orwell84 Samba Member
Joined: May 14, 2007 Posts: 2536 Location: Plattsburgh, New York
Posted: Sat Aug 12, 2017 4:11 pm Post subject: Re: AFR sensor on a Monza style muffler? |
Got it. Thanks! My Innovate unit plugs the O2 sensor directly to the gauge. Of course it is not long enough so I will have to buy an extension. |
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1602 Location: Indianapolis, IN
Posted: Sat Aug 12, 2017 1:26 pm Post subject: Re: AFR sensor on a Monza style muffler? |
read my whole thread linked above. i show how i wired and stored everything. On the Innovate brand AFR gauge i used. you dont have to run the O2 cable all the way forward. Its very straightforward _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
Posted: Sat Aug 12, 2017 1:21 pm Post subject: Re: AFR sensor on a Monza style muffler? |
Thank you, that's a big help. Did you have to add additional wiring to get the gauge to reach the dash, or was it long enough. I would imagine that it would be possible to lengthen the harness to the gauge provided the right gauge wiring was used. It's not like a CHT gauge. |
Posted: Sat Aug 12, 2017 1:00 pm Post subject: Re: AFR sensor on a Monza style muffler? |
I put mine only on the 3/4 side as I wanted a hotter exhaust reading and not in the muffler.
You can read my whole install write-up here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=676774&highlight= _________________ Rebuild your own FI Harness..My Harness
Posted: Sat Aug 12, 2017 10:26 am Post subject: AFR sensor on a Monza style muffler? |
I know this isn't the ideal setup as I would only be able to get readings for 2 cylinders. I was wondering where I should place it and if it would give me any worthwhile readings for tuning/jet selection. I know a collector style exhaust is probably better suited for this, but my current muffler is working well enough at the moment.
Thanks for the help |
