rallyview Samba Member
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32438 Location: Reading Pennsylvania
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17018 Location: Retired South Florida
Posted: Sun Aug 13, 2017 4:30 am Post subject: Re: Diesel bell housing to inline engine bolts source? |
What about the dealer? _________________ ☮️ |
Gizmoman Samba Member
Joined: September 10, 2011 Posts: 1554 Location: Nevada
Posted: Sun Aug 13, 2017 6:13 am Post subject: Re: Diesel bell housing to inline engine bolts source? |
Mcmaster Carr is a good source. I wish I had a list for you but I don't.
They have minimus as well but very fast shipping, usually next day. _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Oversize spare carrier - stock location (no longer for sale). |
gchristensen Samba Member
Joined: October 09, 2012 Posts: 84 Location: Sacramento Ca.
Posted: Sun Aug 13, 2017 7:41 am Post subject: Re: Diesel bell housing to inline engine bolts source? |
Iforget the size you need but go to arp's site and you can get single size bolt kits. You will probablyhave to order a couple kits but it gives you spares and arp fastners are top notch. I had to do this for my bell housing adapter on my 1980 transmission. _________________ Joining now is our new 1982 diesel. This is an ongoing project under construction. |
dkoesyncro Samba Member
Posted: Sun Aug 13, 2017 8:06 am Post subject: Re: Diesel bell housing to inline engine bolts source? |
Weddle Idustries, these guys have it all when it comes to this |
jet 02 Samba Member
Joined: March 11, 2011 Posts: 25 Location: Bakersfield, Cal.
rubbachicken Samba Member
Posted: Sun Aug 20, 2017 11:18 am Post subject: Re: Diesel bell housing to inline engine bolts source? |
i don't think there's m12 x 1.5 in there, m10 x 1.5 yes
my local ace hardware has them. _________________ lucy our westy
lucy's BIG adventure
meet 'burni'
619 201 0310 or 617 935 4182 |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6316 Location: Honolulu,Hawaii and France
Posted: Sun Aug 20, 2017 4:18 pm Post subject: Re: Diesel bell housing to inline engine bolts source? |
alika is quite correct, the bolts are not in there, i've wasted more than an hour looking
ALIKA T3 wrote: |
MarkWard wrote: |
What about the dealer? |
I'll give you a dollar if you can find the bellhousing bolts to engine on ETKA for the Vanagon. I looked for an hour, it's nowhere |
meet 'burni'
jet 02 Samba Member
Posted: Mon Aug 21, 2017 2:09 pm Post subject: Re: Diesel bell housing to inline engine bolts source? |
So I am not the only one that spent an hour on ETOS looking..
(Ersatzteil Order System) |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9895 Location: Orbiting San Diego
Posted: Mon Aug 21, 2017 2:32 pm Post subject: Re: Diesel bell housing to inline engine bolts source? |
Illustration 5-10 is supposed to have the fastener list but it is incomplete, having only a few, at the very bottom.
Then Illustration 134-10 has the 2 long bolts that also hold the starter.
Why the supposed list on 5-10 never got fixed, that is my question.
Mark |
Posted: Tue Aug 22, 2017 9:52 am Post subject: Re: Diesel bell housing to inline engine bolts source? |
This weekend, I found some European ekta site that has some m12 and m10 bolts listed without length at the bottom of the belhousing parts breakdown they are not called out on the drawing so I assume they were probably the bolts.
I took the list provided in the other thread and called two local vw parts counters. Both said they knew from experience that the parts would t be available to them and declined to even look the numbers up.
I would use that list but it's impossible to find a 122mm m12 bolt. I a 120mm will work.
?Waldo? Samba Member
Posted: Wed Aug 23, 2017 6:17 pm Post subject: Re: Diesel bell housing to inline engine bolts source? |
I've repurposed the single-use TTY head bolts for the 12mm bolts although they are a tiny bit shorter than the stock starter bolts. I've also repurposed the main bearing bolts for the 10mm ones. Those are an excellent match. |
