HenrikL Samba Member
Posted: Fri Aug 18, 2017 1:07 pm Post subject: How to repair rust in front bumper mount? |
I need to repair a small hole in the front bumper mount of my 1964 notchback. Anyone have an idea of the best method?
I'm thinking about cutting along the red line and then sandblast everything and repair the rust on the workbench. A lot of work, but it seems very difficult to separate the 2 bumper mount parts from the inner wing when mounted on the car.
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Posted: Fri Aug 18, 2017 1:35 pm Post subject: Re: How to repair rust in front bumper mount? |
I would wire wheel the bumper mount flange to find the spot welds, drill those out and separate that piece to see what you have for rust under there. _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Bobnotch Samba Member
Posted: Fri Aug 18, 2017 1:57 pm Post subject: Re: How to repair rust in front bumper mount? |
W1K1 wrote: |
I would wire wheel the bumper mount flange to find the spot welds, drill those out and separate that piece to see what you have for rust under there. |
Yup, my thought as well. Plus, you'll be able to "hide" the repair easier.
The only way I'd cut that much out (to the red lines), would be IF it had more rust. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Apr 04, 2018 12:55 pm Post subject: Re: How to repair rust in front bumper mount? |
Separating the bumper mount flange wasn't too hard, but of course there was more rust under it.
Also note that there is absolutely no primer or rust proofing between the flange and the spare wheel well from the factory.
After some Scotch-Brite pad things look better.
260KMN Samba Member
Joined: January 17, 2014 Posts: 236 Location: Devon UK
Posted: Thu Apr 05, 2018 12:19 am Post subject: Re: How to repair rust in front bumper mount? |
Yes, your thread has given me much inspiration for my work.
Right now I think I will repair this in place and not cut anything more than the rust.
Posted: Tue Apr 10, 2018 1:37 pm Post subject: Re: How to repair rust in front bumper mount? |
Started welding....
