John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13952 Location: Southampton U.K.
Posted: Wed Aug 16, 2017 9:09 am Post subject: 6 Volt Indicators |
If you have one of these…a 6 volt Thermal Turn Signal Relay…get rid of it.
Most people I know with 6volt electrics have often had lighting problems and the turn signals on my ’58 have always been unreliable…sometimes they work, sometimes not.
In my experience these thermal relays have an annoying habit of throwing you off the track when trying to solve the problem. Understanding how the indicator circuit works, you apply logic and it defies you, (pun intended) at every turn
The most recent symptom to tackle was left-turn signal not working; right-turn signal working. Seemed like a simple ground issue on the front bullet…everyone tells you most 6volt lighting issues are ground issues. It couldn’t be the relay as there is a single wire from the switch to relay to operate both left and right.
That throws suspicion on either ground for left bullet or loose or disconnected left wire in the switch. Logical really. I rigged an auxiliary ground from the left bullet to the ground on the horn mounting in the trunk. No change. Next I take the column switch apart to examine the contacts and the mechanical mechanism. All looks good, I lubricate and reassemble. When I test the indicators the left indicators comes on but doesn’t flash…try the right, they come on but don’t flash. For the first time the finger points at the Indicator Relay, the last suspect is the culprit.
I bought the Wofsburg West electronic relay from VW Heritage here in the UK…
The transformation was instant…the sense of relief that you’re now going to be able to make your intentions clear…the flash-rate is the same as a modern car.
We all know how vulnerable we are in modern traffic and moderate our driving to compensate for out-dated equipment. Today I feel a little safer. _________________ John.
PeteSC Samba Member
Posted: Wed Aug 16, 2017 9:45 am Post subject: Re: 6 Volt Indicators |
Agreed; those WW 6v relays work well. I bought two when I ordered my replacement so I'd have a backup. |
Karly Samba Member
Joined: August 01, 2002 Posts: 641 Location: Australia
Posted: Wed Aug 16, 2017 7:40 pm Post subject: Re: 6 Volt Indicators |
Agreed I fitted one recently to my bug ...at the time the indicators would work but the flash rate wasn't consistent and sometimes incredibly slow. Now they simply work as they should! _________________ 1960 Beetle ''Heidi" daily driver
1964 Karmann Ghia project |
