RichBenn Samba Member
Joined: November 16, 2005 Posts: 703 Location: Lake Tahoe, NV
Posted: Sat Aug 19, 2017 12:09 pm Post subject: Replace or refurbish my propane tank? |
Yes, I know there are other threads on this, but not my tank.
Since I need to replace the shutoff valve, and probably other components, it's time to make a call on replace vs refurbish.
Rust is not bad, except for where the tag was:
If I did refurbish, would I just remove the nameplate and grind the rust out and repaint? My concern, of course, is tank thickness. Or maybe it's time to pony up for a shiny, new, modern tank..... _________________ Rich |
Joined: April 29, 2015 Posts: 704 Location: Berkeley Ca
Posted: Sat Aug 19, 2017 12:12 pm Post subject: Re: Replace or refurbish my propane tank? |
If it were mine I would refurbish. Looks fine. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Sat Aug 19, 2017 2:04 pm Post subject: Re: Replace or refurbish my propane tank? |
Yours looks fabulous compared to my old one:
I chose to replace it with new but even in that state someone else wanted it to refurbish. |
Posted: Sat Aug 19, 2017 2:32 pm Post subject: Re: Replace or refurbish my propane tank? |
The nameplate came off too easily.
It's the thickness of the pieces that came off between the plate and the tank that concern me. In the early tanks, they only welded the corners of the plate. Water and therefore rust developed there. Chunks that came off were 1/8" thick. Was that from the tank or the plate? I can't tell.
The pressure release on these is set much higher than the portable tanks, assuming a thicker tank. It would be OK, I'm sure, except for an abnormal condition, which is what safety is about. _________________ Rich
Posted: Sat Aug 19, 2017 2:37 pm Post subject: Re: Replace or refurbish my propane tank? |
Ahwahnee wrote: |
Actually, you have some oil and grime there, but the overall rust is similar to mine. Clean both and they'd look similar. The plate area, however.... _________________ Rich |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Sun Aug 20, 2017 10:06 am Post subject: Re: Replace or refurbish my propane tank? |
RichBenn wrote: |
The nameplate came off too easily... |
That tank is done. I was going to say before seeing this post that the tag is where a lot of rust hides. I had one that didn't look bad except the tag and I paid a shop to sandblast the tank and they went right through the tank where the tag was. I cleaned up another one in better shape, and the next one I just bought a new one. In most cases that is what I would recommend.
Even when they are good enough to refurb, it is not worth the effort and the cost of the new valves. You spend way too much time and wind up with an old tank that doesn't bad but it isn't new. New tanks are fairly cheap and it's something you will never have to deal with again. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9620 Location: Western WA
Posted: Sun Aug 20, 2017 10:32 am Post subject: Re: Replace or refurbish my propane tank? |
Sandbblast will tell you how deep the corrosion is. But refurbishing is not for everyone. I suppose you could have it proof-tested.
Slightly off-topic but maybe you're interested. I have this notion of welding two westy tanks together to make a long skinny 5 gallon tank. Pretty easy to "proof-test" it. Does anyone know what pressure a propane tank is proofed to? _________________
....KTMs, GasGas, SPOT mtb |
E1 Samba Member
Joined: January 21, 2013 Posts: 6581 Location: Westfalia, Earth
Posted: Sun Aug 20, 2017 10:35 am Post subject: Re: Replace or refurbish my propane tank? |
We had the shutoff valve replaced at a propane shop for like $25.
Tank has well over 300K on it, but a factor is it hasn't lived in a rust belt, either. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
rubbachicken Samba Member
Posted: Sun Aug 20, 2017 11:26 am Post subject: Re: Replace or refurbish my propane tank? |
do you have a propane fridge or heater.
if you do not, don't waste your time, the burners will last a long time on 1lb green bottles.
our lucy's big adventure, i bought a new propane tank, we only ever use the burners, that new tank has only run empty 3 times in 2 years of full time living in the van, cooking and coffee making.
