Fuel Line Inlet Fittings / Weber IDF 40
dgsaz
dgsaz is offline
PostPosted: Fri Aug 18, 2017 3:25 pm    Post subject: Fuel Line Inlet Fittings / Weber IDF 40 Reply with quote
OK, I have started the process of plumbing my newly reconditioned gas tank, new fuel filter (not located in the engine bay) and finally attaching the new fuel line to the new Weber IDF 40's.
Here is where I've got questions. The fittings from the fuel tap and in and out of the fuel pump are (I think) 5mm German braided lines. Everything fits like a glove until I get to the carburetors.
The inlets at the carbs looks to be 7mm. I played with a bit a of lube but the smaller lines do not want to attach to the larger inlet fittings.
Are there 5mm inlets for the Weber IDF? Do I need to keep the 7mm inlets?
This is my first go around with dual carbs and I'm a bit out of my sphere of knowledge.
Here is a photo of the dilemma.
You can see the difference between the fuel pump and the carb inlet.
How to proceed?
Thanks folks,
dgsaz
runamoc Premium Member
runamoc is offline
PostPosted: Fri Aug 18, 2017 5:05 pm    Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 Reply with quote
If you can get another threaded barbed fitting for the fuel pump hose 'size' put the two together with a plumbing coupling as an adapter. From 1/4" to 5/16"
Daily driver: '69 Baja owned 39 yrs. Plan B: '81 Rabbit Diesel LS Deluxe
In garage for rehab: '72 Ghia - '71 Beetle - '60 Sandrail
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
Wiring on a VW = It's just wires
ps2375
ps2375 is offline
PostPosted: Fri Aug 18, 2017 5:43 pm    Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 Reply with quote
I went with push-lock hose and -4 fittings. I run an electric FP up front w/ a CIS filter (also up front) and a compression to AN fitting on the metal line at frame horn. And then a "T" fitting on driver's side near carb. No hose clamps needed. cost was a little more, but very reasonable and hose and brass have dealt very well with todays fuels.
modok
modok is offline
PostPosted: Fri Aug 18, 2017 5:52 pm    Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 Reply with quote
You can change whatever parts you want, but I think you should use 1/4 or 5/16 fuel hose, because this is the USA and that's what's available.
The weber barbs are most likely 8mm (same as 5/16)
dgsaz
dgsaz is offline
PostPosted: Fri Aug 18, 2017 6:37 pm    Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 Reply with quote
After reading the comments thus far, I would like to find 1/4" fuel intakes for the carbs and plumb the entire system in 1/4".
Does anyone know of a source for 1/4" Weber fuel intake? Metric threads.
I thinks that's the way to go.
dgsaz
modok
modok is offline
PostPosted: Fri Aug 18, 2017 6:57 pm    Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 Reply with quote
The threads are about the same as our oil pressure sensors, meaning probably metric but it's SO close to 1/8 pipe that you can hardly tell for sure which it is. I've seen 1/8 tapered pipe barbs or 1/8 straight pipe thread screwed into them but I don't think it's right, but it's close enough to work. Dab of red loctite to make sure it seals and won't come loose is a good idea in any case, just make sure to rinse and blow out any excess.
It's also possible to fit MOST brands of 1/4 fuel line over the 5/16 barb, and once again that's not really "correct" but put some silicone grease on there and some Gates, Goodyear, or other GOOD brand of low pressure fuel line, it'll go, it will go, and plenty tight.
Dealing with fuel I can't endorse doing anything fishy like that but IMO, that's less risky than using some unmarked fuel hose like some places are selling. With no brand and part number to read, you don't know if it's Continental or imitation, ethanol safe or not. There is "mystery hose" out there and it IS causing trouble.
fivelugshortaxle
fivelugshortaxle is offline
PostPosted: Fri Aug 18, 2017 8:39 pm    Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 Reply with quote
Use one of the plastic fuel filters just out of the tube by transaxle. 5mm cuel line coming off metal line and i to fuel filter......7mm fuel line coming off of fuel cilter to go to carbs. Thkse filters are stepped to allow you to do this. Cheap....easy....and made to do that way.
Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc
chrisflstf
chrisflstf is offline
PostPosted: Fri Aug 18, 2017 8:42 pm    Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 Reply with quote
You should be able to buy a reducer in a barbed fitting
Dale M.
Dale M. is offline
PostPosted: Fri Aug 18, 2017 9:50 pm    Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 Reply with quote
Come out of fuel pump and use 1/4 to 5/15 barbed fitting (reducer) and do all plumbing from adapter to carbs in 5/16...
Should be available at most any hardware store or big box store...
Dale
“God forbid, anything should be easy” Hawkeye, M*A*S*H
57BLITZ
57BLITZ is offline
PostPosted: Fri Aug 18, 2017 9:53 pm    Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 Reply with quote
I do!
Definitely NOT pipe (taper) threads!
I ordered these . . . http://www.ebay.com/itm/Metric-M10-M10X1-Male-X-6m...25cc0d6b9f
The photo in the 'Bay ad is not the actual fitting!
What they sent to me looks quite different . . . The new 1/4" barb (on the right) is plated brass . . . that's the O.E.M. Weber fitting on the left
Jesucristo es mi Señor y Salvador!
mcdragracer
mcdragracer is offline
PostPosted: Fri Aug 18, 2017 10:11 pm    Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 Reply with quote
Just use the cone shaped fuel filter it has 2 different size stems.
That will be your adaptor, I've alway used that with a dual carb set up, works just fine.
modok
modok is offline
PostPosted: Fri Aug 18, 2017 10:29 pm    Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 Reply with quote
yes that's it, -10x1 thread-
Not too keen on the plastic fuel filters......but I might endorse a T fitting, a odd tee fitting with one 1/4 and two 5/16 barbs is probably easier to find than the 10x1 1/4 barb fitting, which....hey it's great that it does exist.... but you gotta admit that's a mutant bastard child of a fitting if there ever was one Shocked
57BLITZ
57BLITZ is offline
PostPosted: Fri Aug 18, 2017 10:45 pm    Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 Reply with quote
I'm with ya Glen on the plastic filters . . . especially when placed between the pump and carb(s)!
Wasn't gonna mention it because OP is lookin' for fittings to fit his carburetors, but . . . .for my Italian IDFs, one of these from the same seller . . . http://www.ebay.com/itm/Reducer-Hose-ID-5-16-to-1-...mp;vxp=mtr
Dale M.
Dale M. is offline
PostPosted: Sat Aug 19, 2017 7:42 am    Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 Reply with quote
Possibly...
https://www.belmetric.com/barbed-hose-adapters-c-1...10768.html
Dale
dgsaz
dgsaz is offline
PostPosted: Sat Aug 19, 2017 9:16 am    Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 Reply with quote
I do!
We have a winner. I bought two of these and I believe this should solve the dilemma.
Thanks all,
dgsaz
