MRCRUZ73 Samba Member
Posted: Sat Aug 12, 2017 3:01 pm Post subject: Original made in Germany roof rack restoration |
So the other day I found this original made in Germany roof rack on a local Facebook garage sale page . The owner didnt know where or how there parents acquired it they found it in the garage as they were cleaning out the barn . The wood is shot but everything else is there .
I have removed the wood because its warped and split and broken in a few spots . But to take the wood off i had to remove the aluminum rivets.
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Sat Aug 12, 2017 9:23 pm Post subject: Re: Original made in Germany roof rack restoration |
Got all my new oak wood pieces cut and test fit along with my stained test piece too .
then I pulled all the oak out and stained all of the other pieces so I can seal them tomorrow afternoon.
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Mon Aug 14, 2017 11:46 am Post subject: Re: Original made in Germany roof rack restoration |
Stain/linseed oil etc, but no varnish as it will just peel! My '60's Volvo/VW rack is similar to yours.
_________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
lonotch Samba Padrino
Joined: August 28, 2004 Posts: 3304 Location: So. Cal. Oceanside GFK!
Posted: Tue Aug 15, 2017 6:38 pm Post subject: Re: Original made in Germany roof rack restoration |
You didn't need to remove the rivets to get the wood out or put new slats in if you were going to use all new wood. _________________ It's not about the window, it's about the people.
German Folks |
Posted: Fri Aug 18, 2017 5:52 am Post subject: Re: Original made in Germany roof rack restoration |
I managed to get a little more done on the roof rack today. Since I took out the original rivets I used aluminum binding screws that look like rivets.
here's with all new oak slats and the screws installed .
also I forgot to add that I sanded the frame down and resprayed it a color called titanium silver. |
Posted: Fri Aug 18, 2017 12:48 pm Post subject: Re: Original made in Germany roof rack restoration |
Those sex bolts look great. _________________ It's not about the window, it's about the people.
German Folks |
Posted: Fri Aug 18, 2017 5:32 pm Post subject: Re: Original made in Germany roof rack restoration |
lonotch wrote: |
Those sex bolts look great. |
Yes I agree , they were the closest thing to the original rivets I could get my hands on that looked original enough to use .I didnt want to use bolts with acorn nuts it wouldn't have had the same look . |
Posted: Sat Aug 19, 2017 4:44 pm Post subject: Re: Original made in Germany roof rack restoration |
Well i finally got the roof rack mounted on the beetle today and took it for a ride into town afterwards ! No wind noise till over 55mph and it wasnt horrible in any way.
markj60616 Samba Member
Posted: Sat Apr 21, 2018 5:48 pm Post subject: Re: Original made in Germany roof rack restoration |
Does anyone know what year or years this particular style of original VW made in Germany roof rack was offered as an option? _________________ 1970 Type 1
original paint
original interior
original engine
1978 Type 2 Panel Bus
original engine 2.0L FI
2014 Beetle 2.5L |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sun Apr 29, 2018 4:01 pm Post subject: Re: Original made in Germany roof rack restoration |
It ceased being printed in accessory catalogs in 58/59. In 1960 on all rack references were of the new steel models. _________________
EverettB wrote: |
FU#5 |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2388 Location: Seekonk,Massachusetts USA
Posted: Sun Apr 29, 2018 6:13 pm Post subject: Re: Original made in Germany roof rack restoration |
lonotch wrote: |
You didn't need to remove the rivets to get the wood out or put new slats in if you were going to use all new wood. |
How do you remove the wood with the rivets in place? _________________ Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
02/76 Beetle sedan |