with shipping it cost me near $400, that's a LOT of 1lb bottles, i would not do that again. _________________ lucy our westy
lucy's BIG adventure
meet 'burni'
619 201 0310 or 617 935 4182 |
Posted: Sun Aug 20, 2017 12:42 pm Post subject: Re: Replace or refurbish my propane tank? |
Wire wheel and post pictures. Not sure where that 1/8" came from. If it's from the tabk itself I would not reuse |
vwjetboat Samba Member
Posted: Sun Aug 20, 2017 12:50 pm Post subject: Re: Replace or refurbish my propane tank? |
don't know about other states.. but here in Florida.. the tank has a date.. and if its out of date.. they will not fill it.. this was on a RV we had.. I would think the same applies to vw camper tanks.. so I would check into that if you have not yet |
Vanagon Nut Samba Member
Posted: Sun Aug 20, 2017 1:22 pm Post subject: Re: Replace or refurbish my propane tank? |
The ID tag on the Manchester propane tank on my '81 was falling off. There was noticeable pitting at tank where tag was. I replaced the tank. I've read that the ASME tank wall thickness is about 1/4". Regardless, who knows if its rusting on the inside too? Later Manchester tanks had that tag welded all the way around.
I think this is regarding residential type propane tanks but may apply, depending on state or province?
I don't know.
http://www.propane101.com/photo_albums/PropaneTankNameplates/index.html _________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
Posted: Sun Aug 20, 2017 6:58 pm Post subject: Re: Replace or refurbish my propane tank? |
Sodo wrote: |
Slightly off-topic but maybe you're interested. I have this notion of welding two westy tanks together to make a long skinny 5 gallon tank. Pretty easy to "proof-test" it. Does anyone know what pressure a propane tank is proofed to? |
It does not seem deep, It actually looks better than some pics of ones refurbished here on thesamba. Tapping with a hammer resonates the same as all other locations.
I don't know why the pieces were behind the nameplate.
I like the idea of a longer tank, although it would never work if I welded it, ha ha.
The relief valve is 312 psi. I don't know what the safety factor would be though. I imagine it's capable of pretty high pressure. _________________ Rich |
Posted: Sun Aug 20, 2017 7:06 pm Post subject: Re: Replace or refurbish my propane tank? |
Vanagon Nut wrote: |
I don't know.
http://www.propane101.com/photo_albums/PropaneTankNameplates/index.html |
I believe the RV horizontal tank tags ID it as not needing recertification. But technically, with no tag, like most self refurbished tanks, I believe it should not be filled. But given where the tag is, no filler has asked to read it yet nor refused to fill the tank. _________________ Rich |
Posted: Sun Aug 20, 2017 7:08 pm Post subject: Re: Replace or refurbish my propane tank? |
rubbachicken wrote: |
with shipping it cost me near $400, that's a LOT of 1lb bottles, i would not do that again. |
Do have the LP fridge. _________________ Rich |
Posted: Sun Aug 20, 2017 7:14 pm Post subject: Re: Replace or refurbish my propane tank? |
E1 wrote: |
Tank has well over 300K on it, but a factor is it hasn't lived in a rust belt, either. |
With the valve that has the pressure relief, they are much more. Still cheaper than a new tank. _________________ Rich |
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Sun Aug 20, 2017 7:20 pm Post subject: Re: Replace or refurbish my propane tank? |
We use the stove and use the fridge on LP continuously while on a trip. Our tank wasn't that bad around the label, but looked so awful that no propane folk locally would fill it.
We replaced it, and are glad we did so. No more refusals or not understanding "open the bleed valve all the way". _________________ Jim Crowther
Vespa GTS 300 |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Sun Aug 20, 2017 11:45 pm Post subject: Re: Replace or refurbish my propane tank? |
Is there not a mandatory inspection interval in the US for gas cylinders? In Australia you need to have gas cylinders inspected, tested and recertified every ten years. Even if it looks fine on the outside it could be corroded internally so unless you get it inspected properly you have no idea if it is good or not. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
Posted: Mon Aug 21, 2017 7:25 am Post subject: Re: Replace or refurbish my propane tank? |
Mellow Yellow 74 wrote: |
Is there not a mandatory inspection interval in the US for gas cylinders?... |
My recollection is that there is an interval for the usual backyard barbeque tanks but no such restriction on mounted RV equipment. |
Posted: Mon Aug 21, 2017 8:02 am Post subject: Re: Replace or refurbish my propane tank? |
Ahwahnee wrote: |
yes there is a restriction of RV tanks... if its out of date.. they will not fill it.. |
