runge9524 Samba Member
Joined: August 23, 2007 Posts: 470 Location: browns valley ca
Posted: Thu Aug 17, 2017 2:24 pm Post subject: Routed oil filter lines backwards... |
I was wondering why my cooler always stayed cold, there wasnt any oil in it due to my backwards routed oil filter adapter. The engine sounds like it may have a quiet knock but its hard to tell over my loud exhaust, there is some fine silver sparkles in the oil, but it may be rings ( only 200 miles since new rings pistons and cylinders. This is my ghetto job haha
vwjetboat Samba Member
Posted: Thu Aug 17, 2017 2:27 pm Post subject: Re: Routed oil filter lines backwards... |
I would pull the valve covers and see how much metal in them.. depending on the type of oil filter you are using will depend on how much damage.. some wont let oil go backwards.. anti drain ...but not good |
Posted: Thu Aug 17, 2017 2:46 pm Post subject: Re: Routed oil filter lines backwards... |
Im using a wix filter... guess i should start putting together a back up short block before this one goes out |
turbotype1 Samba Member
Posted: Thu Aug 17, 2017 3:05 pm Post subject: Re: Routed oil filter lines backwards... |
Does it actually have oil pressure? _________________
117harv wrote: |
This new fad of get it the lowest, or run it with the worst looks, (patina) isn't cool, it's for the hey everyone look at me crowd, i'm driving a beat down ratty, unsafe, VW, how cool am I ???...your not....
Pissing off the purists since 1997
Wanted: Boyd Motors plate frame
57 Turbo Oval Sliding rag
67 13 window delux walk-thru- now 21
64 all original for the misses
83 Sinka m-TDI diesel |
Posted: Thu Aug 17, 2017 3:28 pm Post subject: Re: Routed oil filter lines backwards... |
I dont know if it has pressure, this is a type 3 motor with no oil sensor hole. |
modok Samba Member
Joined: October 30, 2009 Posts: 26743 Location: Colorado Springs
Posted: Thu Aug 17, 2017 6:11 pm Post subject: Re: Routed oil filter lines backwards... |
since the oil filter is in the cooler line it won't hurt much having it backward, just won't have any oil flowing through it, oil will bypass both like they aren't there. |
mark tucker Samba Member
Posted: Thu Aug 17, 2017 8:23 pm Post subject: Re: Routed oil filter lines backwards... |
Im lost, how does it bypass and not go through anything? type 3 gets oil pressure off the cooler. ( I have a nos type 3 cooler with the oil pressure port, wondered and finaly found out what it is.bought it years ago with some nos type 1 coolers from a porsche shop from the 60's&70's& 80's, there was lotsa nice stuff there.) |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31271 Location: Hot Arizona
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2714 Location: Hamble, Hampshire, UK
Posted: Fri Aug 18, 2017 11:19 am Post subject: Re: Routed oil filter lines backwards... |
Even if the oil goes through the filter backwards it would still work.
What may be more wrong is that you would need maybe two or three quarts of oil to fill up the loop. So you probably drained all the oil from the sump and stored in the loop when the oil pump sucked the sump down till it sucked air.
Trouble is that the correct cold oil level for that setup might be more than an inch above the top mark on the dipstick so you have probably been driving around with low oil in the sump..
Without an oil pressure or sump/dpistick temperature gauge you would not have been able to tell. _________________ Ancient vehicles and vessels
modok Samba Member
Posted: Fri Aug 18, 2017 6:13 pm Post subject: Re: Routed oil filter lines backwards... |
That's all quite reasonable but, wrong. Off day my samba friends?
mark- oil bypasses the cooler through the rear oil plunger, which is opened by oil pressure.
Cusser, I've had oil coolers uglier than that and they still worked fine, and I didn't use it as a hammer, but that's pretty funny
The grand majority of Oil filters currently made have an anti-drainlack valve, thus won't flow backwards. |
Posted: Fri Aug 18, 2017 6:16 pm Post subject: Re: Routed oil filter lines backwards... |
modok wrote: |
thats why I said depends on filter.. if it had a old chevy ford dodge filter from the 60s 70s early 80s? no drain back valve.. now on the water cooled I4 vws.. you better run a anti drain back or you will have lifter rattle for everrrrrr |
modok Samba Member
Posted: Fri Aug 18, 2017 6:22 pm Post subject: Re: Routed oil filter lines backwards... |
yeah you had it.
Funny when two things wrong make something work right.
If he had installed the filter "full flow" as intended it would have exploded or starved thee engine, but since it's in the cooler line...... |
Posted: Fri Aug 18, 2017 6:24 pm Post subject: Re: Routed oil filter lines backwards... |
yes morlock I know that, I thought you said the filter was still flowing.....or could of be my reading skills during the down pour from hell....never seen that much rain in my life.and..my bug was WFO and full of h2o...(windows down doors open, engine uncovered etc) |
Posted: Fri Aug 18, 2017 6:30 pm Post subject: Re: Routed oil filter lines backwards... |
mark tucker wrote: |
we have to.. and are going to get hammerd. more. you watching the Atlantic storms? 1 after the other |
modok Samba Member
Posted: Fri Aug 18, 2017 6:36 pm Post subject: Re: Routed oil filter lines backwards... |
Yikes. |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Sat Aug 19, 2017 9:37 pm Post subject: Re: Routed oil filter lines backwards... |
Isn't any body going to say any thing about the rubber mounted cooler ?
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Sun Aug 20, 2017 1:37 am Post subject: Re: Routed oil filter lines backwards... |
earthquake wrote: |
Casey |
No, that and zip ties make the world go round _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
modok Samba Member
Posted: Sun Aug 20, 2017 1:58 am Post subject: Re: Routed oil filter lines backwards... |
It's not really a such bad system.
The tubes break off real easy with those coolers, so not having the oil lines tied to the body, the one bungee cord mounting might be better than bolted down. |
challomoner Samba Member
Joined: October 13, 2010 Posts: 1195 Location: IRELAND
Posted: Sun Aug 20, 2017 3:23 am Post subject: Re: Routed oil filter lines backwards... |
modok wrote: |
yeah you had it.
Fram hp1 filter has a adbv, if you mixed up the inlet and outlet on one of these on a standard full flow setup what would happen ? Engine run for few minutes then seize from lack of oil ? |
