stubb1986 Samba Member
Joined: August 15, 2016 Posts: 32 Location: Wichita, KS
Posted: Sat Aug 12, 2017 8:33 am Post subject: 78 bus brake light blinking |
My right rear brake light blinks when the right blinker is on. Has done this since i bought it. I checked the wiring and everything looks factory nothing hacked up. The left one works like it should with no issue. The right side the blinker bulb looks to be a little dimmer than the left side. Any ideas? |
Xevin Samba Member
Posted: Sat Aug 12, 2017 8:44 am Post subject: Re: 78 bus brake light blinking |
I would start by cleaning all the ground connections (the ones to all the back/side lights) shiny clean. If that fails move on to the other spade connections. Also check for corrosion on the bulbs and tabs inside bulb socket. _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Posted: Sat Aug 12, 2017 8:56 am Post subject: Re: 78 bus brake light blinking |
As said, your problem is bad grounds. Clean everything up well and coat all the contact surfaces with a thin smear of dielectric grease. |
