daddygad Samba Member
Posted: Mon Aug 21, 2017 2:23 pm Post subject: Re: Needed: aircooled mechanic in auburnAL area or just plain advice |
a2d2 wrote: |
daddygad wrote: |
a2d2 wrote: |
p.s. Just from my own personal history with heads, I'm going to guess that you have a recessed valve seat as opposed to a burnt valve. Just mentioning this because if I'm right it means your head probably can't be repaired, you'll need to replace it. |
Would there be any way of diagnosing that without pulling the head off? I am probably going to try doing the adjustment before I do anything else, so that would be good to know if there's a way of sussing it out. |
If it's an intake valve you might be able to see it by removing your carb and intake manifold. This is what one of mine looked like, yours may not be this bad:
If it's an exhaust valve you would have to remove your heater boxes and exhaust to see it. |
Thank you! |
Posted: Mon Aug 21, 2017 3:26 pm Post subject: Re: Needed: aircooled mechanic in auburnAL area or just plain advice |
Just called the shop where I had it in to see if he could tell me the compression #'s apparently he did not check the compression on all 4 he checked the kilovolts, and then seeing that cyliner 1 was dead he just checked the compression of cylinder 1 which turned out to be zero. There were 2 other cylinders with lower kVs, but I dont remember which and he didn't give me the #'s. NOt sure what that information even means since this is the first i have ever heard of checking the kVs. |
CessnaJon Samba Member
Joined: August 15, 2008 Posts: 677 Location: Senoia,GA
Posted: Mon Aug 21, 2017 3:56 pm Post subject: Re: Needed: aircooled mechanic in auburnAL area or just plain advice |
I have no idea what that information means as well. Kilovolts? Only thing I can imagine that's referring to is ignition strength. Nothing to do with compression. _________________ 1973 Westy (shared birthday)
1990 Westy Multivan
2015 Passat TDI 6sp
2015 Sportwagon TDI 6sp
LR-JET, Gulfstream 159 |
AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1698 Location: The Old Pueblo
Posted: Mon Aug 21, 2017 5:58 pm Post subject: Re: Needed: aircooled mechanic in auburnAL area or just plain advice |
I'd find a way to pick up my van. The info we are getting is suspect and the longer it sits at a garage the longer it is before your back on the road to VW bliss.
Any measurement in kilovolts is not telling me jack and gets me no further toward understanding the issue at hand. We need compression numbers associated w cylinder numbers in order to make heads or tails of this conundrum. _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
Posted: Mon Aug 21, 2017 9:17 pm Post subject: Re: Needed: aircooled mechanic in auburnAL area or just plain advice |
AZ Landshaper wrote: |
Any measurement in kilovolts is not telling me jack and gets me no further toward understanding the issue at hand. We need compression numbers associated w cylinder numbers in order to make heads or tails of this conundrum. |
Oh yeah, I got it out of there that same day I received the news and just limped it home. I am not letting that guy touch it again. the next time I move it is going to be either to get it onto a flat spot on the street where I can do the work by my house (my drveway is on a slant) or to get it towed to a place in Columbus I found today that is reputable and works on air-cooled VWs and said they could rebuild my whole engine if need be for not much more than that place quoted me for swapping out just the one head with a new one which doesn't sound like the best idea anyway... So now I just have to decide which to do, basically. Seeing as my money is tight, I intend to just keep learning whatever I can til I feel comfortable enough to tear into it. Ideally I could find someone locally who could give me a hand if I get stuck, but it looks like that isn't going to happen. Thanks again for all your input(s)! |
Posted: Tue Aug 22, 2017 6:39 am Post subject: Re: Needed: aircooled mechanic in auburnAL area or just plain advice |
Anyone here have the vol. 8 of the BugMe video series and found it helpful for learning the workings of their vanagon engine. As I udnerstand its basically the same thing, right? |
Posted: Wed Aug 23, 2017 7:39 am Post subject: Re: Needed: aircooled mechanic in auburnAL area or just plain advice |
Pull the valve cover after finding a replacement valve cover gasket. You dont want to break that seal without knowing you can close it back up. Id get a new gasket. A few of them.
Would this fit the bill?
http://chircoestore.com/valve-cover-gasket-1700cc-2000cc-bus-1972-1979.html |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22641 Location: NYC/Upstate/ROW
Posted: Fri Nov 09, 2018 3:23 pm Post subject: Re: Needed: aircooled mechanic in auburnAL area or just plain advice |
_________________ .ssS! |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Fri Nov 09, 2018 3:39 pm Post subject: Re: Needed: aircooled mechanic in auburnAL area or just plain advice |
Do an actual compression test with a gauge in the plug hole.
