Early vs late bay beam tube distance
lightice
lightice is offline
PostPosted: Thu Aug 10, 2017 10:42 pm    Post subject: Early vs late bay beam tube distance Reply with quote
Hi guys, I know that the bolt patterns are different on the early and late bays.
But what about the distance between the tubes?
Are the early same as the splits or the same as the late bays?
Thanks in advance.
Tcash
Tcash is offline
PostPosted: Thu Aug 10, 2017 11:36 pm    Post subject: Re: Early vs late bay beam tube distance Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?p=1269469#1269469
cker5 wrote:
It's not a black and white answer. I have a 70' and had the same question. I have a replacement 69' beam and it has the same bolt pattern as my 70' beam but the 69' beam is actually wider than my 70' beam. It depends when the 69' was manufactured. VW changed the production line in August each year so if the bus was manufactured after August it could fit. Keep in mind that all beam widths are not created equal, VW had special shims made to fit beams that were wider (good luck finding them). You are out of luck if the replacement beam is too short.
lightice
lightice is offline
PostPosted: Fri Aug 11, 2017 12:08 am    Post subject: Re: Early vs late bay beam tube distance Reply with quote
Hi Tcash,
Actually what I meant was the distance between the 2 torsion leaf tubes, not the track width.
As per this image, but this is from someone who wants to make the bolt mounting plate.
brettsvw
brettsvw is offline
PostPosted: Fri Aug 11, 2017 3:56 am    Post subject: Re: Early vs late bay beam tube distance Reply with quote
The only differences are bolt pattern and the early bay beams are missing the brake servo mounting bracket.
My 59 kombi build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=635003&highlight=
My buggy build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=558601&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807
lightice
lightice is offline
PostPosted: Fri Aug 11, 2017 8:41 am    Post subject: Re: Early vs late bay beam tube distance Reply with quote
okay cool thank you!
Tcash
Tcash is offline
PostPosted: Fri Aug 11, 2017 8:44 am    Post subject: Re: Early vs late bay beam tube distance Reply with quote
Thanks in advance.
Ah, the early is the same as the Bays
Tcash
busman78
busman78 is offline
PostPosted: Fri Aug 11, 2017 9:21 am    Post subject: Re: Early vs late bay beam tube distance Reply with quote
Not exactly, they do not directly interchange due to the mounting bolt pattern. The late beams do not come with six holes, at least I have never seen one.
70-79 the mounting bolt pattern is the same, the 70 does not have the servo bracket.
68-69 beams will bolt to 64-67 splits, upgrade the split to ball joint or down grade your bay to king pin. Drawback being the ball joint front will cause the split to have a higher ride height.
There is something about the 63 and earlier beams that is different, I do not know what that is, whether width, bolt pattern or both.
Tcash
Tcash is offline
PostPosted: Fri Aug 11, 2017 9:58 am    Post subject: Re: Early vs late bay beam tube distance Reply with quote
Thanks in advance.
Tcash
lightice wrote:
lightice wrote:Hi Tcash,
Ah, I should have quoted this post!
hazetguy
hazetguy is offline
PostPosted: Fri Aug 11, 2017 10:12 am    Post subject: Re: Early vs late bay beam tube distance Reply with quote
neither.
the trailing arms are different --63 vs 64-67, so beam bushings and/or bearings are not interchangeable, but the width and bolt patern are the same 3/55 through 67.
Your crystal ball ain't so crystal clear
Parts and mechanical restoration services available. I restore and rebuild fuel pumps, distributors, spindles, etc.
Check my ads or send a PM.
lightice
lightice is offline
PostPosted: Fri Aug 11, 2017 9:10 pm    Post subject: Re: Early vs late bay beam tube distance Reply with quote
Okay cool thanks guys.
Conclusion:
So the tube distances are the same for 68-79.
If I want to mount the late beam to early bay, I'd need to fabricate a new mounting plate with the appropriate bolt patterns as per the CAD diagram.
Tcash
Tcash is offline
PostPosted: Sat Aug 12, 2017 8:35 am    Post subject: Re: Early vs late bay beam tube distance Reply with quote
Conclusion:
Need to know what year your bus is and if it is a 69, you are going to have to measure the width of the beam you have under there and determine if it has spacers or not under the mounting plates.
Front beams
Good luck
Tcash
brettsvw
brettsvw is offline
PostPosted: Sat Aug 12, 2017 9:38 am    Post subject: Re: Early vs late bay beam tube distance Reply with quote
Tcash wrote:
Thanks in advance.
Tcash
We are talking about type4 beams?
Editing to change mistake, I should be using early bay and late bay to describe type2 parts for buses 1968-79.
My 59 kombi build.
My buggy build.
busman78
busman78 is offline
PostPosted: Sat Aug 12, 2017 10:48 am    Post subject: Re: Early vs late bay beam tube distance Reply with quote
Thanks hazetguy, always wonder about that.
brettsvw, nope, these are Type 2 beams
lightice
lightice is offline
PostPosted: Sat Aug 12, 2017 11:16 am    Post subject: Re: Early vs late bay beam tube distance Reply with quote
Front beams
Tcash
Thanks for the link.
The beam that I intend to use for narrowing/lowering is from a late bay, but unsure which year. I'll have to measure up and follow your guide.
My original beam will be kept and stashed away in case I need it in the future.
In any case, the replacement beam would be cut and new mounting plates would be fabricated to fit.
@busman78
Brettsvw got me confused too in another thread. Laughing
@brettsvw
We are talking about bus beams, splits and bays and their mounting points and torsion leaf tube distances.
Alan Brase
Alan Brase is offline
PostPosted: Sat Aug 12, 2017 5:56 pm    Post subject: Re: Early vs late bay beam tube distance Reply with quote
brettsvw wrote:
Tcash wrote:
Thanks in advance.
Tcash
Uhh, you do not mean Type 4 beams.
Al
Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home
brettsvw
brettsvw is offline
PostPosted: Sun Aug 13, 2017 8:14 am    Post subject: Re: Early vs late bay beam tube distance Reply with quote
I apologize for the confusion. I have read numerous threads here referring to type2 from 1972-79 as type4.
I stand corrected and will try not to confuse anyone on this matter.
Back on topic. Early Bay verse Late Bay beam tube distance.
My 59 kombi build.
My buggy build.
busdaddy
busdaddy is offline
PostPosted: Sun Aug 13, 2017 8:59 am    Post subject: Re: Early vs late bay beam tube distance Reply with quote
Some 72-79 bays have a type 4 engine, but they are still a type 2 bus aside from what's in the engine compartment.
lightice
lightice is offline
PostPosted: Sun Aug 13, 2017 9:29 am    Post subject: Re: Early vs late bay beam tube distance Reply with quote
Anyone with more dimensions for this image?
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Sun Aug 13, 2017 1:24 pm    Post subject: Re: Early vs late bay beam tube distance Reply with quote
So... someone could use the earlier beam to lower a Bay window & still have full suspension travel?
busman78
busman78 is offline
PostPosted: Sun Aug 13, 2017 2:17 pm    Post subject: Re: Early vs late bay beam tube distance Reply with quote
Yes, it is called a downgrade to handling, for 68-69 as a bolt on, have no idea how much lower it would be, maybe somebody that has done it will pop in.
