TMI seat cushions
kerian159
kerian159 is offline
PostPosted: Sat Aug 12, 2017 4:33 pm    Post subject: TMI seat cushions Reply with quote
OK stupid quest time. Just purchased TMI seat cushions for my westy and I'm trying to figure out which is which. I've got part #43-2004-B and 43-2004-S. I'm guessing the B=back and S=seat but somehow that looks wrong. Early 76 westy seats btw.
Thanks in advance
1976 Type II Westy P22 (Mine)
1969 Type I Autostick (Wife's)
"Growing older but not up!"
Tcash
Tcash is offline
PostPosted: Sat Aug 12, 2017 4:44 pm    Post subject: Re: TMI seat cushions Reply with quote
Thanks in advance
front middle or rear seat pads?
kerian159
PostPosted: Sat Aug 12, 2017 4:45 pm    Post subject: Re: TMI seat cushions Reply with quote
Front buckets.
kerian159
PostPosted: Sat Aug 12, 2017 7:15 pm    Post subject: Re: TMI seat cushions Reply with quote
Here's what I'm dealing with
[email protected]
Samba Peckerhead
PostPosted: Sat Aug 12, 2017 7:21 pm    Post subject: Re: TMI seat cushions Reply with quote
that looks like a back on a bottom. you'll want to use something over the springs, as that foam will turn to crumbs FAST
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
kerian159
PostPosted: Sat Aug 12, 2017 7:25 pm    Post subject: Re: TMI seat cushions Reply with quote
I was afraid someone would say that.
[email protected]
Samba Peckerhead
PostPosted: Sat Aug 12, 2017 7:57 pm    Post subject: Re: TMI seat cushions Reply with quote
backrest looks good. typically you'll want a couple layers of burlap on the spring surface if you use the foam. doesn't hurt to do it with the hair pads either, but the hair pads are more forgiving when used directly on the springs
Jake Raby wrote:
Brian wrote:
kerian159
PostPosted: Sat Aug 12, 2017 9:00 pm    Post subject: Re: TMI seat cushions Reply with quote
I've got burlap between the springs and foam
Tcash
Tcash is offline
PostPosted: Sat Aug 12, 2017 10:02 pm    Post subject: Re: TMI seat cushions Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?p=6748997#6748997
static
static is offline
PostPosted: Mon Aug 14, 2017 7:40 am    Post subject: Re: TMI seat cushions Reply with quote
...and it doesn't actually have to be burlap. Burlap is OEM, cheap and easily available but you don't have to use it.
You could use a scrap of carpet, for example.
I used a sheet of leather, because I just happened to have some around.
Like VW campers? Join us!
https://www.facebook.com/groups/2362239654/
kerian159
PostPosted: Mon Aug 14, 2017 8:11 am    Post subject: Re: TMI seat cushions Reply with quote
I went up to walmart and found a scrap of 43"x33" piece for $3 so i'm happy Smile
