Deedee22 Samba Member
Posted: Sat Aug 12, 2017 10:54 pm Post subject: Concerns on my 87 GL 4spd manual Subaru conversion (2.5) |
It's' been a long journey, took over a year and finally my van is back with the Subaru 2.5 conversion. I'm not sure how much detail I should go into here, but let's just say the process did not go smoothly at all. Ended up having to rebuild the transmission after the mechanic ran it with no fluid, etc etc. The whole process almost cured me of my vanagon fever, and now that I have it back I'm still not convinced. There's less joy but I'm hoping that not all is lost...
1. The gas pedal is really stiff. The engine is from a 2007 Legacy. There's a delay from pushing the gas pedal to actually getting the power and so starting out is always this moment of overreving and and even shifting into second gear can be rough too. Is there a way to cure this? I'd say the main issue is how stiff the gas pedal is. I asked my mechanic about it and he said there's nothing we can do. Is this true? I used to love driving my Van with the old engine. Going into first gear was such a pleasure. Like a boat, it was so intuitive and fun. This thing isn't fun at all, I'm stressing everytime I go from stop, and starting on hills is really hard. suppose I'll get used to it, but I don't want to get used to it, I want to love the thing, or atleast not swear under my breath every time. My wife doesn't even want to drive the thing.
2. I'm really surprised at how fast I'm into 4th gear, and once on the highway I'm past 3k RPM at 60mph. I had sort of thought that I'd be sailing away on a cloud at 70 mph, but with this I'm at 4000 RPM, and when I let off the gas you feel the engine slow very quickly. I assume that I'll have a lot more power on hills compared to the last one, but I thought I'd be driving in the 70s much easier as well. Definitely not the case here. Is that also something I can address? Should I have words with my mechanic about that, or is it reflective of him not doing an awesome job?
3. I tried turning on the ventilation for air and nothing is coming out. Is this normal in a Subaru conversion? I feel some air coming out at my shins but nothing coming out of the main vents. I'm assuming my AC is completely gone. Is that true or is it possible to rescue it?
I appreciate the help/info. I'm starting to wish I just rebuilt the old engine for a fraction of the price, because if this thing isn't fun to drive around like before it isn't worth it. I have a whole bunch of other questions as well, but I'll save those for later.
Thanks!
Dave |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Sun Aug 13, 2017 4:42 am Post subject: Re: Concerns on my 87 GL 4spd manual Subaru conversion (2.5) |
The transmission does not know what engine is there. So without rehearing, rpms will be identical. In other words if the WBX engine was turning 4000 rpm at 70, so will the Subaru engine. More power gets you to 70 quicker. More power will let you run taller gears on an incline.
As far as the accelerator. Is it still using a cable or is it now
flybywire? That will make a difference on how you troubleshoot it. _________________ ☮️ |
Posted: Sun Aug 13, 2017 5:25 am Post subject: Re: Concerns on my 87 GL 4spd manual Subaru conversion (2.5) |
Pictures of how your throttle cable is attached to your throttle body would help. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Sun Aug 13, 2017 6:11 am Post subject: Re: Concerns on my 87 GL 4spd manual Subaru conversion (2.5) |
Too light a throttle can be almost as annoying as too stiff - but if it is mechanical you should be able to find that 'sweet spot' you had before. I'd be looking at where it might be binding. As suggested a photo will help - then it may be a matter of disconnecting at various points to see just what is making it stiff.
High RPMs are not necessarily engine killers but I understand it feels better to cruise at a lower number. At least you now have to power to allow larger tires which help a bit. Re-gearing or adding an over-driven 5-speed, unfortunately, means $$$ & mechanics and it sounds like you may have had enough of that for now.
Did you have working AC before? What was the plan with the mechanic? |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
Posted: Sun Aug 13, 2017 6:19 am Post subject: Re: Concerns on my 87 GL 4spd manual Subaru conversion (2.5) |
I love my EJ25.
That rpm is just fine with that engine. I cruise control mine at 70-72mph (about 3900-4000 rpm) all day long (like 12 hours and more), and then all day long the next day. We do some long traveling. Many folks think they should be at lower rpm's and feel that they are over revving the Subie but it is very happy at that rpm range. I run mine at 5000 rpm in the mountains in third when I am in the rockies on the steeper twisty passes. Here in the appalachians I have enough torque to get over almost anything in 4th gear as long as I can keep above 3500 rpm. Just did it yesterday towing 1000 lbs. Do not be scared of 4000 rpm's.
