cocopuffsman Samba Member
Dale M. Samba Member
Posted: Tue Aug 15, 2017 2:24 pm Post subject: Re: Stripped Axle Bolt |
Personally I would replace axle.... Cleaning up threads and praying may not keep drum and wheel on...
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Tue Aug 15, 2017 2:26 pm Post subject: Re: Stripped Axle Bolt |
Dale M. wrote: |
Dale |
Agreed.
Swing or IRS?
A lot easier if IRS. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Aug 15, 2017 2:31 pm Post subject: Re: Stripped Axle Bolt |
Brake drum splines look pretty questionable too....
Maddward Samba Member
Joined: July 18, 2010 Posts: 206 Location: Orange County, CA
Posted: Tue Aug 15, 2017 2:42 pm Post subject: Re: Stripped Axle Bolt |
I vote new axle and drum. The drum splines look almost non existent? |
Posted: Tue Aug 15, 2017 3:23 pm Post subject: Re: Stripped Axle Bolt |
Well the splines from the backside of the drum look ok. The 2nd picture with the drum still on looked bad...must have been a popsicle illusion |
Posted: Tue Aug 15, 2017 3:25 pm Post subject: Re: Stripped Axle Bolt |
This pic tells me you have more problems.... It appears you are running long spline axles and with short spline drums... See hammered (silvery) area???...... Should not look like that... It indicates loose nut on axle....
Also in pics there is exposed splines on a axles with drums in place, you do have all the correct spacers on axle and spacer between nut and drum???? Please tell me you do!!!
Posted: Tue Aug 15, 2017 3:31 pm Post subject: Re: Stripped Axle Bolt |
Dale M. wrote: |
Dale |
yea the car came like that with some spacers to use these drums never thought anything of it as this is my first vw _________________ https://www.youtube.com/watch?v=z5HSYpTKrUg
https://youtu.be/z5yDe0MKzYw
https://youtu.be/MpJoZYZNLLI
https://youtu.be/m8-rsKIvbos
https://youtu.be/bfYDA3-N0fg |
Posted: Tue Aug 15, 2017 3:39 pm Post subject: Re: Stripped Axle Bolt |
IN image of drum it looks as if spacers were not thick enough as drum was sliding back and forth on axles... Splines on axle and in drum are polished look from movement as if axle nut was not tight... Large axle nut torques to 217 ft-lbs (294.2129 N.m) ... And ADDITIONAL torque to get hole in axle lined up with slots in nut for cotter pin....NOT loosen nut till you get hole and slot aligned for cotter pin...
Also were you using pneumatic impact to put nuts back on with???... Be cause it was definitely cross threaded and I have serious doubt you are not going to do that much damage with "hand tools"... It should have been easy turning up to point nut contacted spacer and drum...
allenw Samba Member
Joined: September 20, 2016 Posts: 221 Location: Dalton, GA
Posted: Tue Aug 15, 2017 3:48 pm Post subject: Re: Stripped Axle Bolt |
Anti seize Works good on threads to keep them from galling like that. Welcome to the world of what the PO did to your bug. |
mark tucker Samba Member
Posted: Tue Aug 15, 2017 4:08 pm Post subject: Re: Stripped Axle Bolt |
if it's a lot hp budget bug,I would shorten the spacer so a new nut would grabb all the good splines that are there.then fix/deburr/remove the fucked up threads and install the nut to see how much the spacer needs shortening then shoprten it 1.5 rev less, install the nut, torque and go about your bizness. if it's a high hp bug change the axle.and the drums and all the other dead crap you find on both sides. |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3446 Location: San Diego
Posted: Tue Aug 15, 2017 4:27 pm Post subject: Re: Stripped Axle Bolt |
That axle is def toast. Check the other side as well. Motor and trans need pulled to fix it |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Tue Aug 15, 2017 5:10 pm Post subject: Re: Stripped Axle Bolt |
cocopuffsman wrote: |
where should I buy a new axle if all else fails? |
Classifieds.
There are three different axles for a beetle. Short axles, long axles with short splines, and long axles with long splines. The drums and other hardware don't all mix. You need to know what all the parts on the car are (axle tubes, axles, drums, and brakes) before you start buying parts. Not as complicated as it sounds. Post some more pics so we can see what you were supposed to have.. _________________ modok wrote:
