Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Thu Aug 17, 2017 12:33 pm Post subject: front clip -1972 to 1978 |
I have a brief opportunity to part out a 1972 bus. Is the front clip on a 1972 model compatible with a 1978 from bumper rail to windshield? |
chabanais Samba Member
Posted: Thu Aug 17, 2017 12:55 pm Post subject: Re: front clip -1972 to 1978 |
Isn't the nose of a 72 the same as that of a 71? _________________ "I spud therefore I yam." |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Thu Aug 17, 2017 1:14 pm Post subject: Re: front clip -1972 to 1978 |
chabanais wrote: |
Isn't the nose of a 72 the same as that of a 71? |
Yes. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Thu Aug 17, 2017 2:26 pm Post subject: Re: front clip -1972 to 1978 |
Wasted youth wrote: |
no _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Thu Aug 17, 2017 3:31 pm Post subject: Re: front clip -1972 to 1978 |
Ok, folks. Thanks! I know that 1972 is a transition/one year only type of situation.
Next: How about the slider door? Will that hardware and door transfer over to the 1973 model?
Will the windshield fit to the 1973? |
Posted: Thu Aug 17, 2017 7:06 pm Post subject: Re: front clip -1972 to 1978 |
Windshield fits
IIRC, the key mechanism changed from 72 having it in the handle to the 73 having it just below the handle _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Thu Aug 17, 2017 7:32 pm Post subject: Re: front clip -1972 to 1978 |
OK, my 1973 has it in the handle. My 1977 had it seperate and below. At some point, the sliding doors changed I think. I have a sliding door that I just could not get to fit on my 1970 bus. |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Fri Aug 18, 2017 6:57 am Post subject: Re: front clip -1972 to 1978 |
The sliding door changed between 1973/74. So, the '72 and '73 should have the same sliding door mechanism. In '74 VW moved the lock cylinder out of the handle into it's own place below the handle.
I happen to have a '72, '73, and '74 under my stewardship at the moment. '75, too, but it's a pickup, so no sliding door on that one. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Malokin Martin Samba Member
Posted: Fri Aug 18, 2017 7:06 am Post subject: Re: front clip -1972 to 1978 |
It will work but not very well. |
Posted: Fri Aug 18, 2017 1:26 pm Post subject: Re: front clip -1972 to 1978 |
Malokin Martin wrote: |
So probably better than most. _________________ "I spud therefore I yam." |
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1602 Location: Indianapolis, IN
Posted: Fri Aug 18, 2017 2:13 pm Post subject: Re: front clip -1972 to 1978 |
I have a lock in handle slider door on my 77. I don't remember what year I pulled it from, but it mounted right up and worked just fine _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
