drbus Samba Member
Posted: Sat May 06, 2017 3:10 pm Post subject: Hooking up an engine hoist to a 1.9 |
I have never lowered a waterbox. I see two likely hoist points (top center, front and rear). The crane has a hook......so to attach the hook to the engine do I use straps? hooks? bolts? Or some combination. Any photos would be appreciated. |
Terry Kay Banned
Posted: Sat May 06, 2017 3:48 pm Post subject: Re: Hooking up an engine hoist to a 1.9 |
Chains, cables, straps,
Motorcycle lift. _________________ T.K. |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6832 Location: Fort Lauderdale, Fl.
Posted: Sat May 06, 2017 4:28 pm Post subject: Re: Hooking up an engine hoist to a 1.9 |
Chain would be the easiest since you can use a bolt and nut to secure a link to the hole in the engine casing at the flywheel end and in the one near the Distributor.
Or you could use an "S" hook as below.
_________________ This free advice is worth exactly what you paid for it.
drbus Samba Member
Posted: Sat May 06, 2017 4:48 pm Post subject: Re: Hooking up an engine hoist to a 1.9 |
Very helpful I take it the eye holes in the case are strong enough. |
Posted: Sat May 06, 2017 5:29 pm Post subject: Re: Hooking up an engine hoist to a 1.9 |
If you are using a roll-around lift where the legs are in a "V" pattern, make sure the engine will fit between them. Kind of a PITA to get an engine almost all the way out and then find that you can't lower it to the ground because it wants to rest on the legs. |
Vanagon Nut Samba Member
Posted: Wed Sep 27, 2017 3:31 pm Post subject: Re: Hooking up an engine hoist to a 1.9 |
Am removing my 2.1 WBX today using method shown below but with a winch on wood frame. I could use a longer length of chain but as is, chain end at forward mount point is close to the plenum. I don't want to put pressure on plenum while lowering engine.
I'm considering using a piece of box steel as a spreader on chain. If it fits, just to confirm..... (with the usual "I'm responsible for whatever happens" in place)
Using a minimum 3/8" OD 5.x grade bolt at each end of the spreader to connect it to the chain should be strong enough right?
Thanks
Neil.
_________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4790 Location: Bemidji, MN
Posted: Thu Sep 28, 2017 5:32 am Post subject: Re: Hooking up an engine hoist to a 1.9 |
regarding the engine lift... i put a piece of plywood between the V legs, lowered the engine onto that, and then just pulled the engine back with the lift as it is on rollers. had to have the van rear end on car ramps plus 3" (wood pads) but it was very slick.
an engine leveler on the hoist is also useful especially if the trans is attached. could pretty much crank it to get the front trans mount in position with just light hand pressure.
-dan |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2796 Location: North Carolina
Posted: Thu Sep 28, 2017 6:50 am Post subject: Re: Hooking up an engine hoist to a 1.9 |
I know it's an older picture, but that picture of somebody using a park bike stand as frame to lower an engine from just cracks me up. I've got to try that! (not). _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
Posted: Thu Sep 28, 2017 10:52 am Post subject: Re: Hooking up an engine hoist to a 1.9 |
I was worrying needlessly. Turns out the chain didn't look like it was putting much, if any, pressure on the intake plenum.
It occurred to me that If using a hoist, one could rig up a rope to the rear engine mount point, use that to pull on engine away from clutch housing as it lowers ?? Run rope through license plate hole?
Anyway, its out.
https://photos.app.goo.gl/9oF9rltLewRk8pBw1
VE7TBN |
