krazyj Samba Member
Joined: August 17, 2017 Posts: 1 Location: Los Angeles
Posted: Thu Aug 17, 2017 8:33 pm Post subject: Is my working area safe? |
Hi all,
I'm fairly new to wrenching and I'm looking for feedback on whether my outdoor setup seems safe.
I have a gravel driveway area in my backyard where I want to jack my car up and go underneath safely (i.e. pull a transmission, diff, etc).
In my opinion, I'd say this patch of driveway is 'very flat', however it's still not a perfectly poured concrete garage floor, and is also covered in small gravel.
I jacked up my car and gave it the 'shake test'. I shook it hard as hell. As hard as I could without getting a running start. And everything actually felt really solid. But, I'll admit I noticed very minor flex in things (perhaps because all of it is sitting on wood, on gravel, and on a not-absolutely-perfectly flat patch). Maybe this is normal even on perfect concrete?
At a maximum, the slope in this area doesn't seem to be more than ~2% over any stretch.
I'm using 4x '3 ton' HF steel jack stands to support a 1.5 ton overall car. The jack stands are placed on 12" x 12" x 3/4" pressure treated plywood, on the gravel.
Below is a picture of the driveway area in question, with the car up on the jack stands. Also, I took pictures of my 9" level placed in the middle of the 12" plywood base under each jack stand. I superimposed both directions in each photo.
Thoughts on whether this seems safe? My backup plan was to build [URL="http://imgur.com/j1VtpHF"]wooden wheel cribs[/URL] for each tire. I assume the larger surface area and more solid construction would be safer, hopefully in spite of the imperfect ground. Or maybe there's another recommendation that would work? (Perhaps some style of ramps?)
Thanks! |
flat4olsen Samba Member
Joined: February 20, 2014 Posts: 342 Location: Denmark, Europe
Posted: Thu Aug 17, 2017 9:27 pm Post subject: Re: Is my working area safe? |
I would say, that you are safe. At least compared to this guy:
nsracing Samba Member
Posted: Thu Aug 17, 2017 9:56 pm Post subject: Re: Is my working area safe? |
Yes, pretty safe. But I am paranoid - I always have a jack up there under too. IN case the damn teeth on the stands break off. Chinese made - ..many are. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
helowrench Samba Member
Joined: August 27, 2003 Posts: 567 Location: dallas texas
Posted: Thu Aug 17, 2017 10:26 pm Post subject: Re: Is my working area safe? |
EverettB wrote: |
Yes, you should be fine, I've worked on my Bus in my gravel side yard like that a few times.
As nsracing said though, I always have a floor jack underneath the end where I am doing something.
My floor jack is on a big sheet of plywood too. |
I have also used removed rims as a "safety" to ensure that I could not be crushed. _________________ Current VWs:
70 bug vert for wifey
73Thing bucket o rust
73 914 1.7
12 Passat 2.5 Highway cruiser |
wombatventures Samba Member
Joined: April 01, 2013 Posts: 20 Location: Peterborough, South Australia
Posted: Fri Aug 18, 2017 1:51 am Post subject: Re: Is my working area safe? |
flat4olsen wrote: |
That bloke is safe as... He's chocked the tyres with a brick!
_________________ 69 Kombi Camper
74 Superbug Convertible
71 Notch
Currently suffering from delusions of sanity! |
Posted: Fri Aug 18, 2017 2:48 am Post subject: Re: Is my working area safe? |
He is at the proper angle so when he is crushed wont suffer too much. |
lightice Samba Member
Posted: Fri Aug 18, 2017 3:45 am Post subject: Re: Is my working area safe? |
Like someone said, I'd use a few rims under the sills on each side as additional insurance.
In any case, take precaution...
Dale M. Samba Member
Posted: Fri Aug 18, 2017 7:51 am Post subject: Re: Is my working area safe? |
NO... I always though jack stands were for the stupid people.... Real mechanics use cinder blocks.....
Yes you are about as safe as it gets.... Still there is no guarantee, even jack stand fail....
http://lmgtfy.com/?t=i&q=jack+stand+failures
JUst check occasionally for any stability changes... Soft ground can allow one stand to sink a bit and everything changes...
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34013 Location: Conejo Valley, CA
Posted: Fri Aug 18, 2017 8:26 am Post subject: Re: Is my working area safe? |
helowrench wrote: |
EverettB wrote: |
I have also used removed rims as a "safety" to ensure that I could not be crushed. |
X2. Make a habit of sliding any rim removed under the pan. Heck, you gotta put it SOMEwhere anyway! |
mark tucker Samba Member
Posted: Fri Aug 18, 2017 9:38 am Post subject: Re: Is my working area safe? |
just pull over a ditch yes you should be fine, but remember shit happens so if somethen happens it aint on us...it's on you. |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6029 Location: CONGERS, N.Y.
Posted: Fri Aug 18, 2017 11:45 am Post subject: Re: Is my working area safe? |
Add Fire to the next on your safe list and it can sneak up on you.
Have friend working on bug with a gas leak in garage, and he drops his light.
Bulb breaks and FIRE!!! We push it out and hit it with hose. The house could have went up.
A month ago was taking out my rear seat. It drops on the battery, the hay under seat instantly blasts into fire. Lucky II was able to get it out fast enough and Took my shirt off and used ti to smother the fire. Again very lucky.
Car falls maybe you die. With fire you can take your home and family with you. . _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
Posted: Fri Aug 18, 2017 11:47 am Post subject: Re: Is my working area safe? |
Upgrade your work light to LEDs.
I have and I don't have to worry about the bulb breaking. |
Posted: Sun Aug 20, 2017 1:50 am Post subject: Re: Is my working area safe? |
That is why I do not go under a carlift without the tall jackstands. They make them so you can put them under the car in case the lift arms let go.
It is scary working under a carlift. Terrible what happened to those two guys getting squashed. |
pondervwmike Samba Member
Joined: June 16, 2017 Posts: 373 Location: Ponder(Dallas) Texas USA
Posted: Sun Aug 20, 2017 2:42 pm Post subject: Re: Is my working area safe? |
Indeed throw a couple tires on rims under the car and have a fire extinguisher handy. _________________ 1967 Cal Look Beetle Street Car in re-restoration,customization. Mom and Dad bought it in 1983 when I was 4.
2010 VW Tiguan
2000 BMW 528i
1997 Jeep Cherokee
2127cc build thread https://www.thesamba.com/vw/forum/viewtopic.php?t=681556&highlight= |
