barefootwestie Samba Member
Joined: September 19, 2005 Posts: 1551 Location: Johns Island, SC
Posted: Wed Aug 16, 2017 9:23 am Post subject: Unknown Engine Tin Hole |
Have been repainting and putting things back together, and am having trouble locating the correct grommet for the hole to the right of the "D". It appears to be 18-20mm but I haven't found a part number yet for it
Any help would be appreciated.
_________________ My Bus Restoration Blog
https://myvolkswagenbus.com/
1973 Westfalia
"Getting better....one repair at a time."
Other VW's owned through the years, in no particular order:
'67 Beetle,
'67 Ghia Hardtop,
'72 Ghia Convertible,
'72 Westfalia |
Posted: Wed Aug 16, 2017 9:32 am Post subject: Re: Unknown Engine Tin Hole |
Thanks. You always pull through for me. It's been a long time since I've been on. Life changes and things take a backseat sometimes. But trying to get her back up and running after dropping the set screw for the points in the engine tins.
Had to take the tins off to get to it, so might as well paint them. 3 years later ...
Thanks _________________ My Bus Restoration Blog
1973 Westfalia
'67 Beetle,
'67 Ghia Hardtop,
'72 Westfalia |
airkooledchris Samba Member
Posted: Wed Aug 16, 2017 9:37 am Post subject: Re: Unknown Engine Tin Hole |
Is that not the location for the fuel pressure regulator to mount?
Is this tin original to your 73 carb'd bus? |
Posted: Wed Aug 16, 2017 10:11 am Post subject: Re: Unknown Engine Tin Hole |
Yes, as far as I know.
Not sure what happened to the response I received earlier from hazetguy. The post disappeared. But he had said it was alternator, so checking that out. _________________ My Bus Restoration Blog
1973 Westfalia
'67 Beetle,
'67 Ghia Hardtop,
'72 Westfalia |
busdaddy Samba Member
Posted: Wed Aug 16, 2017 12:11 pm Post subject: Re: Unknown Engine Tin Hole |
I'll have a look next time I'm near a 73 to confirm, I suspect it's for the EGR vacuum line that goes to the Tee in the brake booster line upstream of the check valve. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
richparker Samba Member
Joined: November 24, 2011 Posts: 6983 Location: Durango, CO
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Wed Aug 16, 2017 6:44 pm Post subject: Re: Unknown Engine Tin Hole |
Sorry for the confusion/quick edit/delete.
The pic i originally posted:
Wasn't sure if that was accurate info. There are not as many holes in my tin.
Other views:
_________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money
Posted: Wed Aug 16, 2017 6:51 pm Post subject: Re: Unknown Engine Tin Hole |
If I remember correctly, the alternator comes up through the tin near. The passenger side heater hole. I'll go ahead and order all my other grommets and get everything back together and then we'll see whats left.😀 _________________ My Bus Restoration Blog
1973 Westfalia
'67 Beetle,
'67 Ghia Hardtop,
'72 Westfalia |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Wed Aug 16, 2017 7:35 pm Post subject: Re: Unknown Engine Tin Hole |
That is the hot air pre-heat ducting path for 1700 and 1800 dual carburetor engines.
You're talking about the hole next to it? Wiring harness path for alternator. Grommet hard for me to find.
Posted: Wed Aug 16, 2017 7:36 pm Post subject: Re: Unknown Engine Tin Hole |
It's all coming back to me now, Hazetguy's pic is correct, the heavy alternator wire to the starter does go there. The alternator harness does come up near the booster fan tube, then it splits and goes up to the regulator while the big wire continues forward to the starter. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Whaanga Samba Member
Joined: May 07, 2016 Posts: 629 Location: Rochester, NY
Posted: Wed Aug 16, 2017 8:58 pm Post subject: Re: Unknown Engine Tin Hole |
Not sure how to repost a quote or copy a photo from a former post but --- what is the purpose of the vertical conduit attached to the back of the tin shown in Hazetguy's photo that attaches to the cup/dish like fixture on the engine side of the fire wall?
I dropped my Type 4 engine this past spring and came across this apparatus. I cleaned it up and painted it but am not clear of its function. Any help would be appreciated. Thanks
https://www.thesamba.com/vw/gallery/pix/411712.jpg
https://www.thesamba.com/vw/gallery/pix/411717.jpg |
Posted: Wed Aug 16, 2017 9:15 pm Post subject: Re: Unknown Engine Tin Hole |
It supplies hot air off the #1 cylinder to the carbs to speed warmup after a cold start. |
Posted: Wed Aug 16, 2017 9:52 pm Post subject: Re: Unknown Engine Tin Hole |
Wildthings wrote: |
...and I use it as a hot air feed to my controversial Weber Progressive. |
Posted: Thu Aug 17, 2017 4:21 am Post subject: Re: Unknown Engine Tin Hole |
Got it- is the warm air released into the engine bay in general or is there some kind of added attachment or duct work that directs the warm air directly on to the carb(s)? |
Posted: Thu Aug 17, 2017 4:49 am Post subject: Re: Unknown Engine Tin Hole |
Flex tube connects from donut up to air box. Hot air not dumped into engine bay. Search out 1972-1974 PDSIT dual carburetor. |
Posted: Thu Aug 17, 2017 4:51 am Post subject: Re: Unknown Engine Tin Hole |
Whaanga wrote: |
No, definitely not directly into engine compartment. Originally, there was an airbox that the duct fed into, with additional attachments. I don't have pictures readily available, but have been collecting the parts through the years to go back original to solve the heat in the winter/progressive issue.
On the engine side, there is another piece of metal that bolts to it and then the other end is formed into a circle. Then the airbox attaches to that piece.
[EDIT]
Actually it appears in this photo supplied earlier.
1973 Westfalia
'67 Beetle,
'67 Ghia Hardtop,
'72 Westfalia |
Posted: Thu Aug 17, 2017 4:58 am Post subject: Re: Unknown Engine Tin Hole |
Thanks Guys for the help. Will post some photos of the newly painted engine bay today.
Had to pull my tins again last night to respray, because after painting and reinstalling, SOMEONE got overly excited when he tested the new paint on the engine bay and didn't fully tape everything like he should have. oops, a little overspray. lol.
Oh well, time spent on the bus is better than time spent in the office.
Chek out the pics here: https://www.thesamba.com/vw/forum/viewtopic.php?p=8532064#8532064 _________________ My Bus Restoration Blog
1973 Westfalia
'67 Beetle,
'67 Ghia Hardtop,
'72 Westfalia |
