ohhorob Samba Member
Joined: September 26, 2013 Posts: 212 Location: Santa Cruz
Posted: Wed Aug 16, 2017 8:29 pm Post subject: [Fixed!] Radiator Leak outside Twin Falls, ID |
I've loaned my van to my Uncle & Aunt that are on a 2 month road trip (starting with Eclipse chasing in Wyoming).
This evening they had the temp light come on, and pulled over. Found small leak in the radiator.. looks like a stone hit it?
Trying to get them to a radiator repair place tomorrow.
Any advice on vanagon radiator repair or replacement in/around Twin Falls, ID?
It looks like enough coolant was lost that the temp led is flashing for low coolant level. If they fill it up at the pressure tank would that work, or is it likely to need a flush now? _________________ "Gundy" - '85 Westfalia
GoWesty 2300cc, Digijet
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Wed Aug 16, 2017 8:56 pm Post subject: Re: [on-the-road] Radiator Leak outside Twin Falls, ID |
Does not need a "flush"... Repair/replace rad, replace lost coolant, bleed & drive.
Or...crack open the pressure cap & run with no pressure if necessary.
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
danfromsyr Samba Member
Posted: Wed Aug 16, 2017 9:49 pm Post subject: Re: [on-the-road] Radiator Leak outside Twin Falls, ID |
to get down the road you just need to stop the flow/loss from the damaged tube. remove the fins for about 1-2in on both sides of the damage. and with long nose pliers and possibly some sealant goop, fold the tubes flat and then back over themselves.
do the radiator cap (coolant bottle cap) trick to alleviate internal pressure from heat expansion.
http://www.surfacezero.com/g503/showfull.php?photo=196616
Tubular type core repair
Abscate wrote: |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10248 Location: N. Idaho
Posted: Thu Aug 17, 2017 7:35 am Post subject: Re: [on-the-road] Radiator Leak outside Twin Falls, ID |
Yeah, I'll second for the Subaru product. If they were here in Coeur d'alene ID, I'd grab mine off the shelf. I always carry it on road trips.
Doug _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
vwjetboat Samba Member
Posted: Thu Aug 17, 2017 7:38 am Post subject: Re: [on-the-road] Radiator Leak outside Twin Falls, ID |
gently pinch off.. and ad bars leak.. |
Posted: Thu Aug 17, 2017 8:21 am Post subject: Re: [on-the-road] Radiator Leak outside Twin Falls, ID |
I'm not a fan of coolant/radiator stop leak additives
this radiator is already damaged and needs to be replaced.
pinch off the tube and get it to repair..
or like my uncle, pinch off the tube and drive it for 5 more years.. it doesn't 'need' all of the cores right?
if done with some aptitude it'll run for the rest of their travels with the pinched off tube.. but always a worry.
Abscate wrote: |
Jeffrey Lee Samba Member
Joined: February 04, 2014 Posts: 1488 Location: Wisconsin
Posted: Thu Aug 17, 2017 8:42 am Post subject: Re: [on-the-road] Radiator Leak outside Twin Falls, ID |
In my early years of learning to wrench (as opposed to my latter years of learning, now over a quarter century later), one of my mentors told me that he once had a Triumph Spitfire with a leaking radiator. He let it cool, and added a couple tablespoons of ground black pepper to the radiator, then idled the engine again. As he watched, the stream of leaking coolant became a trickle, then stopped entirely.
I asked how long that would hold?
“Mmm-mmm,” he shrugged, “that was ten years ago, and my ex-girlfriend is still driving it …” _________________ Camp Westfalia
Camping Tips • Newsletter • Cool Campervan Apparel
www.CampWestfalia.com |
Posted: Thu Aug 17, 2017 8:46 am Post subject: Re: [on-the-road] Radiator Leak outside Twin Falls, ID |
danfromsyr wrote: |
no it does not need them all.. you can cut out 5-10 and really not affect performance.. ( 2l years at Robbins radiator in daytona .. 1year in Robins radiator in deland and 3 years at Allmans radiator in south daytona) I have cut my share out.. |
Posted: Thu Aug 17, 2017 8:48 am Post subject: Re: [on-the-road] Radiator Leak outside Twin Falls, ID |
and actually ya dont cut them out.. you pull them out at each end of the header and then solder the hole up.. fixed 100% |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2795 Location: North Carolina
Posted: Thu Aug 17, 2017 8:51 am Post subject: Re: [on-the-road] Radiator Leak outside Twin Falls, ID |
Many years ago, I "fixed" a leaking radiator on a Chevy g20 by jamming a bar of ivory soap against the leak. It actually did get me the 30 or so miles i had to go still. Was suggested by somebody who pulled over to assist, I was pretty surprised it worked _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
Posted: Thu Aug 17, 2017 9:14 am Post subject: Re: [on-the-road] Radiator Leak outside Twin Falls, ID |
Thanks for all the input
We've been put in touch with some local Vanagon owners and they have a used replacement available.
They're catching up soon to crush-repair the leaky one and drive somewhere to do the swap and bleed the air out. _________________ "Gundy" - '85 Westfalia
GoWesty 2300cc, Digijet |
Posted: Thu Aug 17, 2017 9:29 am Post subject: Re: [on-the-road] Radiator Leak outside Twin Falls, ID |
ohhorob wrote: |
They're catching up soon to crush-repair the leaky one and drive somewhere to do the swap and bleed the air out. |
excellent |
Posted: Thu Aug 17, 2017 9:38 am Post subject: Re: [on-the-road] Radiator Leak outside Twin Falls, ID |
Take an old cap, drill through the bottom so that it will not hold pressure and then toss it into the glove box. This may be all or most of what you need to get home when you have a coolant leak. |
Posted: Thu Aug 17, 2017 4:17 pm Post subject: Re: [Fixed!] Radiator Leak outside Twin Falls, ID |
Thanks to friendly and incredibly generous locals, they're back on the road
Quite the helpful community around these rolling rubik's cubes, both here and in real life! _________________ "Gundy" - '85 Westfalia
tjet Samba Member
Posted: Sun Jul 19, 2020 2:55 pm Post subject: Re: [on-the-road] Radiator Leak outside Twin Falls, ID |
Wildthings wrote: |
That's a good idea. That Bars stuff can cause long term damage.
A side note, the newer OEM coolants have a sealing additive built in. VW G13 has it. You will see a white powdery formation after it drys from a leak |