On the hole with no/low compression, pull the rocker shaft and make sure all valve spring retainers are even. It is easy to see a dropped valve, the installed heights of the valve spring retainers will be way off. This is all too common with abused type 4 engines.
1000 labor is very fair. Just dealing with the heater boxes and exhaust on these engines is a major pain. _________________ Steve
Steve's 87 Syncro project |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Sat Nov 10, 2018 12:02 am Post subject: Re: Needed: aircooled mechanic in auburnAL area or just plain advice |
I have a few extra vanagon air cooled motors now. To bad I can’t crate ship you one or better yet drive it to you. Bummer _________________ Stuart Zickefoose
206-841-7324
[email protected] |
weswsimpson Samba Member
Joined: September 29, 2015 Posts: 191 Location: Chicago
Posted: Sat Nov 10, 2018 8:50 am Post subject: Re: Needed: aircooled mechanic in auburnAL area or just plain advice |
Here's a helpful resource, and Colin will travel to you!
www.itinerant-air-cooled.com |
Posted: Mon Nov 12, 2018 8:13 pm Post subject: Re: Needed: aircooled mechanic in auburnAL area or just plain advice |
Steve Arndt wrote: |
1000 labor is very fair. Just dealing with the heater boxes and exhaust on these engines is a major pain. |
Well there's an update on the situation. I had it towed to scumbugs in Columbus, GA and the guy says after pulling the engine, installing a new head and reinstalling the engine, that it is knocking (and he says DEFINITELY an engine knock, not a lifter noise) and my bearing on cylander 1 must have suffered damage so I am going to need a rebuild. this is beyongd my finances at present so I now basically have to sell it so i can pay them for the work they already did. yes i am bummed! |
Posted: Mon Nov 12, 2018 8:27 pm Post subject: Re: Needed: aircooled mechanic in auburnAL area or just plain advice |
What would you say to a crate mailed long block? I have a good bottomend that I will be selling shortly. Give Me a call! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Tue Nov 13, 2018 10:11 am Post subject: Re: Needed: aircooled mechanic in auburnAL area or just plain advice |
Stuartzickefoose wrote: |
What would you say to a crate mailed long block? I have a good bottomend that I will be selling shortly. Give Me a call! |
i will give you a call. |
Posted: Wed Nov 14, 2018 8:01 am Post subject: Re: Needed: aircooled mechanic in auburnAL area or just plain advice |
daddygad wrote: |
As per Stuart's suggestion I had the mechanic take a short video of the engine running to hear the noise it makes. I am told that new lifters on these engines can be noisy til they pump up from being driven and it can occasionally be mistaken for an engine knock. My mechanic seems certain its not a lifter. Feel free to let me know what you think. Personally I think it could be both.
https://www.youtube.com/watch?v=yH6mEG-tZTk&feature=youtu.be |
Posted: Wed Nov 14, 2018 10:41 am Post subject: Re: Needed: aircooled mechanic in auburnAL area or just plain advice |
Yeah, that is not a lifter. Internet Audio can be deceptive but that sounds pretty bottom end to me. The slight change on float would suggest rod knock to me, but with a 75% confidence level _________________ .ssS! |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5994 Location: Brooklyn
Posted: Wed Nov 14, 2018 12:20 pm Post subject: Re: Needed: aircooled mechanic in auburnAL area or just plain advice |
Quote: |
Abscate wrote: |
There is nothing cheap about this car you are running. It's an expensive toy unless you can fix it, and I mean all of it, yourself. Make that commitment or sell it and move on |
That's my hope. Its just hard to figure out how to even get started. Maybe I ought to sell it and get an ealier one so I can make more use of the "idiot" book, (since that is the category I fall into). |
Everything Abscate said applies equally to the earlier ones. Same engine back to '72. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Wed Nov 14, 2018 12:25 pm Post subject: Re: Needed: aircooled mechanic in auburnAL area or just plain advice |
Just watched that video, they don't have smartphones yet in Georgia? They take their videos on potatoes still? _________________ 1965 Volkswagen 1500 Variant S
Posted: Wed Nov 14, 2018 12:48 pm Post subject: Re: Needed: aircooled mechanic in auburnAL area or just plain advice |
That sounds like a fan shroud hitting a engine mount. Mine had the same noise forever till I did my last rebuild and figured out what was hitting. Hard to tell with the video though. The only reason I say that is the frequency of the low end noise (not the lifters that are also clicking) is just a bit to slow. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
