Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Tue Aug 15, 2017 12:47 pm Post subject: What are the specs for '69 camper front wheel bearing seals? |
I'm installing front disc brakes from CSP on my '69 camper. The instructions call for a 62x50x7 bearing seal. A 62x45x8 seal for a '64-'67 looks like it makes a better overlap on the bearing and would be a better seal because it is wider.
What are the correct specs for the '69 camper.?
What are the consequences of using the '64-'67 seal?
Why does the 62x50x7 look like it is not wide enough to prevent grease form leaking past the inner part of the seal?
Aloha
tp
Aloha
tp |
Tcash Samba Member
Posted: Tue Aug 15, 2017 1:55 pm Post subject: Re: What are the specs for '69 camper front wheel bearing seals? |
Disregard my post. I figured it out myself. The earlier seal does not fit over the hub of the later spindle.
Aloha
tp |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16961 Location: San Diego, California
Posted: Tue Aug 15, 2017 6:55 pm Post subject: Re: What are the specs for '69 camper front wheel bearing seals? |
Bearing supply houses should be able to help _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Tue Aug 15, 2017 7:33 pm Post subject: Re: What are the specs for '69 camper front wheel bearing seals? |
aeromech wrote: |
Bearing supply houses should be able to help |
The instructions with the kit from CSP had the specs for early and later bays and supplied two sets of seals, one for each type of spindle. It's just that the earlier/wrong seal was in the rotor box that I opened first and looked good when installed. I didn't realize my mistake until one side was done, but wrong. I had to take the finished job apart and do it right.
I'm glad I was on my driveway and not yours and I had the time and help to do the job right.
Aloha
tp |
Posted: Tue Aug 15, 2017 7:48 pm Post subject: Re: What are the specs for '69 camper front wheel bearing seals? |
Geez, thanks
I know you really didn't intend for that to sound the way it came out _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Wed Aug 16, 2017 6:24 pm Post subject: Re: What are the specs for '69 camper front wheel bearing seals? |
aeromech wrote: |
Geez, thanks
I know you really didn't intend for that to sound the way it came out |
What I meant was, I f...ed it up by putting in the wrong seal. My daughter was willing to help me to undo my bad and do the job right. If you and I had been doing the job, you wouldn't have made the mistake or I would have gotten an admonishment, mechanic to pilot for the mistake I made.
RTFIATC
Why do pilots have square shoulders and flat heads?
Aloha
tp |