The front ventilation system has no connection to the engine conversion. It should work exactly like it did before. The owners manual does a decent explanation of the really unintuitive controls.
We are here to help. You'll get it working well. _________________ Dave O
The Western Syncro build
Posted: Sun Aug 13, 2017 9:45 am Post subject: Re: Concerns on my 87 GL 4spd manual Subaru conversion (2.5) |
dobryan wrote: |
I love my EJ25.
That rpm is just fine with that engine. I cruise control mine at 70-72mph (about 3900-4000 rpm) all day long (like 12 hours and more), and then all day long the next day. We do some long traveling. Many folks think they should be at lower rpm's and feel that they are over revving the Subie but it is very happy at that rpm range. I run mine at 5000 rpm in the mountains in third when I am in the rockies on the steeper twisty passes. Here in the appalachians I have enough torque to get over almost anything in 4th gear as long as I can keep above 3500 rpm. Just did it yesterday towing 1000 lbs. Do not be scared of 4000 rpm's. |
Agreed, I am very happy with my 2.2 Sub and stock gearing. Maybe if one only drove in the flat lands where the wind didn't ever blow then longer gears would be suitable. |
Joined: April 29, 2015 Posts: 704 Location: Berkeley Ca
Posted: Sun Aug 13, 2017 10:54 am Post subject: Re: Concerns on my 87 GL 4spd manual Subaru conversion (2.5) |
Go Westy has a primer on your ventilation system, it can be confusing untill you figure it out. See their technical section. Throttle should be smooth, not hard to push. Have someone operate the pedal while you are in the back checking the linkage for smooth operation. Are ypu havind a issue with how your clutch ingages ae well? Maybe you have someone local who can drive your van to see how it feels to them? |
WillSharp Samba Member
Joined: November 02, 2016 Posts: 199 Location: US 80424
Posted: Sun Aug 13, 2017 2:51 pm Post subject: Re: Concerns on my 87 GL 4spd manual Subaru conversion (2.5) |
Many people will opt for a 0.82 taller 4th gear when doing a 2.5L subie conversion to bring RPMs down. A taller 3rd and 4th can also be done to really make a difference. This would of course require pulling the trans. out and having a shop put new gears in which would be a bit expensive.
A cheaper easier small solution may be upgrading to bigger tires (if you haven't already) This will give you a little bit more speed without any major service. However its not gonna make your van do 70mph at 2k RPMs.
Just a couple thoughts. Good luck! |
dlb154 Samba Member
Joined: December 27, 2006 Posts: 359 Location: Reno, NV
Posted: Sun Aug 13, 2017 4:27 pm Post subject: Re: Concerns on my 87 GL 4spd manual Subaru conversion (2.5) |
Deedee22 wrote: |
1. The gas pedal is really stiff. The engine is from a 2007 Legacy....
2. I'm really surprised at how fast I'm into 4th gear...
3. I tried turning on the ventilation for air and nothing is coming out. Is this normal in a Subaru conversion? ...
1) I believe your 2007 Legacy is a "drive by wire" throttle, not a cable to throttle body. That means electrical adjustments to the throttle are not a direct result of your foot movement. I don't have first hand experience with a drive by wire Subaru conversion but know it's far more complex than a cable to throttle body and requires some fine tuning to get the feel right.
2) RPMs are RPMs. Your Transmission is just spinning like it always did. Although you have more power, 1 RMP or 4000 RMPs is still the same at the transmission
3) No changes to the dash heater box controls (ventilation level) are touched during a Subaru conversion. Shouldn't be any different than what it was before your conversion. |
Posted: Sun Aug 13, 2017 5:00 pm Post subject: Re: Concerns on my 87 GL 4spd manual Subaru conversion (2.5) |
Thanks for all the responses. Yes this is a flybywire system, which I believe converts to electric at the actual engine? I'll take some photos, it definitely feels like there's friction in the pedal, as opposed to the lever that's on the engine, which is stiff but smooth. Almost as bad is the delay from when pushing the gas. Not sure if that's from the actual stiffiness or something else, but I'm guessing by the responses that it's not a typical characteristic of the suby conversion?
