eventually go away. Really it does say that.
*You can do it right the first time, or do it over, the choice is yours. It is a free country. As to brakes, steering, tires, axles etc. - you may only get one chance at doing it right.
* VW Buses and VW cars share many of the same systems but if you haven't owned a bus and maintained it for awhile, you really don't know how different it is.
