sam_w Samba Member
Joined: March 07, 2002 Posts: 1479 Location: Petaluma, CA
Posted: Fri Aug 18, 2017 8:01 am Post subject: Replaced my rear axles |
My 'new' 74 Thing was making a clicking noise going around tight corners, and I checked and the boots were shot on the rear axles. SO instead of getting new boots I got a pair of Chinese axles and had my friendly VW mechanic Adam, replace the axles. They came with new bolts and washers, but the bolts were six pointed not the 12 pointed in place, so Adam used the old bolts. I will keep track on how long they last and I know Solomon Grundy will hate these boots, we'll see, $110 for 2 axles isn't worth sneezing at.
_________________ 63 singlecab
73 thingster
74 Thing |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5412 Location: Holland, MI
Posted: Fri Oct 05, 2018 7:45 am Post subject: Re: relaced my rear axles |
How are they holding up? Are these the ones with generic Type 2 joints instead of Type 4? I have the EMPI 90-6905 axles, which look similar. They fit things, but have the Type 2 joints. I have installed them on buggy’s before, and they held up well. I just installed a set on my personal project this past week, but I am really pushing it. At just over 20 degrees full drop, I suspect the cv joints won’t last long and I will be replacing them with Type 4 or “off road” Type 2 joints good for 25deg. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
sam_w Samba Member
Posted: Fri Oct 05, 2018 7:56 am Post subject: Re: relaced my rear axles |
They seem to be fine, and I think they have Thing CV's.
I'll take a pic amd post it.
Sam _________________ 63 singlecab
73 thingster
74 Thing |
74 Thing Samba Member
Posted: Fri Oct 05, 2018 8:56 am Post subject: Re: relaced my rear axles |
If those are the Empi kit cv's then I believe that they are Type II cv's and not Type IV. Glad they are holding up though. Empi has some race cv's that provide greater angles of movement. |
Posted: Mon Oct 08, 2018 2:20 pm Post subject: Re: relaced my rear axles |
Sam, look for a number on the EMPI cv joints. Example, VW 202-x-xxx. Just curious what yours are labled as. _________________ 1800 Type 4 Berrien 295
Posted: Mon Oct 08, 2018 7:03 pm Post subject: Re: relaced my rear axles |
Thing CV's are something like 1/8-3/16" thicker than bus CV's. Measure the thickness and we can tell you if you have Thing CV's or not. |
Posted: Mon Oct 15, 2018 6:39 am Post subject: Re: relaced my rear axles |
I called up EMPI for fun just to see what they had to say. They looked up the individual parts to the axle assembly on their bill of materials, and they are in fact regular bus CV joints.
Surprisingly, I don’t have any binding what so ever on my buggy with the axles areticulated to about 22 degrees. No clicking, no nothing. I’m very surprised.
Time will tell, we will see how long they last. I have never pushed these axles so far before. _________________ 1800 Type 4 Berrien 295
sam_w Samba Member
Posted: Mon Jan 21, 2019 8:40 pm Post subject: Re: relaced my rear axles |
I was trusting, so did not check.
Typ181 CV's are slightly longer tham typ2's so that is a way to check
I believe that a type 2 does 18 degrees where a type 181 does 22 degrees
Check the 'blind chicken racing' website for details of cv joints _________________ 63 singlecab
73 thingster
74 Thing |
Posted: Tue Jan 22, 2019 6:57 am Post subject: Re: relaced my rear axles |
I know mine came with T2 joints. Between the part number, ball size, and thickness of the outer race.
Apparently they can be had with different joints if special ordered, so there are other varieties out there. Would be interesting to know what you had.
At full drop, what angle do your axles sit at? _________________ 1800 Type 4 Berrien 295
Joined: February 21, 2003 Posts: 868 Location: Clifton Park NY Saratoga County
Posted: Sat Feb 02, 2019 7:22 am Post subject: Re: Replaced my rear axles |
The balls are larger on type 2 cvs and the cages are silver colored
They dont allow as much travel as the thing ones
I have a small pile of thing cv complete assemblies with good boots
they have smaller balls and are usually brown or dark colored cages _________________ Michael Basso
http://www.thingparts.com
New and Used VW Thing Parts Free advice
CALL 518 630 0173 |
Thing68 Samba Member
Joined: December 14, 2019 Posts: 71 Location: California
Posted: Fri Dec 20, 2019 6:10 pm Post subject: Re: Replaced my rear axles |
The EMPI 90-6905 axles are advertised as "Thing Only". |
Posted: Fri Dec 20, 2019 6:15 pm Post subject: Re: Replaced my rear axles |
China junk _________________ Michael Basso
CALL 518 630 0173 |