Sounds like I'll plan on the bigger wheels to see if that helps the RPM issue since I was planning on doing that at some point anyways. Would 16 inch be much better than 15 inch in that case, or does it even matter? I know that 17 inch is a possibility as well, if it does I'd consider it but I don't feel a need to go super big.
The AC wasn't working before I had the conversion, but was was thinking about getting it fixed at some point, but not sure if that's even possible now that I"ve converted engines. |
dlb154 Samba Member
Posted: Sun Aug 13, 2017 6:46 pm Post subject: Re: Concerns on my 87 GL 4spd manual Subaru conversion (2.5) |
Yes having working air conditioning is an option with your Subaru conversion. You need to mate the Subaru Compressor with the rest of the Vanagon components. Can be a simply as having connections between hoses and compressor modified and then going through the typical flush, new dryer, vacuum pump down, charge up system. Or it can be more involved with full replacement of hoses (the better option but more labor/parts/money). |
Posted: Sun Aug 13, 2017 9:00 pm Post subject: Re: Concerns on my 87 GL 4spd manual Subaru conversion (2.5) |
Do not confuse rim size with final tire diameter. The metal rim does not determine final tire radius size.
I have had a tranny with a taller fouth and third as was mentioned and it gave away the advantages of the EJ25 Please take my expensive experience to heart and just rev the sucker to 4-5000 and do not look back. Really! 👍😀
I am currently running 205/70/15 tires which are like 3% over stock and love the power. _________________ Dave O
Posted: Sun Aug 13, 2017 10:44 pm Post subject: Re: Concerns on my 87 GL 4spd manual Subaru conversion (2.5) |
dobryan wrote: |
I am currently running 205/70/15 tires which are like 3% over stock and love the power. |
OK so it's actually the tires more than the rim size. What are the advantages taken away? I didn't realize that the taller 4th would have drawbacks. I don't mind a little less power for better top speed/lower revving, but I have no idea on the cost. Does even doing the .82 4th gear have those same drawbacks that you mentioned? |
Posted: Sun Aug 13, 2017 11:15 pm Post subject: Re: Concerns on my 87 GL 4spd manual Subaru conversion (2.5) |
Deedee22 wrote: |
A lot depends on where you drive. My 2.2 Suby with stock gearing and 27x8.5r14 tires was okay at sea level, but at 7000' was pretty wimpy. I ended up going back to stock height tires to get that bit of power back.
Also I don't know if it is torque or HP which does the most damage to these transmissions. Going to longer gearing will cause the engine to have to put out more torque to achieve the same tractive effort and that might be more detrimental to the tranny than less torque and faster turning gears. |
Gizmoman Samba Member
Joined: September 10, 2011 Posts: 1554 Location: Nevada
Posted: Mon Aug 14, 2017 3:13 am Post subject: Re: Concerns on my 87 GL 4spd manual Subaru conversion (2.5) |
Please don't take this the wrong way but in reading your post, it sounds like you didn't do a lot of research before doing the swap. I also get the feeling you used a shop that doesn't do subi/vanagon swaps as a mainstay - there are many recommended shops listed here on the Samba that would have given you a better out-the-door feeling, not a "nothing we can do" attitude.
If the van had AC before and you didn't specify you wanted to have AC after, there's a good chance they didn't do the extra work required to hook it up. Again, a sign you didn't do enough research or clearly communicate with the mechanic.
As you are finding out, a somewhat modern engine swap into a 30+ year old vehicle is a huge undertaking and many things must be considered before stepping into it. This site as well as several others have huge amounts of information regarding engine swaps, what to expect and what to consider. Transmission ratios, tire sizes, AC, where you drive, what you carry/tow, or do with your van, etc.
I highly recommend you limp it over to one of these shops for their opinion and be sure to let them know your needs as clearly as possible;
http://www.rockymountainwesty.com/Vanagon_Subaru_C...Am-s8P8HAQ
https://smallcar.com/conversions/faq-for-vanagon-conversions.html. I'm sure there are several others that do solid work as well - just be sure they do swaps on a regular basis and have a good reputation - another thing to research.
