gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Tue Aug 15, 2017 11:08 pm Post subject: Why aren't oil coolers made of copper? |
I was reading up on the different materials used to make heat exchanges when I noticed that copper dissipates heat much faster than aluminum. https://en.wikipedia.org/wiki/Copper_in_heat_exchangers If this is the case, why aren't our oil coolers made from copper? Cost? Durability?
Cheers,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Wed Aug 16, 2017 4:18 am Post subject: Re: Why aren't oil coolers made of copper? |
Copper gets brittle over the years and heat cycles. _________________ Glenn
Member #1009
#BlueSquare |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Posted: Tue Sep 12, 2017 7:35 pm Post subject: Re: Why aren't oil coolers made of copper? |
Also, "Copper conducts heat better than aluminum, but heat dissipation is quicker in Aluminum". This means that copper will pull the heat out of the oil better then aluminum. However, in an air environment, copper tends to hold onto the heat, where aluminum will shed it quicker. So its one of those things that is a compromise, in cost and longevity. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