Sounds like you have a good engine, a solid van, and a rebuilt transaxle. A good shop should be able to get the love back. _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Oversize spare carrier - stock location (no longer for sale). |
Posted: Mon Aug 14, 2017 6:45 am Post subject: Re: Concerns on my 87 GL 4spd manual Subaru conversion (2.5) |
Deedee22 wrote: |
dobryan wrote: |
If you want to play with lower revs then borrow someones larger set of tires and drive with them for a while, especially up long grades. Lowering the rpms for highway driving is not a good tradeoff for me. YMMV. _________________ Dave O
Posted: Mon Aug 14, 2017 9:27 am Post subject: Re: Concerns on my 87 GL 4spd manual Subaru conversion (2.5) |
Ok, fly by wire does make a difference in how to tell you how it should feel and where to look. After a certain year, many manufacturers used and all in one flybywire accel pedal. Here is a picture of mine. It is mounted in the driver's foot well and has been cut down to work with the Vanagon gas pedal. No cables, relay levers, or monkey action required. The pedal tension is from the spring in the unit itself.
Not knowing your configuration, they may have mounted the pedal/potentiometer under the van or in the engine compartment. They are then using the vanagon accel cable to operate the mechanism. Without the correct amount of leverage, I expect the pedal could be difficult to operate. they are designed to have your foot press down on them. I googled some images of the Subaru accel pedal and it does look similar to my vw one. _________________ ☮️ |
Jon_slider Samba Member
Posted: Mon Aug 14, 2017 12:17 pm Post subject: Re: Concerns on my 87 GL 4spd manual Subaru conversion (2.5) |
dobryan wrote: |
I agree with everything in the above post!
Just to repeat
1. I do NOT recommend taller 4th gear.
2. I do NOT recommend tires larger than 6% above stock. That means do NOT buy tires larger than 27" diameter.
3. It makes no difference what rim size you have, 14, 15, or 16, what matters is the diameter of the rubber.
4. It is NORMAL for a Vanagon to go 70mph@4000rpm, there is nothing wrong with that. It is actually GOOD for your motor and GOOD for your transaxle. They were designed to operate at those RPM.
5. Lowering RPM means more work for the motor and transaxle, they will NOT benefit.
6. Peak power is closer to 4000rpm than 3000rpm.
7. 5000rpm in 3rd uphill is FINE for your Subaru motor.
Bottom line, you spent money on a motor, and wish it made your van new. I felt the same when I started changing motors and transaxles on my vans. But it is not realistic. Many Many things are old on our vans. Installing one new thing, leads to other weak links in the chain breaking.
It is Normal that with a new Motor, your old tranny demonstrated it needed more Love ($)
Take a deep breath, imagine your happy place. Then go to another shop for a second opinion.
Chances are everything is as good as it can be.
Congrats on your 2.5 motor. It is a GREAT choice. _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
wasserbox Samba Member
Joined: April 08, 2008 Posts: 533 Location: Durango, CO
Posted: Mon Aug 14, 2017 12:32 pm Post subject: Re: Concerns on my 87 GL 4spd manual Subaru conversion (2.5) |
Deedee22 wrote: |
There's a delay from pushing the gas pedal to actually getting the power and so starting out is always this moment of overreving and and even shifting into second gear can be rough too. Is there a way to cure this |
Not sure about the stiffness, but this behavior is actually pretty standard with the drive-by-wire manual subarus I've been in.
The only thing is to get used to it and adjust your driving style to match.
I've noticed that with a lot of major purchases, the farther I get away from the point I spent all the money - the more I enjoy whatever it is |
Posted: Mon Aug 14, 2017 4:20 pm Post subject: Re: Concerns on my 87 GL 4spd manual Subaru conversion (2.5) |
Jon_slider wrote: |
4. It is NORMAL for a Vanagon to go 70mph@4000rpm, there is nothing wrong with that. It is actually GOOD for your motor and GOOD for your transaxle. They were designed to operate at those RPM. |
I agree with this strongly. In a normal car application the Subaru engine is going to put out X amount of torque on the average. If you put it in a Transporter with stock gearing it will still put out about the same amount of torque or maybe even less (don't know). If you go to longer gearing and/or bigger tires you are asking the engine to put out more torque under most all conditions. I can't say this is actually bad, but I strongly suspect that it is. |
